AC Power controller with node to node remotes
  • Hero Member
    We have a water tank for general use around the home, it has a 240v AC pump that supplies pressurised water via buried poly pipe to several different areas. I do not leave the pump on all the time in case a line breaks and empties all the water, so need a way to turn on the pump when out in the yard. I have been using one of the common 433mhz power switches with a remote. This works out ok but if I am already out in the yard and decide i need to use the water it is a trip in to get the remote.
    So I am now going to build a MySensors controller with stationary remotes. The Remotes will be stand alone MySensors units that will use the node to node feature and talk directly to the pump controller. I will place them in three locations around the home which will make using the tank water much easier.
    These remotes will only get occasional use and will be battery operated. Rather than trying to make these nodes low power devices I will be taking a different approach. Each remote will have three two push buttons and two one LED. The Two buttons will be used to send the on or off message to the pump controller and supply power to the sensor when it is held on. A Green LED will indicate when the arduino has booted up and is ready to transmit and the red button will flash once to indicate a message has been sent.
    The down side is of course you have to wait a few seconds for the Arduino to boot before you can send the pump message but the up side is this node will draw no current while on standby, so the batteries should last a very long time between changes.
    I have posted the rough sketches for the controller and the remotes below, these are working on the bench. One thing i did find that when I sent a direct node message to the pump controller Domiticz did not show the change of state on it's interface. I need Domoticz to always know the state of the pump as i intend to set up a LUA script to turn off the pump if it is left on for too long. So I have added in code to make sure Domiticz knows the state.
    Anyway it all seems to work but I am sure there will be a few changes before I am done 🙂
    The pump controller
       DESCRIPTION
       Based on the RelayWithButtonActuator sketch
       This node will be used as a dual 240v ac socket controller
       The node will also respond to node to node messages from remote
       switching nodes
    // Enabled repeater feature for this node
    //#define MY_REPEATER_FEATURE
    #include <Bounce2.h>
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define CHILD_ID_A 1   // Id of the sensor child
    #define CHILD_ID_B 2   // Id of the sensor child
    const int buttonPinA = 3;
    const int buttonPinB = 4;
    const int relayPinA = 5;
    const int relayPinB = 6;
    int oldValueA = 0;
    int oldValueB = 0;
    bool stateA = false;
    bool stateB = false;
    //#define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
    //#define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
    //#define CHILD_ID 1   // Id of the sensor child
    Bounce debouncerA = Bounce();
    Bounce debouncerB = Bounce();
    MyMessage msgA(CHILD_ID_A, V_STATUS);
    MyMessage msgB(CHILD_ID_B, V_STATUS);
      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
      pinMode(relayPinA, OUTPUT);
      pinMode(relayPinB, OUTPUT);
      // After setting up the buttons, setup debouncer
      debouncerA.attach(buttonPinA);
      debouncerA.interval(5);
      debouncerB.attach(buttonPinB);
      debouncerB.interval(5);
      digitalWrite(relayPinA, RELAY_OFF);
      digitalWrite(relayPinB, RELAY_OFF);
      // state = loadState(CHILD_ID);
      // digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);
    void presentation()  {
      sendSketchInfo("Mains Controller", "1.0");
      present(CHILD_ID_A, S_LIGHT);
      present(CHILD_ID_B, S_LIGHT);
       Example on how to asynchronously check for new messages from gw
      debouncerA.update();
      // Get the update value
      int valueA = debouncerA.read();
      if (valueA != oldValueA && valueA == 0) {
        send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
      oldValueA = valueA;
      debouncerB.update();
      int valueB = debouncerB.read();
      if (valueB != oldValueB && valueB == 0) {
        send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
      oldValueB = valueB;
      if (message.isAck()) {
        // Change relay state
        //  state = message.getBool();
        //  digitalWrite(message.sensor+4, state?RELAY_ON:RELAY_OFF);
        //digitalWrite(RELAY_PIN, state?RELAY_ON:RELAY_OFF);
        // Store state in eeprom
        // saveState(CHILD_ID, state);
        if (message.sender == 0){
        switch (message.sensor) {
          case 1:
            stateA = message.getBool();
            digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
            break;
          case 2:
            stateB = message.getBool();
            digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
            break;
          default:
            Serial.print("Incoming sensor unknown");
        else  {
           case 1:
           // wait (500);
            send(msgA.set(stateA ? true : false));
            break;
          case 2:
           // wait (500) ;
            send(msgB.set(stateB ? true : false));
            break;
          default:
        // Write some debug info
        Serial.println(message.sensor);
        Serial.print("from node:");
        Serial.println(message.sender);
    The Remote
       Node to Node relay control V1.0
    //#define MY_NODE_ID 210
    const int sensorId = 1;               // Id number of the sensor to send to
