Presentation of local sensor with GatewayESP8266MQTTClient seems to fail
  • Hi MySensors,
    I was doing some tests yesterday with an ESP8266-01 as an MQTT Client Gateway. Really impressive work from you Henrik and the rest of the team.
    When trying to add a local sensor to the ESP8266MQTTClient Gatway, the Presentation part doesn't seems to work. Nothing is being sent to the MQTT Broker.
    #include <ESP8266WiFi.h>
    MyMessage msg(1,V_TRIPPED);
    void presentation() {
    sendSketchInfo("Test", "1.0");
    present(1, S_DOOR);
    If I add the same commands to the loop they're being sent forward to the Broker.
    present(1, S_DOOR);
    wait(5000);
    I'm using ESP8266-01 for my tests without any radio (NRF24L01/RFM69) attached.
    The rest is working great, so far.
    //#define MY_RADIO_NRF24
    I'm using the development branch, and it's up-to date.
  • Admin
    Hmm.. that has probably been forgotten for the MQTT client gateway...
    Could you try adding:
    if (presentation)
        presentation();
    Here:
    https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/core/MyGatewayTransportMQTTClient.cpp#L148
  • @hek
    Yes, that fixed the issue. Thanks. 😃
  • 33
  • 9
  • 8
