  3. OpenHAB
  4. OpenHAB/MQTT Tips & Hints
40 Posts 17 Posters 58.6k Views 5 Watching
  • K kolaf
    In parallel with trying to get the radio library to work with my hardware, I started trying to connect this up to my openHAB installation. I will be connecting the Arduino gateway unit directly to a computer through USB, so a solution has to be able to talk to it through the serial port. As far as I can see there are two options for me:
    1. Use one of the MQTT gateway libraries available (which one?).
    2. Use the place and gateway Web server implementation created for openHAB implementation posted by someone a few months ago.
    Are there any other options I have missed and should be looking at?
    I already have a mqtt broker running on my server, so there is no overhead there. However, it seems a bit like overkill to put a mqtt client, a broker, and the mqtt binding between the serial gateway and openhab. Also, I'm not quite sure what kind of management functionality this offers as far as assigning IDs and so on.
    What do you guys suggest I do?
    YveauxY Offline
    YveauxY Offline
    This topic was split off http://forum.mysensors.org/topic/301/the-best-way-to-connect-to-openhab to discuss tips and hints specific to using MySensors together with MQTT middleware and OpenHAB.
    If you made something nice using this combination or have some questions/issues please post them in here!
    @kolaf I just started experimenting with openhab and find it quite hard to get started. There's some documentation ( far from complete, especially when you're just starting) but the general impression is that it's very powerful, mainly due to all the programming options. I'm quite sure you could directly talk to a mysensors gateway using the serial protocol, using e.g. rules, if you want.
    I doubt however if you want to write your own protocol handler...
    Anyway, I'm currently using an Ethernet gateway which tasks to a Perl script I wrote (https://github.com/Yveaux/MySensors_MQTTGateway) that does the conversion to and from MQTT. This script is a MQTT client that runs on the same server I run openhab and the mosquitto broker on. This is the only difference compared to @Damme solution who runs a broker on the gateway.
    I like the flexibility of storing & accessing all data through an MQTT broker which makes up for the apparent overkill going through MQTT just to connect mysensors to openhab.
    As long as your server has enough resources to run it all its not really worth the effort to directly talk to my sensors or create an openhab binding for it.
    K DammeD 3 Replies Last reply
    • K kolaf
      @tboha Thanks, that was very helpful. Do you have some more details for the mystical "do some processing"?
      @Yveaux how do you use the mqtt binding to talk to the sensors? I have looked into it, and must admit I have no idea on how to achieve this. It's apparent that you need some kind of transformation, but my understanding ends there. Specifically, I would like to implement a toggle switch, a switch that toggles a light every time it is activated instead of having a specific on and off state.
      YveauxY Offline
      YveauxY Offline
      I'm not at my PC right now so I can't add any actual code, but let's take the switch as an example.
      A sensor (with say, id 100) which has the switch connected sends a 1 when pressed and a 0 when released to the gateway, with child I'd 7. This comes out the gateway and is picked up by the perl script. The script publishes this to /mysensors/100/7/V_LIGHT.
      You define a switch item in openhab which subscribes to this topic. To read the state of the switch openhab expects either ON or OFF from MQTT instead of 1 or 0 sent by the sensor. I could have changed this on the sensor side, but I choose to implement a map-transformation on the openhab-side. Now the state of the switch changes to ON when pressed on the sensor.
      I also implemented a dimmer which can be controlled by 1or 2 momentary switches (on different nodes) and an rgb dimmer so far. Maybe we can start a separate topic on MQTT & openhab usage for different sensors so we can all benefit from it.
      K 1 Reply Last reply
      • YveauxY Yveaux
        K Offline
        K Offline
        kolaf
        Good idea. If someone made a good, or at least workable and well-documented, solution than I am sure this project would be much utilised by the openHAB crowd as well. Maybe explaining it to me could be a good start for a how to/guide which could also be utilised in their wiki?
        I hope I'm not stepping on any Vera toes when saying this?
