  3. Weather Station with Scene Activator!!!
51 Posts 3 Posters 35.8k Views 3 Watching
  • BulldogLowellB
    BulldogLowellB
    BulldogLowell
    wrote on last edited by BulldogLowell
    you will have a lot of fun building this one.
    ADDED: Check out the youtube video.
    This Weather Station will display your indoor and outdoor environmental conditions but features some hot capabilities...
    Send a Short Message to the LCD from Vera by adding another variable and populating it with whatever you like on Vera.
    Using it in the bedroom and you want to turn the backlight off to get a good night sleep? It has that. Just use scenes or PLEG to toggle a variable on the hygrometer device to turn it on or off at specified times.
    Want to trigger a scene or initiate some other action from PLEG? It has that. Just use PLEG or Luup to monitor a variable on the hygrometer device to do cool things like:
    Put your house into Night mode
    Turn off all your lights
    Open your window coverings
    Turn on your Stereo, TV, or even a tea kettle
    Close your Garage door...
    in fact... this little button can be set up to do whatever you can setup in Vera!!!
    I have attached the sketch, so you are just a few tiny components away from having this all on your nightstand or on your desk.
    1: You will need to hardware debounce your switch but can be done with two extra components available for just a few shekels at your local electronics supplier. diagram attached.
    2: Arduino Nano, Uno or Pro Mini.
    3: Hygrometer/thermometer sensor
    4: LCD display I got mine on ebay
    5: A few wires
    6: A Button
    7: Moisture/Temperature sensor like this
    If you plan on building a simple hygrometer/thermometer... build this one instead, and make it really cool and powerful.
    Have Fun!
    *6-May EDIT
    I was having a couple small issues still with the debounce so added it in the sketch. I took the humidity and temp and put into a function and added the call the to setup. I didn't notice that it was delayed quite a bit getting T&H.
    Debounce.pngWeatherDisplayPBSceneController.ino
    • korttomaK
      korttomaK
      korttoma
      Grate to see you got it all to work.
      A few comments came to mind.
      Is the hardware debounce realy necesary? Did you try any software solutions?
      Is the sleep mode really useful for this sketch? I'm guessing you do not have any plans to run this one on battery so I see no reason to put it to sleep to save power.
      • Tomas
      BulldogLowellB 2 Replies Last reply
      • korttomaK korttoma
        BulldogLowellB
        BulldogLowellB
        BulldogLowell
        @korttoma
        thanks for the feedback.
        I found that it needed debouncing. It was getting into a funny state once in a while where it would lock up. it was so easy for me to add the capacitor on my breadboard, so I did it. A software debounce with a timeout on the button press would work too.
        I started with the sketch that had the radio sleep, never sure if I was going to make it battery version or not, so it was left in. It can be yanked out, do you want to try that?
        I really wanted to do two things, get data in, and push data out. I am working on a project that is reliant on both of those so building this was a major step for me.
        I thought it had a nice practical use given the display and the scene trigger. Plus it is so easy to build, I thought i could get some more people to look at it and help make improvements.
        I'm not a software guy, as you can tell from the sketch...
        • BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @hek
          Cool addition the youtube videos right on the MySensors page... nice improvement.
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @korttoma
            FYI I added the debounce to the sketch. Even with the cap I had a few lockups. I noticed I could get multiples and needed it to go away.
            • BulldogLowellB
              BulldogLowellB
              BulldogLowell
              I thought I would post a few photos of the finished device. While I like all things tech, my wife does not. So you can see, I have added to the list of making 'stuff' have a purpose.
              • korttomaK
                korttomaK
                korttoma
                Hay @BulldogLowell , I'm trying to make use of your sketch for my own project but I ran in to some issue.
                I had trouble finding the right library. I used the "LiquidCrystal_V1.2.1.zip" from here -> https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
                But I got some errors when compiling sketch. Then I found the library link under the ebay item you referred to and now it seems to work.
                you could mention this in the first post if possible so others don't fall in the same ditch.
                cheers ;)
                • Tomas
                • korttomaK
                  korttomaK
                  korttoma
                  Now I ran int to the next issue. How do I know which pin the SDA and SCL should be connected to??
