processing incoming MQTT messages to actuate gateway local relay / variable.
  • I've seen the relay sketch which has a receive function but that is for Radio Nodes, i was wondering about processing arrived MQTT messages to the MQTTClient gateway so it changes a variable / acts on a relay.
    is there any way to do that ? is it using the receive function as well ?
    note: i've already defines a message that has the V_type and CHILD_ID matching, i've got the message on the gateway console, i was wondering to get it into a variable.
  • @Meshx86 i figured out the problem which i believe it is a bug, you can't have in your incoming MQTT prefix "/" or "-" in the path, otherwise the message won't be parsed properly
  • by hek:
    This PR was merged a few days ago:
    https://github.com/mysensors/MySensors/pull/633
  • 8
  • 42
  • 6
  • 4
  • 11
  • 4
