  3. MySensors Php API class + command line script + Form
9 Posts 3 Posters 4.6k Views 4 Watching
  • soifS Offline
    soifS Offline
    soif
    wrote on last edited by soif
    As I needed a simple tool to test MySensors send/receive messages, I've created a basic php class, including a command line script , that can be used to send/receive mysensors messages directly to the Ethernet Gateway.
    You can use it in your php controllers, or directly on the command line by tapping commands like:
    ./mysensors_bin.php 192.168.0.240 set 12 0 V_STATUS 1
    This example send a command to the gateway at IP 192.168.0.240, to set the V_STATUS to 1, for Node 12, child 0...
    The project is at GitHub, and your contributions are most welcome !
    https://github.com/soif/MySensors_Php_API
    BTW I did my best to understand how MySensors messages worked, but without more documentation, I may have missed some things. So test it, and feel free to commit PR to the develop branch !
    HTH :-p
    • soifS Offline
      soifS Offline
      soif
      Currently Working (develop branch) on a convenient form to convert/send messages .
      Form
      It should certainly help developers to test their sensors/gateway ;-)
      • soifS Offline
        soifS Offline
        soif
        I've just posted version 1.1, including the form showed above. ;-)
        Any current users ?
        Comments?
        soifS 1 Reply Last reply
        • soifS soif
          Any current users ?
          Comments?
          soifS Offline
          soifS Offline
          soif
          Updated to v1.2 adding Serial gateway experimental support!
          As I don't have any serial gateway to test, I can't figure if it work or not, but I've implemented all the needed components to make it work.
          Would you please test if it work fine for you, and push some PR if some things need to be fixed for the serial connection.
          If you had to modify the "PhpSerial" class, would you please also push it back to the original developer repo
          HTH
          • A Offline
            A Offline
            ahmedadelhosni
            Great idea.
            I am trying to run the form.php but "select type first" doesn't change. tested on chrome and IE
            • soifS Offline
              soifS Offline
              soif
              Seems like Chrome + IE does not like function argument default values in JS, while mozilla does.
              I've just pushed v1.21 which fixes this bug.
              git pull ;-)
              A 1 Reply Last reply
              • soifS soif
                git pull ;-)
                A Offline
                A Offline
                ahmedadelhosni
                @soif Great. I will test it tomorrow.
                • soifS Offline
                  soifS Offline
                  soif
                  If you dont use git just replace the form.php with the one at GitHub
                  Let me know if it works flawlessly (eth or serial?).
                  cheers
                  • Ivan ZI Offline
                    Ivan ZI Offline
                    Ivan Z
                    There is my php module for MajorDomo https://github.com/Shagrat2/majordomo-mysensor
                    His contain library for MYSensor phpMS.php, and to extend classes for Serrial & TCP (phpMSCom.php, phpMSTcp.php)
