  3. Battery Level Measurement
arduinobattery
11 Posts 3 Posters 13.9k Views 1 Watching
  • funky81F
    funky81F
    funky81
    Hi Guys,
    Need your advice for arduino battery level measurement.
    The goal is that I want to monitor my battery consumption so I can get notice for battery replacement if it's already low.
    This is my setup. is it correct already? I'm using this link as reference.
    m26872M 1 Reply Last reply
    • tbowmoT
      tbowmoT
      tbowmo
      Do you want to power it directly with battery connected to VCC of the atmega? Then it's possible to measure the battery voltage without any external components.
      http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
      funky81F 1 Reply Last reply
      • funky81F funky81
        Hi Guys,
        m26872M
        m26872M
        m26872
        @funky81 The wiring priciple is correct but you have to think of the components. Try six 1,5V cells in series, use R1=5Mohm (=two 10Mohm in parallell) and R2=680kohm and preferably a 0.1uF capacitor in parallell with R2. And some of the code below.
        One (major) drawback with the "secret external-component-less" method from @tbowmo is the Vcc becomes unregulated and it will be more difficult to use and interact with other things like sensors.
        /* BATTERY METER
          Internal_ref=1.1V, res=10bit=2^10-1=1023,
          Some different 1.5V cell (I use AAs) configurations and some suggested corresponding resistor value relations:
          2AA: Vin/Vbat=470e3/(1e6+470e3), 3AA: Vin/Vbat=680e3/(2.5e6+680e3), 4AA: Vin/Vbat=1e6/(1e6+5e6), 5-6AA: Vin/Vbat=680e3/(5e6+680e3), 6-8AA: Vin/Vbat=1e6/(1e6+10e6)
          Example with 6AAs and R1=5Mohm (=two 10Mohm in parallell) and R2=680kohm:
          Vlim = 1.1*Vbat/Vin = 9.188235 V (Set eventually to Vmax)
                                  (9.2V = 1.53V/cell which is a little low for a fresh cell but let's say it's ok to stay at 100% for the first period of time)
          Volts per bit = Vlim/1023 = 0.008982
          Vmin = 6V (Min input voltage to regulator according to datasheet. Or guess Vout+1V )   DEFINE
          Vmax = 9.188235V (Known or desired voltage of full batteries. If not, set to Vlim.)  DEFINE
          Vpercent = 100*(Vbat-Vmin)/(Vmax-Vmin)
          // some code
        #define VMIN 6.0 // (Min input voltage to regulator according to datasheet or guessing. (?) )
        #define VMAX 9.188235 // (Known or desired voltage of full batteries. If not, set to Vlim.)
          // some code
        int oldBatteryPcnt = 0;
          // some code
          analogReference(INTERNAL);    // use the 1.1 V internal reference for battery level measuring
          // some code
            // some code
          int sensorValue = analogRead(BATTERY_SENSE_PIN);    // Battery monitoring reading
        //  Serial.println(sensorValue);
          float Vbat  = sensorValue * 0.008982;
        //  Serial.print("Battery Voltage: "); Serial.print(Vbat); Serial.println(" V");
         //int batteryPcnt = sensorValue / 10;
          int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
        //  Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
            oldBatteryPcnt = batteryPcnt;
          // some code
        • tbowmoT
          tbowmoT
          tbowmo
          @m26872
          It highly depends on what sensors you want to use.
          If you want to go battery powered, you really should invest some time in finding the right sensors that can be used at low voltages.
          • m26872M
            m26872M
            m26872
            @tbowmo I agree.
            ... and something else than an Uno. Given that it actually is an Uno, I expect we're not really in to specialized sensors yet.
            And, sometimes opinions are not as helpful when we don't know the specification or application.
            • tbowmoT tbowmo
              funky81F
              funky81F
              funky81
              @tbowmo right now, the battery will be connected only to vin, coz it raw.
              my step up power converter (in this link) havent arrived yet. So i will use vin only.
              if it stable enough I will connect battery => step up power converter => vcc
              then i will use the link that you provide before
              is my theory correct?
              • m26872M m26872
                /* BATTERY METER
                  // some code
                  // some code
                  // some code
                  // some code
                    // some code
                  // some code
                funky81F
                funky81F
                funky81
                @m26872 right now, i dont have any plans to use more than 2 batteries in series.
                but if i do, i will use step up power converter to stable it.
                but ofcourse this is my theory. am I correct ?
                • tbowmoT
                  tbowmoT
                  tbowmo
                  @funky81
                  If you use a step-up converter, then you need to use the design you made in first post.
                  My method can only be used if you don't have any voltage regulators etc. between the battery and the atmel chip (f.ex. something like http://forum.mysensors.org/topic/510/minimal-design-thoughts, which do not use any regulators, and the battery is connected directly to the atmel.
                  • funky81F funky81
                    m26872M
                    m26872M
                    m26872
                    @funky81 I'm confused. Are you trying to use a 3.3v step-up to an 5V Uno?
                    One or two 1.5V cells works great with a 3V-step-up setup like to power a 3V Arduino Pro Mini to Vcc as I do myself here BUT you can NOT supply a 5V-configuration.
                    • m26872M m26872
                      funky81F
                      funky81F
                      funky81
                      I'm sorry to make you confused. Currently I'm using 3.3v arduino pro mini.
                      What I mean is not step up converter, but step up power converter (http://goo.gl/PFt99R) => to stablize 3.3v to maintain a steady 3.3 VDC even as the battery capacity diminishes. (like in this page http://www.mysensors.org/build/battery)
                      Hmm..after I read your post (http://forum.mysensors.org/topic/486/my-2aa-battery-sensor/4), it seems I have the same goal like you. I'll asked few thing in your thread, if that's okay with you :)
                      • tbowmoT tbowmo
                        @funky81
                        funky81F
                        funky81F
                        funky81
                        wrote on last edited by funky81
                        Hi @tbowmo, do you mind to explain a bit about the design? I'm interested with your design.
                        I will use these steps for removing voltage regulator, http://goo.gl/CsZaNg
                        So the design will be battery > external step up regulator (http://goo.gl/PFt99R - to stabilize 3.3v) > vcc pin ?
                        with these then I can use my first post design?
