  3. PhoneyTV for Vera is Here!
34 Posts 6 Posters 31.8k Views 3 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    So here is a fun project for you to build... introducing PhoneyTV for Vera.
    PhoneyTV is a Home Automation connected security device that mimics the ambient light produced by a television. This makes your house appear to be occupied and will hopefully deter would-be robbers from trying to enter your house.
    Some highlights:
    • Utilizes the MySensors basic sketch for relays, therefore controllable by Vera.
      Energy efficient versus actually leaving a TV on. My 12x 1/2watt LEDs are burning average of about 5 watts with the PWM... a nightlight basically.
      It I can be BRIGHT with 12 10mm LED's produces the light of a 50in LCD TV, in my observation.
      Utilizes 6 channels featuring 3 PWM pins in order to vary the intensity of blues and whites.
      Uses no Delays, rather it uses a timer to produce its random flickering while maintaining terrific radio connection.
      Is customizable to allow you to adjust your PhoneyTV to behave to your specific preferences.
      Is EASY to make... It can be 100% powered by your Arduino and with exception of the actual LED's (I used 12pcs of 1/2watt super-bright 10mm LED's) only requires a board and a few resistors (be careful with this red LEDs).
      It can be powered with an old cell phone charger or any 7-12V power supply.
      You can create a custom, fun housing to camouflage or highlight your PhoneyTV. I repurposed a box that has been sitting on a shelf empty for a while. It is nice because when it is not in use, it can be invisible.
      You can breadboard it on your UNO in under 45 minutes and depending on your box, build in in one evening.
      It can be improved... While this produces a pretty realistic effect, nothing is preventing you from adding more to it like dimming or even multiplexing.
      It is inexpensive versus buying something like FakeTV, where after $30, you will still have to add Home Automation ready outlet if you want to control it. I used a Nano, but you could try a ProMini and save a few bucks.
      Is expandable. Why not add a Thermometer, Hygrometer or Barometer? For a few more dollars you can monitor the room you keep your Phoney TV in.
    I have attached some photos of the approach I took to build the physical box, of course there are many possibilities for you to consider and build.
    I'll post the sketch in an update...
    I want to give credit to DeltaNu1142 for the inspiration and the idea, thanks!
    photo 3-5.JPG photo 4-5.JPG photo 2-3.JPG photo 3-4.JPG photo 4-4.JPG photo 5-1.JPG photo 3-3.JPG photo 4-3.JPG photo 1-2.JPG photo 2-2.JPG photo 3-2.JPG photo 4-2.JPG
      Some highlights:
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      wrote on last edited by BulldogLowell
      The Sketch:
      PhoneyTVNew.ino
      the Schematic...
      So simple, there is no reason not to try it!
      PhoneyTVSchematic.pdf
      There is an UPDATED Version below, which adds a momentary pushbutton switch to control it locally. (software debounce)
      stofakillerS 1 Reply Last reply
      • marceltrapmanM
        marceltrapmanM
        marceltrapman
        Hi @BulldogLowell,
        This looks exactly like something I need in a a couple of weeks :)
        The pdf says 1:4 but I see only page 1.
        Fulltime Servoy Developer
        • marceltrapmanM marceltrapman
          Hi @BulldogLowell,
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @marceltrapman
          The other pages are from the schematic diagraming software for BOM, etc, but I didn't fill out the lists so they are blank pages.
          Te resistor values depend on the LED's you choose but I used these. and chose to do the diffusing cover. If you buy diffused LED's you may get better results if you use a clear or frosted diffuser/cover.
          Besides the arduino and the radio, here are the resistor values, the pinouts are in the sketch as far as the colours.
          • marceltrapmanM
            marceltrapmanM
            marceltrapman
            Really nice! Thanks....
            • H
              H
              henno
              I followed your instructions and built a PhoneyTV this weekend. Great success!
              This was the first time I used a prototype board to build something and it wasn't really that difficult. If there is some other beginner out there who's thinking about building this project, I say go for it.
              While I was at it I put a DHT22 on the board, maybe I'll substitute it for a Dallas DS18B20 to cut cost.
              • H henno
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @henno
                Good thinking on the Dallas sensor. I just ordered a few and am looking forward to adding them here and there as I build more stuff.
                And soldering isn't too bad, yeah?
                  The Sketch:
                  PhoneyTVNew.ino
                  the Schematic...
                  stofakillerS
                  stofakillerS
                  stofakiller
                  @BulldogLowell
                  Hi
                  Im a bit confused about the J1 in the schematic... It seems you dont use it or i dont understand what it is :-)
                  But how is the diodes then connected to the board?