        YveauxY 1 Reply Last reply
        • K kolaf
          YveauxY Offline
          YveauxY Offline
          Not everybody owns a vera and IMHO it's only beneficial for this project when multiple home automation systems are supported. Finding a greatest common divider for e.g. the types of variables will only improve things.
          • YveauxY Yveaux
            K Offline
            K Offline
            kolaf
            wrote on last edited by kolaf
            @Yveaux good, I agree, and I am glad to hear it.
            How would you solve a toggle switch? The sensor does not know whether the light is on or off since it may be toggled through the controller separately. This means that in my head it will simply send "on" every time and it is up to the item/map to figure out whether it should be turned on or off depending on its current state. I guess this may be required as a rule. Or does your server support sending items dated back to the sensor so that it knows whether the light is off or on currently? In that case it can make the decision itself and send the correct on or off command. Maybe I should ask this question in the openhab group...
            • T Offline
              T Offline
              tboha
              @kolaf : I´m not very experienced in Java, so the code reflects my missing knowledge and is much longer than it should be.
              The purpose of "Split Message" is to split multilpe messages into single messages and afterward split this single messages into useful informations to set the OpenHAB items accordingly.
              First part: common declarations
              import org.openhab.core.library.types.*
              import org.openhab.core.persistence.*
              import org.openhab.model.script.actions.*
              var String[] buffer
              var String[] linebuffer
              var int SensorID
              var int transmissions_old = 0
              var int transmissions_new = 0
              var int transmissions_missed = 0
              var int RadioID
              Second part: Splitting multiple Messages
              rule SplitMessage
              when
              	Item Arduino changed
               then
               /* Split messages separated with NEWLINE */
              linebuffer=  Arduino.state.toString.split("\n")
              Third part: Splitting messages according to the serial protocol
              buffer(0) = NODE_ID
              buffer(1) = CHILD_ID
              buffer(2) = MESSAGE_TYPE
              buffer(3) = SUB_TYPE
              buffer(4) = Message
               for (String element : linebuffer) {
              	buffer = element.split(";")
              	RadioID = new Integer(buffer.get(0))
              	switch (RadioID) {
              	case 7: {
              			SensorID = new Integer(buffer.get(1))
              			switch (SensorID) {
              				case 0 : postUpdate (MySensorsT0, buffer.get(4))
              				case 1 : postUpdate (MySensorsT1, buffer.get(4))
              				case 2 : postUpdate (MySensorsT2, buffer.get(4))
              				case 3 : postUpdate (MySensorsT3, buffer.get(4))
              				} /*switch (SensorID) */
              			}  /* case 7 */
              	case 6: {													 /* ExperimentalNode 6 - soll mal NODE 1 werden */
              			if (buffer.get(1)== "10") {							 /* child 10 ist der Homematic Anschluss */
              				postUpdate (HMSerialOut, buffer.get(4))
              			} /* if */
              	} /* case 6 */
              	case 9: {                                                      /* eigentlich war das mal NODE 6 */
              			if (buffer.get(1) == "2") {                            /* Child 2 ist der Schrittmacher      */
              				transmissions_new = new Integer(buffer.get(4))
              				logInfo ("TRANS","Transmissions new " + transmissions_new.toString() )
              				logInfo ("TRANS","Transmissions old " + transmissions_old.toString() )
              				if (transmissions_old == 0) {transmissions_old = transmissions_new -1 } /* beim ersten mal passiert nichts */
              				transmissions_missed = transmissions_missed + (transmissions_new - transmissions_old - 1)
              				postUpdate (Missed_Transmissions, transmissions_missed.intValue.toString)
              				postUpdate (Transmission_Count, transmissions_new.toString())
              			} /* case 9 */
              	case 5: {
              				if (buffer.get(1) == "0") { 						/* Child 0 ist die Luftfeuchte */
              					postUpdate (MySensorsMobHum, buffer.get(4))
              				if (buffer.get(1) == "1") { 						/* Child 1 ist die Temperatur */
              					postUpdate (MySensorsMobTemp, buffer.get(4))
              			} /*case 5: */
              	default:	{
              			postUpdate (MySensorsNode, buffer.get(0))
              			postUpdate (MySensorsChild, buffer.get(1))
