  3. Sketch for Lightning Sensor
58 Posts 14 Posters 33.0k Views 11 Watching
  • SparkmanS Offline
    SparkmanS Offline
    Sparkman
    wrote on last edited by Sparkman
    Hi all,
    Has anyone developed a MySensors sketch for the AS3935 Digital Lightning Sensor that's listed in the MySensors store? Playingwithfusion, the manufacturer of the sensor, has a sample sketch, but being new to MySensors, I need some help setting this up to send data to the MS gateway. Thanks in advance for any help.
    Cheers
    Al
    • SparkmanS Sparkman
      Hi all,
      Cheers
      Al
      BulldogLowellB Offline
      BulldogLowell
      @Sparkman said:
      Playingwithfusion
      cool sensor. Were you able to get it working with your arduino already?
      It looks like you have a few options, but you could try first getting it to work with SoftSPI.h library, and moving the MOSI, MISO and SCLK pins off of the MySensors Hardware SPI pins. Alternatively, you could try to implement using I2C, but I didn't see an example (maybe the manufacturer can provide that).
      Once you have it working with SoftSPI or I2C, it would be easy to help you get it to work with your MySensors Gateway.
      We can help you with the program, but testing would be yours to do, so try to get it working as above, and post that code.
      SparkmanS 1 Reply Last reply
        @Sparkman said:
        Playingwithfusion
        SparkmanS Offline
        SparkmanS Offline
        Sparkman
        Thanks for the response. I haven't hooked it up yet, hopefully tomorrow although not a lot of lightning this time of year where I live to test with. Is it possible to use "normal" SPI and just use a different pin for slave select for it? I was thinking about using pins 8 and 7 for the lightning sensor as to not conflict with the radio on pins 10 and 9, and using pin 3 for IRQ for the sensor versus 2 for the radio. Can both be connected to MOSI, MISO and SCLK? I was looking to use it with a Pro Mini and would need the following SPI parameters:
        SPI.begin();
        SPI.setClockDivider(SPI_CLOCK_DIV8);
        SPI.setDataMode(SPI_MODE1);
        SPI.setBitOrder(MSBFIRST);
        Do these conflict with what's needed for the radio? I guess using I2C would eliminate the conflicts, and will ask Playingwithfusion the details on how to make it work with that. I would like to learn how to get multiple devices playing together using SPI though. I'll read up on SoftSPI as well.
        Cheers
        Al
        • BulldogLowellB Offline
          BulldogLowell
          presently, MySensors (and @hek can correct me if I am wrong) is still not using interrupt on pin2, so you should be OK there.
          SPI is a hardware implementation on pins 11, 12, 13 on your Arduino. MySensors is using hardware SPI to communicate with the radio.
          SoftSpi is a software implementation of SPI and will allow you to make SPI communication to your breakout board, but must use alternate pins on your Arduino as avoid the conflict.
          You should be able to get it to work with SoftSPI or I2C.
          • SparkmanS Offline
            SparkmanS Offline
            Sparkman
            Thanks, but isn't SPI designed to allow more than one slave to be connected? From what I understand, each slave requires a separate slave select pin, but should be able to share the other pins. I'm new to this so please correct me if I'm wrong.
            Al
              Al
              BulldogLowell
              wrote on last edited by BulldogLowell
              yes, if they play well together... I've not been that lucky with Arduino. Since the breakout isn't on a shield, it may work OK.
              You can always just try it and let us know.
                SparkmanS Offline
                SparkmanS Offline
                Sparkman
                Thanks, I did not realize that. The manufacturer got back to me already (great support over a weekend) and indicated that they don't have a sample I2C sketch, so I'll likely try getting it working with SPI first.
                Cheers
                Al
                • jeylitesJ Offline
                  jeylitesJ Offline
                  jeylites
                  wrote on last edited by jeylites
                  @BulldogLowell @Sparkman
                  Hi guys, Have any of you made any developments? I was wondering, can I make changes to distance sensor sketch and use it for lighting?
                  as3935_lightning_snsr_nocal.ino
                  PWFusion_AS3935.cpp
                  PWFusion_AS3935.h
                  • jeylitesJ jeylites
                    PWFusion_AS3935.cpp
                    PWFusion_AS3935.h
                    SparkmanS Offline
                    SparkmanS Offline
                    Sparkman
                    @jeylites I haven't done much with it as I was waiting for my NRF24l01's to show up, First shipment got lost and my replacement shipment seems to be stuck in customs for far too long. I'm hoping to get back to it in a couple of weeks. I did write a sketch that compiled and loaded properly, but I haven't been able to test it due to lack of radios :-(
                    Cheers
                    Al
                    • jeylitesJ Offline
                      jeylitesJ Offline
                      jeylites
                      @Sparkman OK, hope to hear from you soon. Cheers!
