  2. Bug Reports
  3. problem to code?
problem to code?
7 Posts 3 Posters 3.1k Views
  • Michel - ItM
    Michel - ItM
    Michel - It
    wrote on last edited by Michel - It
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    //#include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #include "Bounce2.h"
    //char sketch_name[] = "Multy-Relay";
    //char sketch_ver[]  = "0.1";
    #define RELAY_ON 0                      // switch around for realy HIGH/LOW state
    #define RELAY_OFF 1
    #define DEBUG On
    #define RADIO_ID 45                    // radio Id, whatever channel you assigned to
    #define noRelays 2
    const int relayPin[] = {3,4}; //  switch around pins to your desire
    const int buttonPin[] = {6,7}; //  switch around pins to your desire
    class Relay             // relay class, store all relevant data (equivalent to struct)
    public:
      int buttonPin;                    // physical pin number of button
      int relayPin;                     // physical pin number of relay
      byte oldValue;                    // last Values for key (debounce)
      boolean relayState;               // relay status (also stored in EEPROM)
    Relay Relays[noRelays];
    Bounce debouncer[noRelays];
    MyMessage msg[noRelays];
      gw.begin(incomingMessage, RADIO_ID, true);
      delay(500);
      gw.sendSketchInfo("Bar-Multy-Relay&Interruttori", "0.4");
      delay(500);
      // Initialize Relays with corresponding buttons
      for (int i = 0; i < noRelays; i++)
        Relays[i].buttonPin = buttonPin[i];              // assign physical pins
        Relays[i].relayPin = relayPin[i];
        msg[i].sensor = i;                                   // initialize messages
        msg[i].type = V_LIGHT;
        debouncer[i] = Bounce();                        // initialize debouncer
        debouncer[i].attach(buttonPin[i]);
        debouncer[i].interval(5);
        pinMode(Relays[i].buttonPin, INPUT_PULLUP);
        Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
        digitalWrite(Relays[i].relayPin, Relays[i].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
        gw.send(msg[i].set(Relays[i].relayState ? true : false));                 // make controller aware of last status
        gw.present(i, V_LIGHT);                               // present sensor to gateway
        delay(250);
      gw.process();
      for (byte i = 0; i < noRelays; i++)
        debouncer[i].update();
        byte value = debouncer[i].read();
        //if (value != Relays[i].oldValue && value == 0)
        if (value != Relays[i].oldValue)
          gw.saveState( i, Relays[i].relayState );
        }                 // save sensor state in EEPROM (location == sensor number)
        Relays[i].oldValue = value;
    // process incoming message
      if (message.type == V_LIGHT)
        if (message.sensor < noRelays)            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
          digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState ? RELAY_ON : RELAY_OFF); // and set relays accordingly
          gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
    REport
    send: 44-44-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
    send: 44-44-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=fail:1.5.4
    send: 44-44-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
    repeater started, id=44, parent=0, distance=0
    send: 44-44-0-0 s=255,c=3,t=11,pt=0,l=25,sg=0,st=fail:Bar-Multy-Relay&Interrutt
    send: 44-44-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=fail:0.4
    send: 44-44-0-0 s=0,c=1,t=2,pt=2,l=2,sg=0,st=fail:0
    find parent
    send: 44-44-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    send: 44-44-0-0 s=0,c=0,t=2,pt=0,l=0,sg=0,st=fail:
    send: 44-44-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=fail:0
    send: 44-44-0-0 s=1,c=0,t=2,pt=0,l=0,sg=0,st=fail:
    send: 44-44-0-0 s=0,c=1,t=2,pt=2,l=2,sg=0,st=fail:1
    send: 44-44-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=fail:1
    <<< reset button
    find parent
    :triumph:
    • Michel - ItM
      Michel - ItM
      Michel - It
      • sundberg84S
        "st=fail" means the receiving node or gateway has problems sending ack back to the sending node.
        Its probably a hardware/radio issue (power and/or range). Try adding a capacitor (http://www.mysensors.org/build/connect_radio#connecting-a-decoupling-capacitor) to the receiving radio, change powersource, move receiver/sender closer to each other or build a repeater.
        • D
          D
          DavidZH
          It might be the board you're using. I had similar issues when I was building my weather node with the same proto-board. After I switched to single sided board it worked immediately. The copper might reflect RF-energy back to the radio and your Arduino that interfere with the transmission.
          • sundberg84S
            Also the relays can cause problems - they cause spikes in the circuit which the radio dislikes. Try replacing the relays with leds or something and see what happens.
            • Michel - ItM
              Michel - ItM
              Michel - It
              the problem was the radio module nrf24, replacing it I solved
              ps
              when you see lots of nrf24 not buy them on the cheap. thank you all for the support
              • Michel - ItM
                Michel - ItM
                Michel - It
                the project
                http://forum.mysensors.org/topic/3721/2-switch-2-relay/2
