  3. MQTT Client using MySensors Serial Gateway
5 Posts 4 Posters 3.6k Views 2 Watching
  • A
    A
    arendst
    I wrote a python script acting as a MQTT Client using the standard MySensors Serial Gateway:
    https://github.com/arendst/mqtt-mysensors
    It is based on the MQTT Ethernet gateway as provided with the MySensors package. It supports the same message structure as
    <topic_prefix>/<nodeid>/<childid>/<variable_type> [<value>]
    Depending of the presence of <value> a C_SET or C_REQ message is send to the gateway. It recognizes ON and OFF for V_LIGHT. So publishing 'mysensors/0/0/V_LIGHT ON' will turn the light on for node 0 and child 0.
    Before use please update the user configuration values according to your environment at the beginning of the script.
    L TheoLT 2 Replies Last reply
    • A arendst
      L
      L
      lafleur
      @arendst
      I have this gateway running on my Raspberry PI2, but I noticed that it not giving out node ID's... Is this something your going to add??
      • X
        X
        xefil
        hello @arendst ,
        Does it work on MySensors API 2.0 as well?
        I'm interested to use it ;)
        thanks!!
        Simon
        X 1 Reply Last reply
        • A arendst
          TheoLT
          TheoLT
          TheoL
          @arendst I'm also interested of you MQTT client is capable of assinging nodes. At this point it's the only reason why I still connect everything through Domoticz. Would be awesome to separate MySensors and Domoticz.
          • X xefil
            hello @arendst ,
            thanks!!
            Simon
            X
            X
            xefil
            Seems to work well! I'll test it a little bit :-)