                      • SparkmanS Offline
                        SparkmanS Offline
                        Sparkman
                        My radios showed up a few days ago and this is the sketch I'm using:
                        #include "MySensor.h"
                        // the sensor communicates via SPI or I2C. This example uses the SPI interface
                        #include "SPI.h"
                        // include Playing With Fusion AXS3935 libraries
                        #include "PWFusion_AS3935.h"
                        // setup CS pins used for the connection with the sensor
                        // other connections are controlled by the SPI library)
                        int8_t CS_PIN  = 8;
                        int8_t SI_PIN  = 7;
                        int8_t IRQ_PIN = 3;
                        volatile int8_t AS3935_ISR_Trig = 0;
                        // #defines
                        #define AS3935_INDOORS       1
                        #define AS3935_OUTDOORS      0
                        #define AS3935_DIST_DIS      0
                        #define AS3935_DIST_EN       1
                        #define AS3935_CAPACITANCE   96      // <-- SET THIS VALUE TO THE NUMBER LISTED ON YOUR BOARD
                        // prototypes
                        void AS3935_ISR();
                        PWF_AS3935  lightning0(CS_PIN, IRQ_PIN, SI_PIN);
                        #define CHILD_ID_DISTANCE 1
                        #define CHILD_ID_INTENSITY 2
                        MyMessage msgDist(CHILD_ID_DISTANCE, V_DISTANCE);
                        MyMessage msgInt(CHILD_ID_INTENSITY, V_VAR1);
                          gw.begin();
                          gw.sendSketchInfo("Lightning Sensor", "1.0");
                          gw.present(CHILD_ID_DISTANCE, S_DISTANCE);
                          gw.present(CHILD_ID_INTENSITY, S_CUSTOM);
                          boolean metric = gw.getConfig().isMetric;
                          Serial.begin(115200);
                          Serial.println("Playing With Fusion: AS3935 Lightning Sensor, SEN-39001");
                          Serial.println("beginning boot procedure....");
                          // setup for the the SPI library:
                          SPI.begin();                            // begin SPI
                          SPI.setClockDivider(SPI_CLOCK_DIV4);    // SPI speed to SPI_CLOCK_DIV16/1MHz (max 2MHz, NEVER 500kHz!)
                          SPI.setDataMode(SPI_MODE1);             // MAX31855 is a Mode 1 device
        //    --> clock starts low, read on rising edge
                          SPI.setBitOrder(MSBFIRST);              // data sent to chip MSb first
                          lightning0.AS3935_DefInit();                        // set registers to default
                          // now update sensor cal for your application and power up chip
                          lightning0.AS3935_ManualCal(AS3935_CAPACITANCE, AS3935_OUTDOORS, AS3935_DIST_EN);
                                          // AS3935_ManualCal Parameters:
                                          //   --> capacitance, in pF (marked on package)
                                          //   --> indoors/outdoors (AS3935_INDOORS:0 / AS3935_OUTDOORS:1)
                                          //   --> disturbers (AS3935_DIST_EN:1 / AS3935_DIST_DIS:2)
                                          // function also powers up the chip
                          // enable interrupt (hook IRQ pin to Arduino Uno/Mega interrupt input: 0 -> pin 2, 1 -> pin 3 )
                          attachInterrupt(1, AS3935_ISR, RISING);
                          lightning0.AS3935_PrintAllRegs();
                          // delay execution to allow chip to stabilize.
                          delay(1000);
                          // This program only handles an AS3935 lightning sensor. It does nothing until
                          // an interrupt is detected on the IRQ pin.