              			postUpdate (MySensorsMtype, buffer.get(2))
              			postUpdate (MySensorsStype, buffer.get(3))
              			postUpdate (MySensorsMessage, buffer.get(4))
              	  }   /*switch(RadioID) */
              	} /*for (String element) */
              end
              So the drawback of the serial binding becomes obvious - every action has to be coded separately. On the other hand it offers enormous controlling possibilities (eg scene configurations),
              Fourth part: some actions triggerd from OpenHAB GUI/Webinterface:
              rule ArdSwon
              when
              	Item ArduinoSwitch changed from OFF to ON
              then
              	sendCommand(Arduino, "4;2;1;0;2;1\n")
              end
              rule ArdSwoff
              when
              	Item ArduinoSwitch changed from ON to OFF
              then
              	sendCommand(Arduino, "4;2;1;0;2;0\n")
              end
              rule HmArdon
              when
               Item ArduinoHMSw1	changed from ON to OFF
              then
              	sendCommand(Arduino, "1;10;1;0;24;HD01004000000\n")
              end
              rule HmArdoff
              when
               Item ArduinoHMSw1	changed from OFF to ON
              then
              	sendCommand(Arduino, "1;10;1;0;24;HD01004010000\n")
              end
              To send commands to the MySensors Network you have to use the same "Arduino"Item. In my oppinion another drawback. A separate way out would be nicer. Despite of my oppinion there is no interference between input and output - so i can live with this.
              The above example illustrates controlling a LED connected to an Arduino-UNO with the original Relais-Sketch, the second part controls some of my Homematic devices via another MySensors node (connected to Homematic via USB) .
              So at last I got a 2.4Ghz network to communicate with my Homematic and an ethernet connection via OpenHAB. In combination with direct interaction between certain MySensor nodes this results in a very redundant and stress-resistant home controlling network.
              • K kolaf
                YveauxY Offline
                YveauxY Offline
                To make sure I understand you right, are both the switch & light located at the same node or do you have a sensor node (switch) and actuator node (light) ?
                • YveauxY Yveaux
                  K Offline
                  K Offline
                  kolaf
                  The light is entirely separate from the switch. In my specific case it will typically be a Z-wave relay controlling the light, so I will have to map the toggle switch to the light relay in openhab. This is why I assume I have to use a rule to achieve this.
                  • YveauxY Offline
                    YveauxY Offline
                    @kolaf Here's my code to use one or two switches to dimm. I hope it gives you some inspiration to connect your zwave switch.
                    MQTT topics (exposed by the MQTT perl script. Node 120 = switch sensor, node 119 = dimmable light):
                    /mySensors/120/0/V_LIGHT           switch, reporting 1 when pressed, 0 when released
                    /mySensors/120/1/V_LIGHT           switch, reporting 1 when pressed, 0 when released
                    /mySensors/120/2/V_LIGHT           switch, reporting 1 when pressed, 0 when released
                    /mySensors/119/0/V_DIMMER          dimmable light, accepting integer value between 0 and 100
                    Items:
                    Switch Switch_Up               {mqtt="<[server:/mySensors/120/0/V_LIGHT:state:MAP(switchFromMqtt.map)]"}
                    Switch Switch_Down             {mqtt="<[server:/mySensors/120/1/V_LIGHT:state:MAP(switchFromMqtt.map)]"}
                    Switch Switch_UpDown           {mqtt="<[server:/mySensors/120/2/V_LIGHT:state:MAP(switchFromMqtt.map)]"}
                    Dimmer Light_Dimmed   (Lights) {mqtt=">[server:/mySensors/119/0/V_DIMMER:state:*:default]"}
                    switchFromMqtt.map: (in transform folder)
                    0=OFF
                    1=ON
                    Rules for 2-switch dimmer control (short press Switch_Up switches light on, short press Switch_Down switches light off, keep pressed to increase/decrease light level):
                    val Long DimmerDelayMs = 333L
                    rule "DimUp"
                    when
                      Item Switch_Up received update ON
                    then
                      var Boolean dimmed = false
                      do
                        Thread::sleep(DimmerDelayMs)
                        if (Switch_Up.state == ON)
                          sendCommand( Light_Dimmed, INCREASE )
                          dimmed = true;
                      } while (dimmed)
