  3. Small wall outlet sensor node
40 Posts 17 Posters 29.6k Views 12 Watching
  • axillentA
    axillentA
    axillent
    wrote on last edited by axillent
    I've created this to have easiest way to establish environment monitoring across the house
    the idea is to have a wall outlet type plug with everything on board
    and I like to do small things
    The board is less than 50 x 50 mm
    It contains AC-DC power supply with resettable fuse, 3.3V LDO, arduino based on atmega328, radio, LED, and two slots, one for DS18B20 and the second one is for DHT11/DHT22
    The real consumption measured by RMS wattmeter is just 0.3W
    sense and drive
    O 1 Reply Last reply
    • greglG
      greglG
      gregl
      Really nice!
      I guess the DHT11/22 pin could also be used for PIR sensor or drive a relay/actuator.
      axillentA 1 Reply Last reply
        Cool!
        @axillent, did you get a chance to test the MPL-03S-05E I sent you?
        • axillentA axillent
          O
          O
          olaeke
          @axillent Very nice! How do you make the circuit board and the soldering of surface mounted components is quit advanced.
          • greglG gregl
            Really nice!
            axillentA
            axillentA
            axillent
            @gregl thanks, yes, the same board can be used for any simple 1-2 inputs or 1-2 channel actuator
            I have a plan to create something similar for wall switch in 3-wire and 2-wire versions
            sense and drive
            RJ_MakeR 1 Reply Last reply
              Cool!
              axillentA
              axillentA
              axillent
              @hek thanks
              I read a datasheet and I doubt about where to use it
              it requires quite a big external filter
              the total size will be bigger than normal isolated AC-DC
              The supply based on none-isoleted schema is interested in some projects where you need lower footprint.
              If someone interested I will do a test
              sense and drive
              • axillentA
                axillentA
                axillent
                Here are a schematic and PCB prints
                MySensors.Sens.atmega328-wall.PDF
                sense and drive
                • O olaeke
                  axillentA
                  axillentA
                  axillent
                  @olaeke thanks!
                  it is half-a-day project including a home-production of the PCB
                  but it is a 2-year experience
                  I also use a simplified approach for some PCBs, without drilling, using 0.5mm FR4 cut by office scissors and thermo-transfer technology. This one requires about 30-50 minutes for the production circle.depending on etching speed. For example this two side AC lamp off-timer:
                  http://radiokot.ru/circuit/digital/automat/81/04.jpg
                  http://radiokot.ru/circuit/digital/automat/81/05.jpg
                  sense and drive
                  • axillentA
                    axillentA
                    axillent
                    Pictures bellow are virtual, under printing
                    MySensors.Sens.atmega328-wall modelview-02.JPG MySensors.Sens.atmega328-wall modelview-01.JPG
                    sense and drive
                    • gaduG
                      gaduG
                      gadu
                      It would be cool with a 90degree angled version as well :)
                      • HeinzH
                        HeinzH
                        Heinz
                        Excellent!
                          RJ_MakeR
                          RJ_MakeR
                          RJ_Make
                          @axillent Your an evil genius! :-)
                          RJ_Make
                          • RJ_MakeR RJ_Make
                            axillentA
                            axillentA
                            axillent
                            @ServiceXp thanks)
                            all this is simple, just a patient work
                            Printed thing is a bit ugly comparing to the virtual one, but it's work is real
                            http://www.youtube.com/watch?v=JG7gutD1oo8
                            sense and drive
                            greglG bjornhallbergB 2 Replies Last reply
                              @ServiceXp thanks)
                              greglG
                              greglG
                              gregl
                              @axillent So very very cool!!
                              as @gadu commented, making one at 90 deg so its very low profile would be even better for places such as hallways where the sensor could be bumped....
                              Really nice!
                              • blaceyB
                                blaceyB
                                blacey
                                @axillent - well done! :+1:
                                  @ServiceXp thanks)
                                  bjornhallbergB
                                  bjornhallbergB
                                  bjornhallberg
                                  @axillent Very impressive! What is the total cost of the components involved?
                                    axillentA
                                    axillentA
                                    axillent
                                    @bjornhallberg it is hard to say
                                    the BOM is simple and short
                                    but the cost of a single component is dramatically depends on how many your purchase in a single order
                                    for example atmega328 purchased in 10pcs will be US1.2 pcs while a single pcs will costs US3-4
                                    If it will be an interest I think in production this PCB can cost retail US8-12
                                    sense and drive
                                    gigiG 1 Reply Last reply
                                      gigiG
                                      gigiG
                                      gigi
                                      @axillent
                                      very very cool!!
                                      Vera lite - mysensors Ethernet gateway - AirWik sensor - Relay Module
                                      • nutcrackerN
                                        nutcrackerN
                                        nutcracker
                                        Impressive!
                                        • axillentA
                                          axillentA
                                          axillent
                                          made two more with modified box - it is a bit wider to hold DHT sensor inside
                                          I made a new sketch as a combination of Dalas example and DHT. This new sketch able to detect automatically connected sensors and work according to detection.
                                          One problem I've got. I cannot get DHT working from AC plug. It is working fine been powered from DC and failed during startup been powered from AC :( The most probably the reason is high pulsation (up to 440mV) coming from the supply based on SR10 chip.
                                          Dalas is fine with this but not DHT. Probably some code inside the library holds.
                                          Had to mark each sensor with radio channel because they will work with different gateways
                                          sense and drive