                  Is it this line that defines it?
                  LiquidCrystal_I2C lcd(0x27,20,4);
                  So what should it be if I'm using a Pro Mini?
                  • Tomas
                  • korttomaK
                    korttomaK
                    korttoma
                    I think I found it now... For the Pro Mini it is like this:
                    "I2C: A4 (SDA) and A5 (SCL). Support I2C (TWI) communication using the Wire library."
                    I was expecting it to be declared somehow in the sketch so I got confused... Well I learned something once again...
                    • Tomas
                      BulldogLowellB
                      BulldogLowellB
                      BulldogLowell
                      @korttoma hey, glad you have it figured out.
                      I have been very busy and haven't been able to check in here for a while:(
                      all working now?
                      • korttomaK
                        korttomaK
                        korttoma
                        Yepp, all working now. Just need to find some time to make my deviec
                        • Tomas
                        • korttomaK
                          korttomaK
                          korttoma
                          Hi @BulldogLowell (or anybody else),I'm hoping you could help me with one last thing to finish this project of mine.
                          The issue I'm facing is that I do not know how to send a "string" from Vera using luup. Or basically collecting a string from a variable of one device and sending it to a MySensors node. Here is what I tried:
                          local text = luup.variable_get("urn:empuk-net:serviceId:SimpleAlarm1","StatusLabel", 319)
                          luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_3", value=text}, 276)
                          If I give the variable "text" a numeric value it is sent and received without problems but how the h**l can I send a string??
                          Grateful for any help
                          • Tomas
                          • korttomaK
                            korttomaK
                            korttoma
                            One step closer:
                            local text = "Test"
                            Instantly prints the text "Test" on my display :D
                            Seems like my issue is that I can not get the text from the SimpleAlarm Variable "StatusLable".
                            any suggestions?
                            • Tomas
                            • korttomaK
                              korttomaK
                              korttoma
                              Solved! :D
                              local status_label = luup.variable_get("urn:upnp-empuk-net:serviceId:SimpleAlarm1", "StatusLabel", 319)
                              luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_3", value=status_label}, 276)
                              Found my answere from the vera forum:
                              http://forum.micasaverde.com/index.php/topic,23942.msg168373.html#msg168373
                              • Tomas
                                Solved! :D
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                @korttoma said:
                                Solved! :D
                                Hye korttoma,
                                Did you finish this project?
                                I have a bit of time and thought I would convert my weather station up to the new mySensors version... was wondering if you could share your work...
                                korttomaK 1 Reply Last reply
                                  @korttoma said:
                                  Solved! :D
                                  Hye korttoma,
                                  korttomaK
                                  korttomaK
                                  korttoma
                                  @BulldogLowell
                                  Hi Jim, Yeah I finished it. there is a few posts about it over in heks scene controller thread -> http://forum.mysensors.org/topic/446/scene-controller
                                  • Tomas
                                  • BulldogLowellB
                                    BulldogLowellB
                                    BulldogLowell
                                    Tomas,
                                    My business has kept me away from this, I guess I didn't notice how far along you took it... brilliant job!
                                    I'll check in when it's done.
                                    Thanks mate.
                                    jim
                                    • BulldogLowellB
                                      BulldogLowellB
                                      BulldogLowell
                                      Tomas,
                                      Again, thanks for your example. I have to say, it helped a lot.
                                      I am however struggling with radio communication it seems and I am wondering at this point what I am doing wrong, having spent a couple hours trying to find my errors.