                      if (!dimmed) sendCommand( Light_Dimmed, ON )
                    end
                    rule "DimDown"
                    when
                      Item Switch_Down received update ON
                    then
                      do
                        if (Switch_Down.state == ON)
                          sendCommand( Light_Dimmed, DECREASE )
                          dimmed = true;
                      } while (dimmed)
                      if (!dimmed) sendCommand( Light_Dimmed, OFF )
                    end
                    Rules for 1-switch dimmer control (short press switches light on/off (depending on current state), keep pressed to increase/decrease light level):
                    rule "DimUpDown"
                    when
                      Item Switch_UpDown received update ON
                    then
                      var Number percent = 0
                      if (Light_Dimmed.state instanceof DecimalType) percent = Light_Dimmed.state as DecimalType
                      do
                        if (Switch_UpDown.state == ON)
                          // Start cycling up/down until released
                          var Boolean dimmUp = percent < 100
                          do
                            if (dimmUp) sendCommand( Light_Dimmed, INCREASE )
                            else		sendCommand( Light_Dimmed, DECREASE )
                            if (percent >= 100)	dimmUp = false;
                            if (percent <= 0)	dimmUp = true;
                            dimmed = true;
                          } while (Switch_UpDown.state == ON)
                      } while (dimmed)
                      if (!dimmed)
                        // Short press: switch on or off, depending on current state
                        if (percent > 0)	sendCommand( Light_Dimmed, OFF )
                        else				sendCommand( Light_Dimmed, ON )
                    end
                    Rule for the dimmable light:
                    rule "MyDimmer0"
                      when
                        Item Light_Dimmed received command
                      then
                        if(Light_Dimmed.state instanceof DecimalType) percent = Light_Dimmed.state as DecimalType
                        if(receivedCommand==INCREASE) percent = percent + 5
                        if(receivedCommand==DECREASE) percent = percent - 5
                        if(receivedCommand==ON) percent = 100
                        if(receivedCommand==OFF) percent = 0
                        if(percent<0)   percent = 0
                        if(percent>100) percent = 100
                        postUpdate(Light_Dimmed, percent)
                    end
                    Some stuff I'm still struggling with (any help/ideas appreciated):
                    • Not sure if I can wrap (parts of) rules in a function to make re-use easier
                    • Getting the current value of an item seems complicated first testing for DecimalType, then getting it. Maybe this can be done more efficient?
                    • I use Thread::sleep to determine the timing of the buttons on the sensor node (pressed short/long). This will be influenced by the jitter on the sensor values received, but currently it seems to work fine. Furthermore Thread::sleep (probably) blocks whole rule processing, so this isn't a nice solution. The short/long presses can also be dermined on the sensor node and reported with different values, but then the sensor node is no longer a dumb switch and has to have knowledge of short/long presses....
                    • YveauxY Yveaux
                      Items:
                      0=OFF
                      1=ON
                      rule "DimUp"
                      when
                      then
                        do
                            dimmed = true;
                        } while (dimmed)
                      end
                      rule "DimDown"
                      when
                      then
                        do
                            dimmed = true;
                        } while (dimmed)
                      end
                      rule "DimUpDown"
                      when
                      then
                        do
                            do
                              dimmed = true;
                        } while (dimmed)
                        if (!dimmed)
                      end
                      rule "MyDimmer0"
                        when
                        then
                      end
                      K Offline
                      K Offline
                      kolaf
                      @Yveaux Excellent, this is just what I needed, thank you.
                      I started looking at your Perl script since this seems like the most active solution for openhab integration. I have a couple questions if you don't mind.