                  Regards
                  Jan
                  • stofakillerS stofakiller
                    @BulldogLowell
                    Hi
                    Regards
                    Jan
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @stofakiller said:
                    @BulldogLowell
                    Hi
                    Regards
                    Jan
                    Jan,
                    the LEDs I used are through-hole pins; I soldered them to the board. The photo shows their respective resistors connected to them accordingly. I soldered a trace to connect all of the cathodes to ground, put the resistors in series with the anodes. PIN>>RESISTOR>>ANODE.
                    As far as the connector numbers go, use the MySensors standard radio connection and the pinouts for the LEDs detailed in the sketch. In my experience, having the Blue and White on some PWM gives a more realistic effect. The numbers don't match the Nano because I used the header component in the software I used to create the circuit diagram.
                    good luck why your build!
                      @stofakiller said:
                      @BulldogLowell
                      Hi
                      Regards
                      Jan
                      Jan,
                      stofakillerS
                      stofakillerS
                      stofakiller
                      @BulldogLowell
                      Okay, now i better understand, because in the schematics the J1 is connected to pin 3 and i didnt get it to work, but also the D1 you use is Blue, but in the sketch the first one you use is white ;-) So now i got the 6 diodes connected, what about the other 6? :-) are the connected parallel? (whites, red greens etc)
                      Regards Jan
                        @BulldogLowell
                        Regards Jan
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        @stofakiller said:
                        @BulldogLowell
                        Regards Jan
                        Sorry about the schematic, I actually recall thinking that would come back to haunt me. I'll fix it to make it easier for the next guy :)
                        Yes, I put two LEDs on each 'channel' wired in parallel. This way, you can power all 12 LEDs with the arduino, no problem.
                        Six channels with two LEDs each.
                        Blue1
                        Blue2
                        White1
                        White2
                        Red
                        Green
                        I arranged them in this 4 x 3 matrix attached and used more space between the rows for a square-ish (that isn't a real word!) arrangement.
                        FYI, I'll probably get to adding a pushbutton to turn it on/off. I'll post that if I can get to it.
                        I also wanted to look at using SoftPWM.h and move some LEDs to the analogue side for even more variation in brightness.
                        Finally, I want random go-dark dips (turning all LEDs off for a moment) and I didn't want to do it using delays, I will get that in there too.
                        • BulldogLowellB
                          BulldogLowellB
                          BulldogLowell
                          I have an updated version attached to:
                          Add a pushbutton to control it locally (I am using an interrupt on Digital Pin 2, which is not in use presently, so you can disconnect your radio connection to pin 2)
                          Improved the dark dips of light, again trying to make it even more realistic.
                          cleaned up the code to make it (a lot) simpler; I eliminated the generic relay 'stuff' and made is single use, basically.
                          Now you can leave it plugged in and turn it off if you are occupying the room... and no longer have to worry about plugging it back in :)
                          PhoneyTV_V2.ino
                          • BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            Completed upgrade to version 1.4, removing Relay capability.
                            PhoneyTV update attached:
                            PhoneyTV_V3.1_MySensors_V1.4.1.ino
                            • 5546dug5
                              5546dug5
                              5546dug
                              Hi @BulldogLowell
                              get work am in the middle of working the hardware
                              I cant seem to download the V2 or V3.1 versions I get the reply as is is the pic
                              • 5546dug5
                                5546dug5
                                5546dug
                                When I create this file it states only ashii characters allowed and asks meto delete the file
                                  Rename it to something shorter and try again.
                                  • 5546dug5
                                    5546dug5
                                    5546dug
                                    Once again @hek you have come to the rescue.
                                    Back to planning the phoney, I think this is a terrific app hats off to @BulldogLowell
                                    • 5546dug5
                                      5546dug5
                                      5546dug
                                      @BulldogLowell In the final stage of boxing this unit I like it and sure will use it in the coming months.
                                      Question is when it was included to vera she made the node and then created the light node for it complete with on and off buttons, are they supposed to work or ignore these and use the local interrupt on d2 but would be cool to control this remotely with vera or in a scene.
                                      Great project!
                                      • 5546dug5 5546dug
                                        Great project!
                                        BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        you will be able to turn on/off at the controller and with the (quite optional) attached button!
                                        do you need it to work just by the button, and no controller? that is an easy mod if that is your use case.
                                        • 5546dug5
                                          5546dug5
                                          5546dug
                                          @BulldogLowell , In a perfect world I would like to control Phoney TV over vera/my sensors.
                                          right now I can use RST to drop the lights for a few secs only, but that is a physical action .
                                          I did look at phoney tv 2.0 and see the pin was changed to pinbutton and declared as an output?
                                          There was a relay in this sketch, or is the vera switch node to be therelay ? I see when you push button it changes the state of the lights but I think not the power to the nano.
                                          I guessing my guesses are wrong.
                                          Enough guessing from an old guy!