                                      Would you mind to take a look for anything you may see:
                                      #define STATES 7
                                      #define HUMIDITY_SENSOR_DIGITAL_PIN 4
                                      #define DEBUG
                                      #ifdef DEBUG
                                      #define DEBUG_SERIAL(x) Serial.begin(x)
                                      #define DEBUG_PRINT(x) Serial.print(x)
                                      #else
                                      #include <Wire.h>
                                      #include <Time.h>
                                      #include <DHT.h>
                                      #define RADIO_ID 11
                                      #define CHILD_ID_SCENE 3
                                      LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x20 for a 16 chars and 2 line display
                                      void (*lcdDisplay[STATES])();
                                      byte state = 0;
                                      byte lastState;
                                      byte timeCounter = 0;
                                      unsigned long lastTime;
                                      unsigned long refreshInterval = 3000UL;
                                      unsigned long lastClockSet;
                                      boolean isMessage = false;
                                      float insideTemperature;
                                      float humidity;
                                      int OutdoorTemp = -99;
                                      int OutdoorHumidity = -99;
                                      int todayHigh = -99;
                                      int todayLow = -99;
                                      String conditions = "Not yet Reported";
                                      String FreeMessage = "No Message recieved"; //*****
                                      int ledStatus = 1;// to toggle LCD backlight led
                                      //int ledLevel = 254;
                                      boolean buttonPushed = false;
                                      DHT dht;
                                      MyMessage msgOn(CHILD_ID_SCENE, V_SCENE_ON);
                                      MyMessage msgOff(CHILD_ID_SCENE, V_SCENE_OFF);
                                      MyMessage msgVAR1(CHILD_ID_SCENE, V_VAR1);
                                      MyMessage msgVAR2(CHILD_ID_SCENE, V_VAR2);
                                      MyMessage msgVAR3(CHILD_ID_SCENE, V_VAR3);
                                      MyMessage msgVAR4(CHILD_ID_SCENE, V_VAR4);
                                      MyMessage msgVAR5(CHILD_ID_SCENE, V_VAR5);
                                        DEBUG_SERIAL(115200);
                                        DEBUG_PRINTLN(F("Serial started"));
                                        attachInterrupt(1, PushButton, CHANGE);
                                        lcdDisplay[0] = lcdDisplay0;
                                        lcdDisplay[1] = lcdDisplay1;
                                        lcdDisplay[2] = lcdDisplay2;
                                        lcdDisplay[3] = lcdDisplay3;
                                        lcdDisplay[4] = lcdDisplay4;
                                        lcdDisplay[5] = lcdDisplay5;
                                        lcdDisplay[6] = lcdDisplay6;
                                        gw.begin(TempStatus, RADIO_ID);
                                        gw.sendSketchInfo("WeatherClock", "1.0");
                                        gw.present(CHILD_ID_SCENE, S_SCENE_CONTROLLER);
                                        int clockTimer;
                                        while(timeStatus() != timeSet && clockTimer < 10)
                                          gw.requestTime(receiveTime);
                                          Serial.println("getting Time");
                                          delay(500);
                                          clockTimer++;
                                        lcd.init();
                                        lcd.clear();
                                        lcd.backlight();
                                        lcd.setCursor(0, 0);
                                        lcd.print("Hello World!!!");
                                        delay(2000);
                                        lcd.clear();
                                        lastTime = millis();
                                        gw.process();
                                        if (millis() - lastClockSet >= 60000UL)
                                          lastClockSet = millis();
                                        if (millis() - lastTime >= refreshInterval)
                                          state++;
                                          if (state > STATES - 1) state = 0;
                                          DEBUG_PRINTLN(F("State:"));
                                          DEBUG_PRINTLN(state);
                                          lastTime += refreshInterval;
                                          getTempHumidity();
                                        if (state != lastState)
                                          fastClear();
                                          lcdDisplay[state]();
                                        lastState = state;
                                        if (buttonPushed)
                                          activateScene();
                                      void fastClear()
                                        lcd.setCursor(0,0);
                                        lcd.print("                ");
                                        lcd.setCursor(0,1);
                                        lcd.print("                ");
                                      void lcdDisplay0()
                                        lcd.setCursor(0,0);
                                        lcd.print(F("Time: "));
                                        if (hourFormat12() < 10) lcd.print("0");
                                        lcd.print(hourFormat12());
                                        lcd.print(":");