                      Why do you have two versions of the gateway script, and which version should I use as a basis when adding serial support?
                      Does your gateway take care of node ID assignments? I guess I will figure out that by reading more of code :-)
                      I'm thinking that I will fork your project to add a serial option to your script, controlled by some kind of commandline argument.
                      • K kolaf
                        YveauxY Offline
                        YveauxY Offline
                        Glad I could help!
                        The serial format changed from MySensors 1.3 (protocol 1) to 1.4beta (protocol 2). I was lazy and just cloned the 1.3 version to add 1.4 support (the 2-version). Wouldn't be hard to support both, but I really wrote this script for my own usage. It's not documented and I tried to help Damme in the past to build MQTT support. I'm primarily on 1.4b btw, with some 1.3 setup for backwards sniffer support...
                        If more people start using it I should do some things the nice way ;-)
                        Not at the moment. Shouldn't be hard to implement though, but when you implement it you run into another issue of mapping the node-ID's onto the MQTT topic tree, or accessing the right topic from OpenHAB.
                        Sticking to fixed Node ID's seemed to make more sense to me.
                        Feel free to fork, but the current code is based on AnyEvent. Not that I like it, but it seemed to have the best MQTT support. There is some hacking in the script to get things working, for which I don't know how they behave when switching to serial.
                        • YveauxY Offline
                          YveauxY Offline
                          Btw. there's one important thing to understand when using the Perl script. When it receives values from a sensor node through the gateway it's easy to publish the value in the topic-tree.
                          When a value has to be sent to an actuator node, the story is different as the script has to know which topic to subscribe to at the MQTT broker.
                          Currently when a mysensor node requests a value from the gateway the script automagically translates this into a subscription of the corresponding topic with the MQTT broker. The dimmer node for example, calls gw.request(childID, V_DIMMER) from setup to subscribe itself to dimmer messages.
                          Note that sometimes this request gets lost (CRC error or so) and the subscription fails. While not supported by the MySensors library, a robust implementation should wait for a response after requesting this value and retry when it doesn't come.
                          The Perl script stores all current subscriptions persistent (file subscriptions.storage) so restarting the Perl script will not force you to restart all nodes to subscribe again.
                          • YveauxY Offline
                            YveauxY Offline
                            And another small one; an RGB dimmer!
                            MQTT topics (exposed by the MQTT perl script. Node 118 = 3-channel dimmable light):
                            /mySensors/118/0/V_DIMMER          dimmable light RED, accepting integer value between 0 and 100
                            /mySensors/118/1/V_DIMMER          dimmable light GREEN, accepting integer value between 0 and 100
                            /mySensors/118/2/V_DIMMER          dimmable light BLUE, accepting integer value between 0 and 100
                            Items:
                            Dimmer Light_R      {mqtt=">[server:/mySensors/118/0/V_DIMMER:state:*:default]"}
                            Dimmer Light_G      {mqtt=">[server:/mySensors/118/1/V_DIMMER:state:*:default]"}
                            Dimmer Light_B      {mqtt=">[server:/mySensors/118/2/V_DIMMER:state:*:default]"}
                            Color Light_RGB 	"RGB Dimmer" 	(Lights)
                            Rules to distribute colorwheel value over R,G,B dimmers:
                            rule "Set RGB value"
                            when
                                    Item Light_RGB changed
                            then
                                    var HSBType hsbValue = Light_RGB.state as HSBType
                                    postUpdate( Light_R, hsbValue.red.intValue )
                                    postUpdate( Light_G, hsbValue.green.intValue )
                                    postUpdate( Light_B, hsbValue.blue.intValue )
                            end
                            No button control here; just using the colorwheel and on/off buttons in the GUI.
                            Enjoy!
