Sonoff + MySensors mqtt gateway + Home-Assistant
  • Edit: This information is now maintained here and now includes both ethernet and mqtt gateway examples.
    I just got my hands on a Sonoff wifi switch and have adapted the MySensors mqtt gateway example to work work with the Sonoff relay and Home Assistant
    I have not used it with 220V yet but its tested as you can see.
    At start up the LED will blink twice once the presentation is done and then start in the off state.
    The button will toggle on off and send the state back to the gateway.
    The gateway can also send state to the Sonoff.
    If you have multiple Sonoff's they can all use the same mqtt topic as long as they don't have the same child id.
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
     * Sonoff specific details (IM15116002)
     * The sonoff header left to right, relay above, LED below.
     *  [1]  vcc 3v3
     *   2   rx
     *   3   tx
     *   4   gnd
     *   5
     * In arduinoIDE 1.6.* choose Generic ESP8226 module.
     * Hold Sonoff button when attaching FTDI to flash.
    #define MY_BAUD_RATE 9600
    // No radio in Sonoff
    //#define MY_RADIO_NRF24
    #define MY_GATEWAY_ESP8266
    #define MY_MQTT_PUBLISH_TOPIC_PREFIX "sonoff-out"
    #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "sonoff-in"
    // Set MQTT client id
    #define MY_MQTT_CLIENT_ID "mysensors-sonoff-1"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "SSiD"
    #define MY_ESP8266_PASSWORD "password"
    #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway-sonoff-1"
    #define MY_IP_GATEWAY_ADDRESS 192,168,0,1
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 100
    #define MY_PORT 1883
    // Not tested for Sonoff
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <ESP8266WiFi.h>
    #include <Bounce2.h>
    #define BUTTON_PIN 0  // Sonoff pin number for button
    #define RELAY_PIN 12  // Sonoff pin number for relay
    #define LED_PIN 13    // Sonoff pin number for LED
    #define RELAY_ON 1
    #define RELAY_OFF 0
    #define LED_ON 0
    #define LED_OFF 1
    // Id of the sensor child
    // Set unique id for each sonoff if sub/pub on same mqtt topic
    #define CHILD_ID 0
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool state = false;
    MyMessage msg(CHILD_ID,V_STATUS);
      // Setup the button
      pinMode(BUTTON_PIN, INPUT_PULLUP);
      debouncer.attach(BUTTON_PIN);
      debouncer.interval(5);
      // Make sure relays and LED are off when starting up
      digitalWrite(LED_PIN, LED_OFF);
      pinMode(RELAY_PIN, OUTPUT);
      pinMode(LED_PIN, OUTPUT);
    void presentation()  {
      // Send the sketch version information
      sendSketchInfo("Sonoff", "1.0");
      // Register sensor
      present(CHILD_ID, S_BINARY);
      // Send the current state
      send(msg.set(state?true:false));
      // Blink when ready
      blink();
      debouncer.update();
      // Get the update value
      int value = debouncer.read();
      if (value != oldValue && value==0) {
        // Toggle the state
        state = state?false:true;
        // Change relay state
        // Change LED state
        digitalWrite(LED_PIN, state?LED_ON:LED_OFF);
        // Send new state
        send(msg.set(state));
      oldValue = value;
      // We only react on status messages from the controller
      // to this CHILD_ID.
      if (message.type==V_STATUS  && message.sensor==CHILD_ID) {
        // Only switch if the state is new
        if (message.getBool() != state) {
          state = message.getBool();
          // Change LED state
    void blink()
      digitalWrite(LED_PIN, digitalRead(LED_PIN)?LED_ON:LED_OFF);
      wait(200);
      wait(200);
      wait(200);
    The HASS config is not much. Using the persistence file will make HASS restore the desired state if the Sonoff loses power etc.
    mysensors:
      gateways:
        - device: mqtt
          persistence_file: '/home/homeassistant/.homeassistant/sonoff.json'
          topic_in_prefix: 'sonoff-out'
          topic_out_prefix: 'sonoff-in'
      debug: false
      optimistic: false
      persistence: true
      retain: true
      version: 2.0
  • Admin
    Great! Could your perhaps add this project to openhardware.io? It would fit nicely into the build-section on the main site.
  • @hek Yes, just have to figure out how 😃
  • Might be helpful for somebody... Things configuration for OpenHab2:
    Bridge mysensors:bridge-eth:gateway_2 [ ipAddress="192.168.178.50", tcpPort=5003, sendDelay=200, enableNetworkSanCheck=true ] {
            /** define things connected to that bridge here */
            light sonoff01 [ nodeId="0", childId="0", requestAck=true ]
  • 42
  • 7
  • 53
  • 12
  • 15
18
