  3. EthernetGateway hangs after "Gateway startup complete"
hangethernetgatewaywiz5100arduino uno r3
2 Posts 1 Posters 2.2k Views 1 Watching
  • HeinzH Offline
    HeinzH Offline
    Heinz
    wrote on last edited by Heinz
    I spent some hours to get my EthernetGateway running on the following configuration:
    • SainSmart Arduino Uno R3
    • SainSmart EthernetShield (5100)
    • EthernetGateway.ino
      I followed the steps in the documentation and luckily received the message: "Gateway startup complete"
      BUT then I noticed that I could not ping the gateway.
    After adding some "Serial.println"-calls in the setup() routine I discovered that the arduino did not return from the
    gw.begin(...); call. Having a look at the implementation made me a bit curious.
    setup() does the following:
    1. gw.begin
    2. Ethernet.begin
    3. server.begin
    gw.begin accepts a callback "writeEthernet" which is implemented as follows:
    void writeEthernet(char *writeBuffer) {
    server.write(writeBuffer);
    This callback is called before server.begin is called. So server.write gets called before server.begin!
    To avoid calling server.write before server.begin was called I introduced a bool which is set to true at the end of setup() and used this
    in the following way:
    if (serverUp)
    Now my EthernetGateway runs fine, with this workaround.
    Is this a bug in the code?
    Could anyone provide some help to find out why the arduino hangs when server.write is called before server.begin?
    • HeinzH Offline
      HeinzH Offline
      Heinz
      I think it is the same problem as in...
      http://forum.mysensors.org/topic/737/uno-w5100-shield-not-pinging
      12.1k