                            siodS E 2 Replies Last reply
                            • YveauxY Yveaux
                              DammeD Offline
                              DammeD Offline
                              Damme
                              Code Contributor
                              wrote on last edited by Damme
                              rule to calculate absolute humidity and dew point from degree Celsius and rH%
                              import java.lang.Math
                              import java.lang.Integer
                              import java.lang.Double
                              rule "Calculate absolute humidity (g h2o / m3 air) and dew point"
                              when
                                  Item temp1 changed or
                                  Item hum1 changed
                              then
                                  var temp = temp1.state as DecimalType
                                  var hum = hum1.state as DecimalType
                                  var t1 = (17.271*temp.floatValue) / (237.7+temp.floatValue) + Math::log(hum.floatValue*0.01)
                                  var dew = (237.7 * t1) / (17.271 - t1)
                                  var Number c1 = ((17.67*temp.floatValue)/(temp.floatValue+243.5))
                                  var abs = (Math::pow(Math::E,c1.doubleValue)*6.112*2.1674*hum.floatValue) /(273.15+temp.floatValue)
                                  Dewpoint1.postUpdate(dew)
                                  AbsHum1.postUpdate(abs)
                              end
                              • DammeD Damme
                                when
                                    Item hum1 changed
                                then
                                end
                                YveauxY Offline
                                YveauxY Offline
                                @Damme Nice calculation example! Thanks!
                                • D Offline
                                  Dany
                                  Hi everyone!
                                  I'm new in the topic. I find it very interesting the world of mysensors.
                                  I would like to ask whether there is a description of someone that I can set my mqtt openHAB bindings eg .: an Arduino LED dimmer ?
                                  I already read http://forum.mysensors.org/topic/303/mqtt broker-gateway
                                  I made a Humidity sensor node, and Relay node, too.
                                  It would be good if we had a basic description or example project for beginners from all sensor type. :)
                                  • pgoP Offline
                                    pgoP Offline
                                    pgo
                                    wrote on last edited by pgo
                                    It is not rocket science to get the openHAB running w/MQTT gateway, see for example my post with DS/Light/Relay in http://forum.mysensors.org/topic/115/implementing-multiple-sensors/60
                                    But sure, it would be great to put a wiki with all sensor settings for openHAB together on one page. I needed to read/search for some days to put the knowledge together...
                                    Example of the openhab screenshots on mobile https://github.com/pgo-sk/mysensors/wiki/Home-automation-using-mysensors-and-openHAB
                                    There you see also the mapping of the sensor
                                    • A Offline
                                      A Offline
                                      adi32k
                                      How can I make openhad respod to gw.request(sensor, V_HEATER_SW,0);
                                      I have a relay actuator sketch and in setup() I have this
                                      for (int sensor=1 ; sensor<=NUMBER_OF_RELAYS;sensor++)
                                      gw.present(sensor, S_HEATER);
                                      practically I would like openhab to respond to the gw.request with the actual state of the relay.
                                      My item definition is the follwing. I am able to ON and OFF the relay, but I need to find a way to get the values from openhab of the relays when the relay actuator arduino reboots.
                                      Switch Incalzire_Releu_GF_Living2 "Incalzire Releu Living 2" <heating> (Incalzire) {mqtt=">[mysensor:MyMQTT/3/2/V_HEATER_SW:command:ON:1],>[mysensor:MyMQTT/3/2/V_HEATER_SW:command:OFF:0]"}
                                      • raditvR Offline
                                        raditvR Offline
                                        raditv
                                        is there any sample code for controlling RGB led here?
                                        • ChaoticC Offline
                                          ChaoticC Offline
                                          Chaotic
                                          Sorry to Necro this thread but had a question,
                                          I believe I read somewhere that you can use a serial gateway connected to a pi and have openhab/mqtt run on the pi?
                                          How would one go about setting this up? Currently I have 2 Unos one running as the serial gateway. I plan to replace the serial gateway with a nano I'm still waiting on that.
                                          I just got the pi last night so I'm still working on getting everything up and running on that but I'd rather just connect the gateway directly to the pi rather than have to get a wifi/ethernet module for one of the arduinos.
                                          Also probably outside the scope of this thread (and thats fine) but anyone have a good guide for setting up the pi for openhab/MQTT?
                                          113.2k