    const int nodeId = 7;                 //Id number of the node to send to
    const int ledpinTx = 5;                // use pin 5 to turn on led when transmitting
    const int onPush = 6;                // the input pin where the on pushbutton is connected
    const int offPush = 7;               // the input pin where the off pushbutton is connected
    int statOn ;                      // statOn will be used to store the state of  input pin 6 (is the on button pressed)
    int statOff ;                     // statOff will be used to store the state of  input pin 7 (is the off button pressed)
      pinMode(onPush, INPUT);           // configure pin 6 as an input
      pinMode(offPush, INPUT);          // configure pin 7 as an input
      pinMode(ledpinTx, OUTPUT);                 // configure pin 5 as an output
      statOn = digitalRead(onPush);                               // read input status for on button
      statOff = digitalRead(offPush);                             // read input status for off button
      if (statOn == HIGH && statOff == LOW) {                     // check that only one button is being pushed
        send(MyMessage(1, V_STATUS).setSensor(sensorId).setDestination(nodeId).set(true));  //send message to relay node to turn on
        digitalWrite(ledpinTx, HIGH);                               //turn on transmit LED
        wait (1000);                                              // delay so led can be seen
        digitalWrite(ledpinTx, LOW);                                //Turn off transmit LED
      if (statOff == HIGH && statOn == LOW) {                      // check that only one  button is being pushed
        send(MyMessage(1, V_STATUS).setSensor(sensorId).setDestination(nodeId).set(false));  // send message to relay node to turn off
      wait (2000);  // 2 second delay, time to get finger off button before program loops around
  • Hero Member
    Progressed a bit further this weekend. have changed the remote a little and now only have two buttons and one led. The revised sketch is now shown above. The new circuit uses a 9v battery (because i have lots of these) and uses a voltage divider on inputs 6 and 7 to bring it down to around 5v
    Circuit for the remote
  • Hero Member
    I Have another update for this project.
    ***WARNING THIS PROJECT USES MAINS POWER AND SHOULD NOT BE ATTEMPTED BY ANYONE WHO IS NOT QUALIFIED TO DO SO.
    IT IS ILLEGAL IN MANY COUNTRIES FOR UN-QUALIFIED PERSONS TO WORK ON MAINS EQUIPMENT ****
    The power controller node is based on the MySensors relay with button actuator sketch. I am using solid state relays to control the AC mains, these should give good isolation via their optical isolators.
    Two momentary push buttons are used to toggle the SSR’s locally. This can be handy if this node is the closest control point at the time. They are simply connected between GND and pins 3 and 4.
    Both SSR’s can also be optionally set to turn off after a pre-set time has elapsed. The main use I have for this control is for a 240v pump attached to a water tank which is located away from the house. Sometimes in the past this pump has been left on accidentally and if the hose were to burst it would drain the tank before it was noticed.
    At first I was simply going to use a LUA script in Domoticz to set a timer but if for some reason my server was to go down then the turn off may not be sent. So I decided to incorporate the timer into the node so that it will be a more reliable failsafe.
    At this time I have not connected the SSR's to the mains (still waiting on the enclosure) but it all seems to be working ok
    On the Bench
    Current Sketch
       DESCRIPTION
       switching nodes
       It also has a built in timer for the Relays. This can be used to turn off
       the relay after a set time period. Set activeTimeA or activeTimeB to the number of
       minutes the relay is to stay on for. If no timer is desired then just set them to 0
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SSR_A_ID 1   // Id of the sensor child
    #define SSR_B_ID 2   // Id of the sensor child
    int oldValueA = 0;
    int oldValueB = 0;
    int timerMarkerA = 0;
    int timerMarkerB = 0;
    unsigned long startMillisA = 0;            // holder for the time when relay first turns on
    unsigned long startMillisB = 0;            // holder for the time when relay first turns on
    unsigned long millisNow = 0;              // holder for the current time
    unsigned long activeTimeA = 1;           // Time the realy will stay active in minutes. change this to suit your situation (use 0 to dissable timer)
    unsigned long activeTimeB = 0;           // Time the realy will stay active in minutes. change this to suit your situation (use 0 to dissable timer)
    MyMessage msgA(SSR_A_ID, V_STATUS);
    MyMessage msgB(SSR_B_ID, V_STATUS);
      pinMode(buttonPinA, INPUT_PULLUP); // Setup the button pin, Activate internal pull-up
      pinMode(buttonPinB, INPUT_PULLUP); // Setup the button pin, Activate internal pull-up
      sendSketchInfo("Mains Controller", "1.1");
      present(SSR_A_ID, S_LIGHT);
      present(SSR_B_ID, S_LIGHT);
      int valueA = debouncerA.read();       // Get the update value
      oldValueA = valueA;
      int valueB = debouncerB.read();       // Get the update value
      oldValueB = valueB;
      if (activeTimeA != 0) {                //  Call timer function if needed
        relayTimerA();
      if (activeTimeB != 0) {                //  Call timer function if needed
        relayTimerB();
    /*---------------Start of functions-----------------------*/
    void relayTimerA() {
      millisNow = millis();           // get the current time
         Check relayPinA status and start timer event if relay is on.
