Can't compile serial gateway example, MySigningNone.h not found
  • I'm a newbie at MySensors; haven't yet got a gateway or node running. I bought a SenseBender gateway board and want get it working. I'm trying to compile the serial gateway example found at https://codebender.cc/sketch:47514#SerialGateway.ino. I chose this file because it seems to have complete working code for a gateway, as opposed to MySensors\examples\GatewaySerial\GatewaySerial.ino, in which setup(), presentation() and loop() are all empty, therefore I figure it isn't a complete example and won't do anything, and being a newbie I don't know how to fill in those parts.
     * The ArduinoGateway prints data received from sensors on the serial link.
     * The gateway accepts input on seral which will be sent out on radio network.
     * The GW code is designed for Arduino Nano 328p / 16MHz
     * Wire connections (OPTIONAL):
     * - Inclusion button should be connected between digital pin 3 and GND
     * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
     * LEDs (OPTIONAL):
    #define NO_PORTB_PINCHANGES
    #include <MySigningNone.h>
    #include <MyTransportRFM69.h>
    #include <MyTransportNRF24.h>
    //#include <MyHwATMega328.h>
    #include <MySigningAtsha204Soft.h>
    #include <MySigningAtsha204.h>
    #include <MyParserSerial.h>
    #include <stdarg.h>
    #include <PinChangeInt.h>
    #include "GatewayUtil.h"
    #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
    #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
    #define RADIO_ERROR_LED_PIN 4  // Error led pin
    #define RADIO_RX_LED_PIN    6  // Receive led pin
    #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
    MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    //MyTransportRFM69 transport;
    // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
    //MySigningNone signer;
    //MySigningAtsha204Soft signer;
    //MySigningAtsha204 signer;
    // Hardware profile
    MyHwATMega328 hw;
    // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
    // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
    #ifdef WITH_LEDS_BLINKING
    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    #else
    MySensor gw(transport, hw /*, signer*/);
    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
    int inputPos = 0;
    boolean commandComplete = false;  // whether the string is complete
    void parseAndSend(char *commandBuffer);
    void output(const char *fmt, ... ) {
       va_list args;
       va_start (args, fmt );
       vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
       va_end (args);
       Serial.print(serialBuffer);
      gw.begin(incomingMessage, 0, true, 0);
      setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
      // Add interrupt for inclusion button to pin
      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
      // Send startup log message on serial
      serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
      gw.process();
      checkButtonTriggeredInclusion();
      checkInclusionFinished();
      if (commandComplete) {
        // A command wass issued from serial interface
        // We will now try to send it to the actuator
        parseAndSend(gw, inputString);
        inputPos = 0;
      SerialEvent occurs whenever a new data comes in the
     hardware serial RX.  This routine is run between each
     time loop() runs, so using delay inside loop can delay
     response.  Multiple bytes of data may be available.
    void serialEvent() {
      while (Serial.available()) {
        // get the new byte:
        char inChar = (char)Serial.read();
        // if the incoming character is a newline, set a flag
        // so the main loop can do something about it:
        if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
          if (inChar == '\n') {
            inputString[inputPos] = 0;
            commandComplete = true;
          } else {
            // add it to the inputString:
            inputString[inputPos] = inChar;
            inputPos++;
        } else {
           // Incoming message too long. Throw away
            inputPos = 0;
    I did a complete fresh install of Arduino 1.8.3, then used library manager to install MySensors 2.1.1. I see that Arduino put the library in My Documents\Arduino\libraries, with all the .h and .cpp files in \cores.
    When I try to compile, I get MySigningNone.h not found. I found it on the web and put it in \cores, but that didn't help - still not found. If I comment out MySigningNone.h, other of the .h files are found either, e.g. MyTransportRFM69.h.
    So, I don't understand why the files aren't found if I put them in \cores. Where should they go? Why aren't they included in the distribution?
    Does anyone have an example of complete code for a simple working serial gateway and a simple node? I'd like to first try a node that has a temp & humidity sensor on it.
    I admit I'm finding it frustrating to get started with MySensors, though I think it will be great once I get it working.
  • Hi Bill,
    Welcome to MySensors!
    Instead of using the library manager, you could try to copy the complete MySensors folder to Arduino\libraries. (don't forget to restart the Arduino IDE afterwards)
    The MySensors folder also contains an examples folder that contains different codes for gateway and sensor nodes that you should be able to compile without any problems.
  • Mod
    @billgoolsby you are trying to compile a MySensors 1.x sketch with MySensors 2. That won't work. Follow the instructions on https://www.mysensors.org/hardware/sensebender-gateway instead.
  • SensebenderGatewaySerial.ino has empty functions for setup(), presentation() and loop(). How can it possibly work with no code in these?
  • Mod
    @billgoolsby because the MySensors library does what it is supposed to do 🙂
    Why would we ask you to use broken code?
  • So the library is entirely interrupt-driven? Is there a document describing the library's architecture and design intent?
  • Mod
    @billgoolsby the gateway could probably be called event-driven but that's not why there is no need for additional code.
    The concepts are described in the getting started guide, which starts at https://www.mysensors.org/about
  • 14
  • 5
  • 9
  • 9
  • 4
  • 72