                          while(0 == AS3935_ISR_Trig){}
                          // reset interrupt flag
                          // now get interrupt source
                          uint8_t int_src = lightning0.AS3935_GetInterruptSrc();
                          if(0 == int_src)
                            Serial.println("Unknown interrupt source");
                            //gw.send(msgDist.set(999));
                            //gw.send(msgInt.set(0));
                          else if(1 == int_src)
                            uint8_t lightning_dist_km = lightning0.AS3935_GetLightningDistKm();
                            uint32_t lightning_intensity = lightning0.AS3935_GetStrikeEnergyRaw();
                            Serial.print("Lightning detected! Distance to strike: ");
                            Serial.print(lightning_dist_km);
                            Serial.println(" kilometers");
                            Serial.print("Lightning detected! Lightning Intensity: ");
                            Serial.println(lightning_intensity);
                            gw.send(msgDist.set(lightning_dist_km));
                            gw.send(msgInt.set(lightning_intensity));
                          else if(2 == int_src)
                            Serial.println("Disturber detected");
                            //gw.send(msgDist.set(998));
                          else if(3 == int_src)
                            Serial.println("Noise level too high");
                            //gw.send(msgDist.set(997));
                        // this is irq handler for AS3935 interrupts, has to return void and take no arguments
                        // always make code in interrupt handlers fast and short
                        void AS3935_ISR()
                          AS3935_ISR_Trig = 1;
                        It seems to be working (based on what I'm seeing using the serial monitor) and updating my controller (HomeSeer), although hard to know how well it's working without lightning in the area. I'll have to find a way to simulate lightning.
                        I have both the lightning sensor and the radio hooked up to the SPI bus.
                        Cheers
                        Al
                        EDIT: The diagram above is incorrect, I had to connect the lightning sensor breakout board to 5V, it did not seem to work at 3.3V in this configuration.
                        • hekH Offline
                          hekH Offline
                          Sweet. Would you want to create a pull request when you're ready with this example (including AS3935 library)?
                          SparkmanS 3 Replies Last reply
                            SparkmanS Offline
                            SparkmanS Offline
                            Sparkman
                            @hek Thanks and yes, will do.
                              SparkmanS Offline
                              SparkmanS Offline
                              Sparkman
                              @hek The AS3935 Sensor also registers the energy intensity. What sensor type would be the best way to send that data to the controller? I'm using S_DISTANCE for the calculated distance, but would also like to capture the energy intensity. The energy intensity is returned as a 32 bit integer.
                              Also, the AS3935 returns the distance in km, but I believe S_DISTANCE is in cm. Is there a way to specify different units or should I have the sketch convert it to cm and then have the controller convert back to km?
                              Al
                              H 1 Reply Last reply
                              • hekH Offline
                                hekH Offline
                                Oh.. than sensor is more advanced than I thought.
                                Send distance in "meter" for now. Stupid thing that the distance sensor example we're sending in cm in the first place.
                                Energy intensity is harder. What unit that is that? Maybe you could send it in VAR_1 for now?
                                  SparkmanS Offline
                                  SparkmanS Offline
                                  Sparkman
                                  @hek The sensor has a number of registers that can be set and/or read, so depending what someone wants to do with it, additional parameters may be sent.
                                  Ok, will do regarding the units. The energy intensity is just a relative value with no units associated with it. I saw one sketch for a different breakout board for the same chip that converted the intensity to a value in the range of 1-10. The actual value returned can be as large as 16843008. I'll take a look at VAR_1, but don't believe the HomeSeer plugin supports that yet. As a test I used I used V_WATT/S_POWER for now.
                                  Cheers
                                  Al
                                  • jeylitesJ Offline
                                    jeylitesJ Offline
                                    jeylites
                                    @Sparkman
                                    If you can give me some time say around June or July, I'll be going to a tropical country with lots of lightning. I could test it out for you using Vera.
                                      @Sparkman
                                      SparkmanS Offline
                                      SparkmanS Offline
                                      Sparkman
                                      @jeylites Thanks, I appreciate the offer. July/August are prime thunderstorm season where I live and they are forecasting a possible thunderstorm for today, so I'm hoping to confirm that everything is working today :-)
                                      Cheers
                                      Al
                                      • sowardS Offline
                                        sowardS Offline
                                        soward
                                        I put one of these together a short while ago -- just missed a storm rolling though, but another round might come through later. There's a reference in the code to AS3935_CAPACITANCE and a comment suggesting it be set to "THE NUMBER LISTED ON YOUR BOARD", however I'm seeing no number listed on the board. Am I just over looking it or is it something you derive?
                                        thanx,
                                        JpS
                                        • sowardS soward
                                          thanx,
                                          JpS
                                          SparkmanS Offline
                                          SparkmanS Offline
                                          Sparkman
                                          @soward So far the thunderstorms have skirted our area, but more to come tonight. Here's hoping ;-)
                                          The Capacitance value is written on the bag the sensor came in. If you don't have the bag anymore, send an email to TechnicalSupport@PlayingWithFusion.com and they should be able to cross reference your order and provide the value. How does your sketch compare to mine?
                                          Cheers
                                          Al
                                          sowardS 1 Reply Last reply
                                          113.2k