              PORTD is used for digital pins 0 to 7
      if ((bitRead(PORTD, relayPinA)) == RELAY_ON && timerMarkerA == 0 ) {
        timerMarkerA = 1;
        startMillisA = millisNow;
      if (timerMarkerA == 1 && (millisNow - startMillisA) > (activeTimeA*60000)) {   // check to see if timeout has been reached
        digitalWrite(relayPinA, RELAY_OFF);                             // turn off relay A
        send(msgA.set(false));                                         // send message to controller so it knows the relay is now off
        timerMarkerA = 0;                                                 //reset marker
      if ((bitRead(PORTD, relayPinA)) == RELAY_OFF && timerMarkerA == 1 ) {        //if  relay A has been turned off  cancell timer event
        timerMarkerA = 0;
    void relayTimerB() {
         Check relayPinB status and start timer event if relay is on.
      if ((bitRead(PORTD, relayPinB)) == RELAY_ON && timerMarkerB == 0 ) { //Check relayPinB status and start timer event if relay is on. (As this pin is set to output we can't use digitalRead to get status, so must read the port instead)
        timerMarkerB = 1;
        startMillisB = millisNow;
      if (timerMarkerB == 1 && (millisNow - startMillisB) > (activeTimeB*60000)) {   // check to see if timeout has been reached
        digitalWrite(relayPinB, RELAY_OFF);                             // turn off relay B
        send(msgB.set(false));                                        // send message to controller so it knows the relay is now off
        timerMarkerB = 0;                                                 //reset marker
      if ((bitRead(PORTD, relayPinB)) == RELAY_OFF && timerMarkerB == 1 ) {        //if  relay A has been turned off  cancell timer event
        timerMarkerB = 0;
       if (message.sender == 0) {       // this message is from gateway (node 0)
            case 1:
              break;
            case 2:
              break;
      else  {                                // message is not from gateway so must be from a remote
            case 1:
              send(msgA.set(stateA ? true : false));                // echo the message to the gateway so controller will be aware of the change
              break;
            case 2:
              send(msgB.set(stateB ? true : false));               // echo the message to the gateway so controller will be aware of the change
              break;
        #ifdef MY_DEBUG
    Wiring diagram
  • Hero Member
    Got a working device under test now, will see how it goes switching lights and give it a try on the pump when I get time. I still have some changes i want to make on the sketch but it is working as expected at this time.
    I had trouble finding a suitable case at a reasonable price for this project. The SSR's are around 80mm high once they are mounted on their heat sinks so I needed a fairly deep box. In the end I just used an old PC power supply case which has worked out ok. Although the node will be outside it will be located in the pump shed so will not be directly affected by the weather. I may need to add flyscreen to prevent insects from getting in.
    The completed power control node
    The inner workings. you can see the two buttons used to toggle the relays on and off. Channel 1 is switched by the orange button and channel 2 by the green.
    Even though there was room inside the box for the arduino I decided to mount it on the outside. This has several advantages, this being a metal case it would of had a drastic affect on the range if mounted inside. It will hopefully be less affected by the noise form the AC mains and it will mean I can upload sketch updates without being exposed to the mains voltages inside.
    I have used the easy pcb from @sundberg84 I just had to cut off the aux part to get it to fit. I used hot glue to hold the board in place.
