Need some minor help with MQTT strings
  • Hi,
    I have a MQTTClient from the dev branch communicating with my Mosquitto Broker, and relaying information from Temp/Humidity sensors nicely. Now I have been trying to add in my relays, and i'm not sure what string to use for them to send them data. I'm using Home-Assistant, and my MQTT strings look like this for temp/humid/motion and work fine:
    #Sensors
    sensor 1:
      platform: mqtt
      state_topic: "mygateway1-out/13/0/1/0/1"
      name: "Upstairs Humidity"
      unit_of_measurement: "%"
    sensor 3:
      platform: mqtt
      state_topic: "mygateway1-out/13/1/1/0/0"
      name: "Upstairs Temperature"
      unit_of_measurement: "°C"
    sensor 4:
      platform: mqtt
      state_topic: "mygateway1-out/13/2/1/0/16"
      name: "Upstairs Room PIR"
      payload_on: "1"
      payload_off: "0"
    sensor 5:
      platform: mqtt
      state_topic: "mygateway1-out/1/1/1/0/16"
      name: "Test PIR LR"
      payload_on: "ON"
      payload_off: "OFF"
    But my relay one does not. This is what it looks like:
    #Switches (Lights)
    switch 1:
      platform: mqtt
      state_topic: "mygateway1-out/2/255/3/0/3"
      command_topic: "mygateway1-in/2/255/3/0/3"
      payload_on: "1"
      payload_off: "0"
    I notice that both my PIR sensors end in /16, so i'm guessing there is a standard for light switches as well. Anyone have any idea where I would be going wrong? This is the sketch I am using. There are two relays connected one on Pin 3 the other on Pin 5, so it's set up for 3 relays right now.
     * Version 1.0 - Henrik Ekblad
    #include <MySigningNone.h>
    #include <MyTransportNRF24.h>
    #include <MyTransportRFM69.h>
    #include <MyHwATMega328.h>
    #define NUMBER_OF_RELAYS 3 // Total number of attached relays
    #define NODE_ID 2 //Disable to have GW set automatically
    //MyTransportRFM69 radio;
    //MySigningNone signer;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      gw.begin(incomingMessage, NODE_ID, AUTO, true);
      gw.sendSketchInfo("EasyLED", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    Thanks,
    This does not look korrekt.
    The serial API says:
    node-id;child-sensor-id;message-type;ack;sub-type;payload\n
    so you are trying to send something to node 2, sensor 255. That does not work. Your skeetch is numbering the child from 1 to NUM_RELAYS
    so i think something like
    command_topic: "mygateway1-in/2/1/3/0/3"
    should to... But that's my theoretical knowledge 😄 haven't build a relay yet
  • Plugin Developer
    The third digit from the left is the command/message type and should not be 3 but 1, to set a value. 3 means internal command/message. See the mysensors API.
    Edit:
    Since you are using a state topic in home assistant, you also need to send a message to the controller of the state change, after receiving the command to switch the relay.
    For the sensors, I suggest using binary sensors in home assistant for the PIRs that only report on/off.
  • Well, getting closer @dakky and @martinhjelmare
    The Serial API page is a good resource, but i'm still having issues with the gateway-in part I think. HA starts the light as off, so when I try to switch it on I receive the message in mosquitto mygateway-out:
    mygateway1-out/2/0/1/1/3 1
    And this is the output I receive via serial from the sensor:
    send: 2-2-1-0 s=0,c=1,t=3,pt=0,l=1,sg=0,st=ok:1
    read: 0-1-2 s=0,c=1,t=3,pt=0,l=1,sg=0:1
    send: 2-2-1-0 s=0,c=1,t=3,pt=0,l=1,sg=0,st=fail:1
    So i'm getting closer, i'm sure it's in the communication somewhere but not sure where. This is what my configuration.yaml file looks like right now....
    #Switches (Lights)
    switch 1:
      platform: mqtt
      state_topic: "mygateway1-out/2/0/1/2/3"
      command_topic: "mygateway1-in/2/0/1/2/3"
      payload_on: "1"
      payload_off: "0"
  • Plugin Developer
    Read @dakky 's post again. Your MQTT topic structure is still not correct. Topics in HA config does not match what you write that mosquitto outputs.
    Post your new sketch, might be something in there as well.
  • Plugin Developer
    @drock1985 I guess your switch string should be as follows,
    #Switches (Lights)
    switch 1:
      platform: mqtt
      state_topic: "mygateway1-out/2/1/1/0/2"
      command_topic: "mygateway1-in/2/1/1/0/2"
      payload_on: "1"
      payload_off: "0"
