  3. Air Quality Sensor
Air Quality Sensor
calibrationaqigas sensorhchoair quality
270 Posts 46 Posters 456.4k Views 35 Watching
  • epierreE
    epierreE
    epierre
    @jumping see just above on power regressin curves, this is the result from a power regression based on the data sheet provided by one maker. Sometime I leave the data points in the sketch, sometime not (based on history ;-)
    z-wave - Vera -> Domoticz
    • epierreE epierre
      Air Quality Index is a combination of several sensors values:
      • sulfur dioxide (SO2) MQ136 / (avoid:2SH12 no datasheet)
      • nitrogen dioxide (NO2) MiCS-2710 MiCS-2714 MICS-6814
      • carbon monoxide (CO) MQ-7 MiCS-5525 TGS2442 MICS-6814
      • ozone (O3) MQ131 MICS-2610 MICS-2614
      • Particles concentration: PM2.5 and PM10 (SamYoung DSM501, Shinyei_PPD42NS, avoid: Sharp_GP2Y1010AU)
      Additional gases can be interesting to track:
      • CO2 MH-Z14
      Current work being done:
      • manage default Ro once
      • take into account humidity
      • manage to get proper values from TGS2600
      • possibility to have a push if a value goes up too quick (for deadly gases even without calibration)
      What is done:
      • remove powerdown to keep heaters on
      • add a five minute pre-heat on each startup
      • removed the powerdown
      • 2SH12 datasheet doesn't exist
      WARNING: all sensors differs even within the same reference, a calibration has to be done each time. Do not rely upon a sketch result with deadly gases.
      Working sketch in 1.4/1.5:
      • https://github.com/empierre/arduino/blob/master/MQv01dgi_1_4.ino (for a Mega, MQ2, MQ6, MQ131, MQ136, MQ138, TGS2600, TGS2602, HCHO, Barometer BMP085, DHT11)
      • https://github.com/empierre/arduino/blob/master/AirQuality-CO-NO2-NH3.ino for MICS-6814
      • https://github.com/empierre/arduino/blob/master/CO2-MH-Z14.ino
      • https://github.com/empierre/arduino/blob/master/DustSensor_SamYoung_DSM501.ino
      • https://github.com/empierre/arduino/blob/master/DustSensor_Shinyei_PPD42NS.ino
      ambuj
      @epierre Hi I am working on the MQ2 sensor, I want to know CO level. Did you do it before with this sensor?
      http://www.amazon.in/Butane-Hydrogen-Sensor-Detector-Arduino/dp/B01N0XSQ9J?tag=googinhydr18418-21&tag=googinkenshoo-21&ascsubtag=9d5b3107-037a-4d7b-a8b9-722d0a4bcfea.
      I am using this module and just start work with this sensor.
      epierreE 1 Reply Last reply
      • Lukács AttilaL
        Lukács AttilaL
        Lukács Attila
        @epierre is it possible that the lastest github for Samyoung 501a is not correct? Flashed it and the results are way too high (157000 mg/m3)?
          surepic
          Ppm percentage calculations in the code seems wrong. Instead of providing rs/ro ratio to the function is transfered rs value not the ratio.
          alexsh1A 1 Reply Last reply
          • A ambuj
            epierreE
            epierreE
            epierre
            @ambuj please see the begining of the discussion regarding MQ like reliability
            • Lukács AttilaL Lukács Attila
              epierreE
              epierreE
              epierre
              @lukács-attila check wiring first, seems there are several sub version around thay may need other values from datasheet
              • S surepic
                alexsh1A
                alexsh1A
                alexsh1
                @surepic Which sensor? Which code? Would you please be more specific?
                • alexsh1A alexsh1
                  @epierre I wonder if you looked at this sensor Figaro TGS8100:
                  http://www.figarosensor.com/products/entry/tgs8100.html
                  Looks like it is perfect for a low-powered platform.
                  R
                  R
                  Rosmel
                  @alexsh1
                  Hello, I am working recently with tgs8100 sensors, and I am developing a project, I would like to know how it was in the results? How did you acquire them? Any arduino code? Thank you
                  • alowhumA
                    alowhumA
                    alowhum
                    @rosmel said in Air Quality Sensor:
                    tgs8100
                    That's also quite a non-precise sensor if I understand correctly. Useful for general 'how's the air', but because it will respond to so many different 'polutants' you never know which of those polutant is the culprit.
                    You will find code in the forum for good CO, CO2 and fine dust sensors.
                    • R
                      R
                      rayzyzy
                      Working with tgs2602 , tgs 2620 and tgs2611 . I've read the replies from top to bottom but haven't understood how
                      exactly i take data from the graph in datasheet and use it with power regression .
                      12.5k