    I will be testing with lights for a start to make sure it is reliable, then on to other things. The SSR's I have used are zero switching and from what I have read random switching would be a better choice for inductive loads. I already had these so will see how they go, if they prove problematic I will get some random switching and try them.
    I have also completed the first remote node. The design is working well and with the infrequent use these remotes get I will be expecting to get close to the shelf life of the battery between battery changes. Well worth the minor inconvenience of a few seconds wait for it to boot and send the message.
  • Hero Member
    I now have this device connected to the water pump and it is working ok. The pump has turned on and off without fault while in use. The SSR's are running nice and cool as well so all seems to be correct. I did notice while testing that cfl bulbs would not turn completely off due to a small power bleed across the triac.
    From what I have read this would seem to be normal and can be overcome by additional circuitry but they are working for the intended use. If you were to use this sketch/circuit for cfl's or very low powered items it may be best to just use standard relay modules instead.
    The final sketch is shown bellow , The only change has been to the timing part of the sketch. I have now included the ability to turn the timers on and off from Domoticz or whatever controller you are using. The state of the timer switches is now also stored in eeprom so it is reloaded if the node is power cycled.
    The remote sketch remains as the one shown in the first post, it also is functioning as intended.
       DESCRIPTION
       switching nodes
       Timers can also be enabled/disabled by switches in your home automation controller.
    //#define MY_DEBUG
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define SSR_A_ID 1            // Id of relay A
    #define SSR_B_ID 2            // Id of relay B
    #define TIMER_A_ID 3          // Id of timers switch A
    #define TIMER_B_ID 4          // Id of timers switch B
    const int buttonPinA = 3;     //on/off button for relay A
    const int buttonPinB = 4;     //on/off button for relay B
    const int relayPinA = 5;      // SSR_A connected here
    const int relayPinB = 6;      // SSR_B connected here
    int oldValueA = 0;
    int oldValueB = 0;
    int timerMarkerA = 0;        // Used to tell if timer A is active
    int timerMarkerB = 0;        // Used to tell if timer B is active
    bool timerStateA = false;
    bool timerStateB = false;
    unsigned long activeTimeA = 60;           // Time the relay will stay active in minutes. change this to suit your situation (use 0 to dissable timer)
    unsigned long activeTimeB = 60;           // Time the relay will stay active in minutes. change this to suit your situation (use 0 to dissable timer)
      // Set timers to last known state (using eeprom storage)
      timerStateA = loadState(TIMER_A_ID);
      timerStateB = loadState(TIMER_B_ID);
      sendSketchInfo("Mains Controller", "1.2");
      present(SSR_A_ID, S_LIGHT,"Relay A");
      present(SSR_B_ID, S_LIGHT,"Relay B");
      present(TIMER_A_ID, S_BINARY,"Timer Switch A");
      present(TIMER_B_ID, S_BINARY,"Timer Switch B");
      oldValueA = valueA;
      oldValueB = valueB;
    if (timerStateA == true and activeTimeA != 0){          //check if timer A is enabled
        relayTimerA();                                     // call timer A function
    if (timerStateB == true and activeTimeB != 0){         //check if timer B is enabled
        relayTimerB();                                     // call timer B function
        timerMarkerA = 1;
        timerMarkerA = 0;
        timerMarkerB = 1;
        timerMarkerB = 0;
       if (message.sender == 0) {                                        // check if message is from gateway (node 0)
            case 1:                                                      //incoming message is for relay A
              break;
            case 2:                                                      //incoming message is for relay B
              break;
           case 3:                                                       //incoming message is from relay A timer switch
              timerStateA = message.getBool();
              if (timerStateA == false){
              timerMarkerA = 0;
              saveState(TIMER_A_ID, timerStateA);                       // Store timer state in eeprom
              break;
            case 4:                                                     //incoming message is from relay B timer switch
              timerStateB = message.getBool();
              if (timerStateB == false){
              timerMarkerB = 0;
              saveState(TIMER_B_ID, timerStateB);                       // Store timer state in eeprom
              break;
              break;
              break;
        #ifdef MY_DEBUG
        Serial.print(" New status: ");
  • I have a project in mind that I think is similar to yours. Essentially I would have one main unit that issues commands to numerous slaves. Your code is a bit confusing to me. I'm just wanting to make sure I am understanding it correctly. You basically have two pieces to this right? A remote control and then the pumps receiver right? So for all intensive purposes your controller is also your gateway. Are you able to communicate to say 20 other pumps using this same controller?