                                        if (minute() < 10) lcd.print("0");
                                        lcd.print(minute());
                                        DEBUG_PRINT(F("Time:"));
                                        DEBUG_PRINTLN(hourFormat12());
                                        lcd.setCursor(0,1);
                                        lcd.print(F("Date: "));
                                        if (month() < 10) lcd.print("0");
                                        lcd.print(month());
                                        lcd.print("/");
                                        if (day() < 10) lcd.print("0");
                                        lcd.print(day());
                                        lcd.print("/");
                                        lcd.print(year());
                                        DEBUG_PRINTLN(F("Date: 01.11.2014"));
                                      void lcdDisplay1()
                                        lcd.setCursor(0,0);
                                        lcd.print(F("Indoor Temp:"));
                                        lcd.print(int(insideTemperature));
                                        lcd.print(char(223));
                                        DEBUG_PRINT(F("Indoor Temp:"));
                                        DEBUG_PRINT(int(insideTemperature));
                                        DEBUG_PRINTLN(F("F"));
                                        lcd.setCursor(0,1);
                                        lcd.print("   Humidity:");
                                        lcd.print(int(humidity));
                                        lcd.print(F("%"));
                                        DEBUG_PRINT("   Humidity:");
                                        DEBUG_PRINT(int(humidity));
                                      void lcdDisplay2()
                                        lcd.setCursor(0,0);
                                        lcd.print("Outdoor Temp:");
                                        lcd.print(OutdoorTemp);
                                        DEBUG_PRINT(F("Outdoor Temp:"));
                                        DEBUG_PRINTLN(OutdoorTemp);
                                        lcd.setCursor(0,1);
                                        lcd.print(F("    Humidity:"));
                                        lcd.print(OutdoorHumidity);
                                        lcd.print(F("%"));
                                        DEBUG_PRINT(F("    Humidity:"));
                                        DEBUG_PRINTLN(OutdoorHumidity);
                                      void lcdDisplay3()
                                        lcd.setCursor(0,0);
                                        lcd.print(F("Today's HI:"));
                                        lcd.print(todayHigh);
                                        DEBUG_PRINT(F("Today's HIGH"));
                                        DEBUG_PRINTLN(todayHigh);
                                        lcd.setCursor(0,1);
                                        lcd.print(F("        LO:"));
                                        lcd.print(todayLow);
                                        DEBUG_PRINT(F("Today's LOW"));
                                        DEBUG_PRINTLN(todayLow);
                                      void lcdDisplay4()
                                        lcd.setCursor(0,0);
                                        lcd.print(F("Today's Weather is"));
                                        DEBUG_PRINTLN(F("Today's Weather:"));
                                        lcd.setCursor(0,1);
                                        lcd.print(conditions);
                                        DEBUG_PRINTLN(F("EXAMPLE"));
                                      void lcdDisplay5()
                                        if (isMessage)
                                          lcd.setCursor(0,0);
                                          lcd.print(F("****Message****"));
                                          DEBUG_PRINTLN(F("****Message****"));
                                          lcd.setCursor(0,1);
                                          lcd.print(F("Custom Message"));
                                          DEBUG_PRINTLN(F("Custom Message"));
                                        else
                                          lcd.setCursor(0,0);
                                          lcd.setCursor(0,1);
                                          lcd.print(F("Have a Nice Day"));
                                          DEBUG_PRINTLN(F("Have a Nice Day"));
                                      void lcdDisplay6()
                                        lcd.setCursor(0,0);
                                        lcd.print(F(" Weather & Time "));
                                        DEBUG_PRINTLN(F(" Weather & Time "));
                                        lcd.setCursor(0,1);
                                        lcd.print(F("by BulldogLowell"));
                                        DEBUG_PRINTLN(F("by BulldogLowell"));
                                      void getTempHumidity()
                                        insideTemperature = dht.toFahrenheit(dht.getTemperature());
                                        if (isnan(insideTemperature))
                                          DEBUG_PRINTLN(F("Failed reading temperature from DHT"));
                                        humidity = dht.getHumidity();
                                        if (isnan(humidity))
                                          DEBUG_PRINTLN(F("Failed reading humidity from DHT"));
                                      void receiveTime(unsigned long time)
                                        DEBUG_PRINTLN(F("Time value received: "));
                                        DEBUG_PRINTLN(time);
                                        setTime(time);
                                      void PushButton()
                                        static unsigned long last_interrupt_time = 0;
                                        unsigned long interrupt_time = millis();
                                        if (interrupt_time - last_interrupt_time > 200)
