cant get setSafeguard to work with NodeManager 1.8dev
  • Hi
    First of all, since this is my first post. Thank you all who have made this possible and so easy for us to use, especially NodeManager.
    I'm currently working on a garage sensor. Everything is working except this safeguard.
    I'm using a relay to open my garage door, but I only need a puls so I want to de-energize the relay as soon as possible. I tried to use;
    // [108] when switching on, turns the output off after the given number of milliseconds. For latching relay controls the pulse width (default: 0)
        void setPulseWidth(int value);
    It worked, but with power loss it would send one puls at startup, I tried using EEPROM, but still the same problem.
    So I thought it would be possible to use it as a normal relay and then use setSafeguard to be sure to cut the signal to the relay within a short time. Nothing happens when I try to use setSafeguard.
    Here is my code. If anyone can see where my mistake is, or have another solution how to make a momentary relay with nodeManager. I would be very happy 🙂
    * Copyright (C) 2013-2017 Sensnology AB
     * MySensors node configuration
    // General settings
    #define SKETCH_NAME "Relay"
    #define SKETCH_VERSION "1.0"
    #define MY_NODE_ID 3
    // RFM69 radio settings
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ  // Define for frequency setting. Needed if you're radio module isn't 868Mhz (868Mhz is default in lib)
    #define MY_IS_RFM69HW  // Mandatory if you radio module is the high power version (RFM69HW and RFM69HCW), Comment it if it's not the case
    #define MY_RFM69_NETWORKID 100  // Default is 100 in lib. Uncomment it and set your preferred network id if needed
    #define MY_RFM69_NEW_DRIVER
    // Advanced settings
    #define MY_BAUD_RATE 9600
     * NodeManager configuration
    #define NODEMANAGER_DEBUG ON
    #define NODEMANAGER_INTERRUPTS ON
    #define NODEMANAGER_SLEEP OFF
    #define NODEMANAGER_RECEIVE ON
    #define NODEMANAGER_DEBUG_VERBOSE ON
    #define NODEMANAGER_POWER_MANAGER OFF
    #define NODEMANAGER_CONDITIONAL_REPORT ON
    #define NODEMANAGER_EEPROM OFF
    #define NODEMANAGER_TIME ON
    #define NODEMANAGER_RTC OFF
    #define NODEMANAGER_SD OFF
    #define NODEMANAGER_HOOKING OFF
    #define NODEMANAGER_OTA_CONFIGURATION OFF
    #define NODEMANAGER_SERIAL_INPUT OFF
    // import NodeManager library (a nodeManager object will be then made available)
    #include <MySensors_NodeManager.h>
     * Add your sensors
    //#include <sensors/SensorConfiguration.h>
    //SensorConfiguration configuration;
    #include <sensors/SensorSignal.h>
    SensorSignal signal;
    #include <sensors/SensorLDR.h>
    SensorLDR ldr(A0);
    #include <sensors/SensorRelay.h>
    SensorRelay relay(6);
    #include <sensors/SensorDHT22.h>
    SensorDHT22 dht22(4);
    #include <sensors/SensorDoor.h>
    SensorDoor door(3);
     * Main Sketch
    // before
    void before() {
       * Configure your sensors
      // report measures of every attached sensors every 10 minutes
      nodeManager.setReportIntervalMinutes(10);
      // [105] automatically turn the output off after the given number of minutes
      relay.setSafeguard(1);
      // call NodeManager before routine
      nodeManager.before();
    // presentation
    void presentation() {
      // call NodeManager presentation routine
      nodeManager.presentation();
    // setup
      // call NodeManager setup routine
      nodeManager.setup();
    // loop
      // call NodeManager loop routine
      nodeManager.loop();
    #if NODEMANAGER_RECEIVE == ON
    // receive
      // call NodeManager receive routine
      nodeManager.receive(message);
    #if NODEMANAGER_TIME == ON
    // receiveTime
    void receiveTime(unsigned long ts) {
      // call NodeManager receiveTime routine
      nodeManager.receiveTime(ts);
  • It Looks like I can somewhat answer my own question.
    I got Safeguard to work, even if I have set it to 1minute, it doesn't update before next
    So it takes 10minutes, even if I have sent it to 1min. Is it supposed to be like this or is it a bug?
  • Contest Winner
    Sorry for the delay first of all, unfortunately I didn't get the notification of this thread 😕 If you are using a latching relay I'd recommend using SensorLatchingRelay1Pin or SensorLatchingRelay2Pins which should take better all the aspects of a latching relay. Then you can still use the safeguard for closing the door after a given timeframe. And yes you have to set a reporting interval even if not intuitive at all. This is because the safeguard is checked in the loop cycle which is called only if a reporting interval is set. So if you have a safeguard set to 1 minute, the report interval should be 1 minute or less. Thanks!
11.3k
