  3. How ethernet gateway code can check if is connected with controller?
3 Posts 1 Posters 1.1k Views 2 Watching
  • M Offline
    M Offline
    matkor
    Having arduino ethernet gateway I need to send messages with senors values to controller (Home assistant requirement to auto configure sensors).
    With serial gateway simple sending in first iteration of loop:
    		if ( ! inital_msgs_sent ) {
    			inputs.sendStates();
    			outputs.sendStates();
    			inital_msgs_sent = true;
    worked.
    But with ethernet controller loop starts when HA is not yet connected to GW so sent messages do not reach controller :/
    So, how should I fix it?
    1. Is any way to know if controller is connected ?
    2. Is any way to know if controller requested presentation?
    3. Is any way to know if send message really reached controller?
    TIA, regards,
    • M matkor
      worked.
      TIA, regards,
      M Offline
      M Offline
      matkor
      @matkor said in How ethernet gateway code can check if is connected with controller?:
      2. Is any way to know if send message really reached controller?
      Seems positive send() result means message reached controller when executed on gateway?
      • M Offline
        M Offline
        matkor
        Answering one of my own questions.
        On ethernet gateway send() may return true when there is no connected controller, even when there is no ethernet cable plugged in. :/
