  3. Leaf Wetness
Leaf Wetness
45 Posts 9 Posters 33.4k Views 3 Watching
  • epierreE Offline
    epierreE Offline
    epierre
    wrote on last edited by epierre
    Leaf wetness is important to know to detect for crops the neet to make some treatments to avoid some diseases (tomatoes, grapes...)...
    With soil humidity and temperature, it is an element important to monitor your crops.
    In order to make it, some parts are needed:
    • a rain sensor whicl looks like to work as the Davis expensive one, this one is double sided and inexpensive.
    • a box enclosure that can work in the outside
    • an arduino with radio (and good software ;-))
    • and a source of energy.
    or that last point, I'm wondering how to make it since I have both 5V and 3.3V arduini, and 2xAAA or 3xAA batteries holders.
    z-wave - Vera -> Domoticz
    epierreE 1 Reply Last reply
    • epierreE Offline
      epierreE Offline
      epierre
      From this document here is the caracteristic of the leaf wetness response to events:
      • epierreE epierre
        epierreE Offline
        epierreE Offline
        epierre
        I'll try to power a 3.3V mini pro with a 3xAA batteries holders, and have it lowered to 3.3V with an AMS1117.
        Sensor resistance seems to lower when there is humidit on the holder as expected. I have 735 as analogRead when it is dry.
        • epierreE Offline
          epierreE Offline
          epierre
          First test yesterday, device is well powered, device presentation ok, but afterward nothing was mesured... to be investigated on connexions...
          • epierreE epierre
            epierreE Offline
            epierreE Offline
            epierre
            hmmm... difficult to make it work on batteries... AND the gas sensors overloading the radio.... now I have it functional.
            RJ_MakeR 1 Reply Last reply
            • epierreE epierre
              RJ_MakeR Offline
              RJ_MakeR Offline
              RJ_Make
              @epierre
              What do you mean the gas sensor overloaded the radio?
              RJ_Make
              • RJ_MakeR RJ_Make
                @epierre
                epierreE Offline
                epierreE Offline
                epierre
                @ServiceXp just that I have a Mega sketch with 7 sensors reporting too frequently one one side, and on the other the weservice call was too slow, making me think of no transmission, but it was delayed in fact...
                • epierreE Offline
                  epierreE Offline
                  epierre
                  Some experiments:
                  • I left it on a window border, it varied by one ohm on the night.
                  • radio close is ok with the basic antenna.
                  • i'll try to see to put it further outside, at the moment there are more than 10°C difference along with wet cars on the morning. I fear the rain drop may not be enough sensible...
                  There is an alternative to the expensive davis one: LEAF WETNESS SENSOR
                  I'll modify the sketch to report a percentage, as other humidity sensors would do.
                  Some interresting discussion:
                  • 200 KOmhs = very dry leaf
                  • 20 KOmhs = slew fog
                  • 5 KOhms = heavy rain
                  About oxydation, dfrobot has one ground probe with this explanation:
                  Immersion Gold which protects the nickel from oxidation. Electroless nickel immersion gold (ENIG) has several advantages over more conventional (and cheaper) surface platings such as HASL (solder)
                  • epierreE Offline
                    epierreE Offline
                    epierre
                    some returns:
                    • from Sept 11th to 15th, the batteries (3*1.5V) went from 4.5V to 3.2 as mesured today, it stopped emitting on sept 15th
                    • the leaf sensor shows heavy signs of oxydation without any rain during the period... this is a real problem with all those copies around... that is not a very viable solution...
                    I've seen another product from Spain at Liebllium that I guess I will test for I haven't found any other item...
                    YveauxY 2 Replies Last reply
                    • epierreE epierre
                      some returns:
                      YveauxY Offline
                      YveauxY Offline
                      You're definitely not the first to report this.... I've read many negative reviews of these cheap sensors.
                      • YveauxY Yveaux
                        epierreE Offline
                        epierreE Offline
                        epierre
                        @Yveaux but finding good one seems to be .... very difficult... I've spoken of immersive gold... will try to see if those are better....
                        • epierreE epierre
                          some returns:
                          YveauxY Offline
                          YveauxY Offline
                          @epierre any idea why your sensor lasted this short?
                          How often did it report its value to the gateway? Was it sleeping in between? Any other sensors connected?
                          • YveauxY Yveaux
                            epierreE Offline
                            epierreE Offline
                            epierre
                            @Yveaux several ideas:
                            • it reported every 10000
                            • it has no other sensor (this was my first try on batteries...)
                            • I had an AMS1117 in entry but I didn't needed it
                            • I haven't hacked the 3.3V core with the websites @a-lurker ideas
                            I'm waiting for the batteries from my other post because using so fast batteries is not environment friendly...
                            Has there been simulation of energy usage for those arduini ? e.g. for a spark core it isadvertized at 500mW
                            • epierreE Offline
                              epierreE Offline
                              epierre
                              I've finally received from cooking hacks the leaf wetness sensor board that should be better than the one from china...
                              It is the one from hobby boards:
                              I guess I can recycle the lectronic from the cheap one on this one ?
                              • hekH Offline
                                hekH Offline
                                It doesn't look much different that the china-ones. Is it gold-plated or something?
                                • epierreE Offline
                                  epierreE Offline
                                  epierre
                                  yes it is, from the hobby board site it is $2, but it is a quarter the china's size.
                                  sorry I missed your point, it is gold plated, immersion gold.
                                  • epierreE Offline
                                    epierreE Offline
                                    epierre
                                    Ok, so I made some adjustments from my last try:
                                    • hobbyboard immersion gold sensor
                                    • I kept the comparator from the other sensor to facilitate work with the arduino
                                    • I've added a 18650 LiOn battery (5000mAh) to have an extended life cycle
                                    Here is the sketch:
                                    https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
                                    What I can say, is that it is very sensitive. It is now outside live in the cold.
                                    This could be used for a leak sensor easily.
                                    • epierreE Offline
                                      epierreE Offline
                                      epierre
                                      so my 5000mAh lasted outside... 4 days... btw I didn't remove all leds from the comparator that could be an improvement and the outside weather is quite cold.
                                      I had a reading every 30 secs, way to quick surely...
                                      @hek is there a way to power the radio only when necessary ? I guess the gw.sleep could be a gw.sleep and a gw.wakeup and manage the delay outside ?
                                      hekH 1 Reply Last reply
                                      • epierreE epierre
                                        hekH Offline
                                        hekH Offline
                                        wrote on last edited by hek
                                        @epierre
                                        gw.sleep() sleeps the radio as well. What do you mean by power down radio? Like cutting power using digital pin?
                                          @epierre
                                          epierreE Offline
                                          epierreE Offline
                                          epierre
                                          @hek said:
                                          @epierre
                                          yes, now you combine sleep for the radio and delay, what I mean is to have loop() run without radio, and if a transmission is needed to have a command that power it.
                                          If you have a long dry period, a device on battery will consume a lot of power having the radion on and off, if it is always off until a sensor finds something, that would save more power, no ?