                                          buttonPushed = true;
                                        last_interrupt_time = interrupt_time;
                                      void activateScene()
                                        DEBUG_PRINTLN(F("ButtonPushed"));
                                        fastClear();
                                        for (byte i = 0; i < 10; i++)
                                          lcd.noBacklight();
                                          delay(50);
                                          lcd.backlight();
                                          delay(50);
                                        lcd.setCursor(0,0);
                                        lcd.print(F(" A/C Boost Mode "));
                                        lcd.setCursor(0,1);
                                        lcd.print(F("**** ACTIVE ****"));
                                        delay(2000);
                                        lastTime = millis(); //Reset the timer to even out display interval
                                      void TempStatus(const MyMessage &message)
                                        if (message.type == V_VAR1)
                                          OutdoorTemp = atoi(message.data);
                                          DEBUG_PRINTLN(F("OutdoorTemp recieved:"));
                                        if (message.type == V_VAR2)
                                          OutdoorHumidity = atoi(message.data);
                                          DEBUG_PRINT(F("OutdoorHumidity recieved:"));
                                        if (message.type == V_VAR3)
                                          todayLow = atoi(message.data);
                                          DEBUG_PRINT(F("Today's LOW:"));
                                        if (message.type == V_VAR4)
                                          todayHigh = atoi(message.data);
                                          DEBUG_PRINT(F("Today's HIGH:"));
                                        if (message.type == V_VAR5)
                                          conditions = String(message.data);
                                      my error looks like this:
                                      Serial started
                                      sensor started, id 11
                                      send: 11-11-0-0 s=255,c=0,t=17,pt=0,l=3,st=fail:1.4
                                      send: 11-11-0-0 s=255,c=3,t=6,pt=1,l=1,st=fail:0
                                      send: 11-11-0-0 s=255,c=3,t=11,pt=0,l=12,st=fail:WeatherClock
                                      send: 11-11-0-0 s=255,c=3,t=12,pt=0,l=3,st=fail:1.0
                                      send: 11-11-0-0 s=3,c=0,t=25,pt=0,l=3,st=fail:1.4
                                      send: 11-11-0-0 s=255,c=3,t=1,pt=0,l=3,st=fail:1.4
                                      getting Time
                                      send: 11-11-255-255 s=255,c=3,t=7,pt=0,l=0,st=fail:
                                      getting Time
                                      send: 11-11-0-0 s=255,c=3,t=1,pt=0,l=0,st=fail:
                                      getting Time
                                      getting Time
                                      getting Time
                                      getting Time
                                      getting Time
                                      State:
                                      Indoor Temp:71F
                                         Humidity:46F
                                      State:
                                      Outdoor Temp:-99
                                          Humidity:-99
                                      State:
                                      Today's HIGH-99
                                      Today's LOW-99
                                      State:
                                      My lua code server-side is this:
                                      local temp = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 60)
                                      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_1", value=temp}, 85)
                                       local humid = luup.variable_get("urn:micasaverde-com:serviceId:HumiditySensor1","CurrentLevel", 63)
                                      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_2", value=humid}, 85)
                                      local low = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 61)
                                      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_3", value=low}, 85)
                                      local high = luup.variable_get("urn:upnp-org:serviceId:TemperatureSensor1","CurrentTemperature", 62)
                                      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_4", value=high}, 85)
                                      local conditions = luup.variable_get("urn:upnp-org:serviceId:Weather1","CurrentTemperature", 59)
                                      luup.call_action("urn:upnp-arduino-cc:serviceId:arduino1", "SendCommand", {radioId="11;3", variableId="VAR_5", value=conditions}, 85)
                                      • BulldogLowellB
                                        BulldogLowellB
                                        BulldogLowell
                                        I added delays in the lua code and that seemed to help a lot:
                                        luup.sleep(750)
                                        luup.sleep(750)
                                        luup.sleep(750)
                                        luup.sleep(750)
                                        still struggling with this, however:
                                          DEBUG_PRINT(F("Received today's Conditions:"));
                                          DEBUG_PRINTLN(conditions);
                                        not returning the present conditions....
                                        • BulldogLowellB
                                          BulldogLowellB
                                          BulldogLowell
                                          also noticed that variable5 (V_VAR5) does not show up here (in device 85):
