  3. NRF24L01+PA+LNA
NRF24L01+PA+LNA
32 Posts 7 Posters 13.3k Views 9 Watching
    moskovskiy82
    I was running an NRF24L01 with the built in antenna and had some problems with range. Got from aliexpress an NRF24L01+PA+LNA
    After replacing the module on my NodeMCU MQTT gateway i can see that my RX is a little bit improved and i can get all the sensor data. The problem is that after replacing i cannot send out commands to relay sensors. Nothing happens. As soon as i switch back to plain NRF - everything works...
    NRF is powered directly from the pins of NodeMCU...
    • noelgeorgiN
      noelgeorgiN
      noelgeorgi
      Same issue here, all data transmitted fails with st=fail , i thought it was a power issue and specific to me, @hek
      M 1 Reply Last reply
      • noelgeorgiN noelgeorgi
        moskovskiy82
        @noelgeorgi
        I remember there are options like
        #define RF24_PA_LEVEL RF24_PA_MAX
        So maybe they need to be tuned in the gateway code?
          @hek?
          The PA radio module requires much more juice. You can lower the transmission power in MyConfig.h (1.5) or by using the MY_RF24_PA_LEVEL define in sketch (development).
          The arduino/NodeMCU has limits on how much power you can draw from its pins. Separate powering might be needed when using the upper PA levels.
          noelgeorgiN 1 Reply Last reply
          • OitzuO
            OitzuO
            Oitzu
            @moskovskiy82 there are several topics about this:
            http://forum.mysensors.org/topic/3353/nrf24l01-with-antenna-not-working/2
            http://forum.mysensors.org/topic/1877/solved-2-x-nrf24l01-pa-lna-with-rf24_pa_max/2
            as example. There are several problems with the nrf24l01+pa+lna.
            • OitzuO
              OitzuO
              Oitzu
              Just to get an idea how they perform: I got, with the right supply etc. about 1000m free line of sight out of this modules max.
              Currently i have a stable link of about 270m with 200 packtes/s in a non line of sight environment (forest).
                @hek?
                noelgeorgiN
                noelgeorgiN
                noelgeorgi
                @hek i tried even using #define MY_RF24_PA_LEVEL RF24_PA_MIN with the PA+LNA modules but still sending fails but receiving is ok, i think its an issue with NodeMCU and PA+LNA modules rather than power supply issues.
                • OitzuO
                  OitzuO
                  Oitzu
                  @noelgeorgi if it works with the normal nrf24l01+ modules, it is more likely that it is a power/noise/shielding problem.
                  • OitzuO Oitzu
                    noelgeorgiN
                    noelgeorgiN
                    noelgeorgi
                    @Oitzu I tried adding capacitors and the issue still persists, I will try another supply :disappointed:
                    • OitzuO
                      OitzuO
                      Oitzu
                      @noelgeorgi have a look here: http://blog.blackoise.de/2016/02/fixing-your-cheap-nrf24l01-palna-module/
                      Tackles most of the nrf24l01 pa/lna module problems.
                      In short: Power/Noise/Shielding.
                      Addidtional caps don't help in any case.
                      • OitzuO Oitzu
                        noelgeorgiN
                        noelgeorgiN
                        noelgeorgi
                        @Oitzu Thank for your replies, but i have already read that blog earlier and my other PA+LNA modules connected to the nodes just work fine.
                        • OitzuO
                          OitzuO
                          Oitzu
                          @noelgeorgi: My experience with this: Power supplies differ. Even modules that seem to be the same can have different effective output. So maybe trying another supply is the way to go, yes.
                          Just want to help. ;)
                          B 1 Reply Last reply
                          • OitzuO Oitzu
                            B
                            B
                            bigjimjeedom
                            @Oitzu ,
                            just a question; i have a serial gateway on my JEEDOM box and i have a range problem in my stone house;
                            so i replace my nrf24l01+ "classic" with a shielded NRF24L01+PA+LNA (as described in the web site you gave us) powered with a separate 3.3v regulator (the module as a little router antenna).
                            it is working but he range is similar as with the classic version.
                            So i wanted to know your setting in "config.h" ;
                            mine are:
                            #define RF24_PA_LEVEL_GW RF24_PA_LOW
                            #define RF24_DATARATE RF24_250KBPS
                            what are your settings for a good range ? (i need about 50m in my house)
                            thanks for your help
                            • OitzuO
                              OitzuO
                              Oitzu
                              @bigjimjeedom you should receive the best results with:
                              #define RF24_PA_LEVEL_GW RF24_PA_MAX
                              As long as your power supply is clean and your module is shielded.
                              • OitzuO Oitzu
                                B
                                B
                                bigjimjeedom
                                @Oitzu
                                do you use thoses settings (max max) ? because some people says that it was not the good way with this module but maybe it is because of bad power supply ???
                                i use this for supplying (with a 5v from USB):
                                http://fr.aliexpress.com/item/New-Socket-Adapter-plate-Board-for-8Pin-NRF24L01-Wireless-Transceive-module-51/32230227557.html?spm=2114.30011508.3.2.TXAdlL&ws_ab_test=searchweb201556_1,searchweb201602_1_10036_10035_10034_10033_507_10032_10020_10001_10002_10017_10010_10005_10006_10011_10003_10021_10004_10022_10009_401_10008_10018_10019,searchweb201603_8&btsid=3092fef5-564c-43aa-98a5-0e834674bcd1
                                • OitzuO
                                  OitzuO
                                  Oitzu
                                  @bigjimjeedom said:
                                  @Oitzu
                                  do you use thoses settings (max max)?
                                  Yes. I use the max/max settings. I also use as datarate RF24_2MBPS but RF24_250KBPS should be better for good range.
                                  Yes this is due to low power supply -> The module doesn't get enough current for the MAX setting.
                                  OR
                                  Bad power supply -> The module needs more current -> bad supplys tend to be noisier on higher current.
                                  OR
                                  Bad shielding -> The output from the module is that high that it feedbacks (without the shielding) back into the IC.
                                  Never used them, but on the datasheet they look okay.
                                  • OitzuO Oitzu
                                    @bigjimjeedom said:
                                    @Oitzu
                                    OR
                                    OR
                                    B
                                    B
                                    bigjimjeedom
                                    @Oitzu
                                    thanks a lot for your help !
                                    i try this tonight and i will tell you!
                                    • OitzuO
                                      OitzuO
                                      Oitzu
                                      @bigjimjeedom i'm eager to hear your results. :)
                                      • F
                                        F
                                        flopp
                                        Other problem
                                        I have cap 4,7uf
                                        No shield
                                        Power from seperate source
                                        When I use it in my Ethernet gateway it starts up but can't receive anything.
                                        When I put it on other Uno(repeater) it works fine.
                                        When I have it on Uno(battery sensor sketch) it works fine.![alt text](image url)
                                        What am I missing?
                                        • OitzuO
                                          OitzuO
                                          Oitzu
                                          Add shield try again. Even electronics near to the pa/lna module can induce enough noise that it stops working.
                                          Different power supplys on the ethernet gateway and the uno?
                                          F 1 Reply Last reply