  • Hero Member
    Essentially yes the two nodes in this project are the remote and the pump control. Of course I still also have a MySensors gateway that is connected to my controller which is Domiticz .
    Just to clear up the terminology, in MySensors
    Controller is used to describe the (Home Automation) software that you can use to interact with your nodes.
    Gateway is the device you build which is the bridge between your controller and your nodes. A gateway can also contain sensors
    Nodes are the modules you build that contain the sensors/Actuators
    Yes that would certainly be possible. You could do that in a number of ways depending on where the "pumps" were located.
    If all the pumps were in the same spot you would just need to construct one Node and it could contain the 20 actuators used to control the pumps.
    If the pumps are widely dispersed then you may need to build a node for each pump, you could still combine some on the same node if they were close together and able to be linked by wire.
    Each Node has its own address on the network and every sensor/actuator on that node has its own identifier as well. It is that information we can use to interact and control.
    For example in this project my pump control node has two actuators that I have assigned the Id's of 1 and 2. This node has an address of 7 on the network, this address was assigned by the controller (Domoticz) but you can also assign the id manually in code if you like.
    So my remote node uses this information to control the actuators on the pump control node. The code that does this is shown in the line below. The variable nodeId holds the address of the destination node and the variable sensorId holds the ID of the actuator on that node to be changed.
    You would just need to use the addresses of your nodes and actuators
    If you are going to use the MySensors network for you project you may still need to have a gateway and controller.
    Having a controller could open up other possible methods you could use to control the "pumps" such as timed events or control via the internet. Many controllers also have apps for phones etc. that will allow your phone or tablet to switch the "pumps"
  • Hero Member
    I have updated the controller so it will boot up and can be locally switched even if no gateway is found. I have cleaned up the code a little bit as well. Now running on V2.1.1
       DESCRIPTION
       switching nodes
    #define MY_TRANSPORT_WAIT_READY_MS 3000     //set how long to wait for transport ready.
    #define MY_RF24_CHANNEL 84
    #define RELAY_ON 1
    #define RELAY_OFF 0
    int oldValueA = 0;
    int oldValueB = 0;
    unsigned long heartbeatDelay = 120;       // how often the heartbeat will be sent, in minutes
    unsigned long lastHeartbeat = millis();    // holder for last time heartbeat was sent
     // set relay pins in output mode
      sendSketchInfo("Mains Controller", "1.4");
      present(SSR_A_ID, S_BINARY,"Relay A");
      present(SSR_B_ID, S_BINARY,"Relay B");
        stateA =  !stateA;                                          // Toggle the state
        send(msgA.set(stateA), false);                                // send new state to controller, no ack requested
        digitalWrite(relayPinA, stateA ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
      oldValueA = valueA;
       stateB =  !stateB;                                          // Toggle the state
        send(msgB.set(stateB), false);                                // send new state to controller, no ack requested
        digitalWrite(relayPinB, stateA ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
      oldValueB = valueB;
    heartbeatCheck();                                    // call heartbeat function
    void heartbeatCheck(){
    if ((millisNow - lastHeartbeat) > (heartbeatDelay*60000)) {
      sendHeartbeat();
      #ifdef MY_DEBUG
        Serial.println("Heartbeat Sent" );
      if (digitalRead(relayPinA) == RELAY_ON && timerMarkerA == 0 ) {        //Check relayPinA status and start timer event if relay is on.
        timerMarkerA = 1;
        if (digitalRead(relayPinA) == RELAY_OFF && timerMarkerA == 1 ) {    //if  relay A has been turned off  cancel timer event
        timerMarkerA = 0;
        if (digitalRead(relayPinB) == RELAY_ON && timerMarkerB == 0 ) {      // Check relayPinB status and start timer event if relay is on.
        timerMarkerB = 1;
      if (digitalRead(relayPinB) == RELAY_OFF && timerMarkerB == 1 ) {     //if  relay B has been turned off  cancel timer event
        timerMarkerB = 0;
        Serial.println("timer B cancelled" );
              break;
              digitalWrite(relayPinB, stateB ? RELAY_ON : RELAY_OFF);
              break;
              timerMarkerA = 0;
              break;
              timerMarkerB = 0;
              break;
              break;
              break;
        #ifdef MY_DEBUG
  • Hardware Contributor
    I use a similar design for a wireless door bell. To not be forced to push the button while the node is booting, I charge a large capacitor when a button is pressed.
  • 8
  • 1
  • 29
  • 90
  • 1
20
11.3k
