  3. Rpi MQTT Gateway on Docker
6 Posts 4 Posters 1.9k Views 4 Watching
  • magpernM
    magpernM
    magpern
    wrote on last edited by magpern
    Has anyone successfully installed a raspberry pi Mysensors MQTT Gateway in a docker container?
    There is a docker file with a mysensors mqtt online, but it does not work.
    And if it where, it is lacking personalization files and config files.
    • magpernM
      magpernM
      magpern
      If anyone is interested.. I got MySensors Ethernet Gateway working in a docker container on a RPi, with a radio connected physically to the Pi.
      • J
        J
        jrbenito
        I am starting with MySensors to switch my mighthat gateway in near future. Could you share a bit more? I have some experience with docker.
        magpernM 1 Reply Last reply
        • J jrbenito
          magpernM
          magpernM
          magpern
          @jrbenito I did jump the gun a little early. Sure, the gateway works, if you have externally connected devices, like an external MySensors gateway, but it does not work if you have the radio wired directly onto the RPi. It cannot fint the SPI.
          Basically I did this:
          A DockerFile (the .configure section needs to be modified to personal preferences)
          FROM balenalib/raspberrypi3-debian
          RUN apt-get update && apt-get install -y --no-install-recommends git bash make g++ \
            && cd /root \
            && git clone https://github.com/mysensors/MySensors.git --branch development \
            && cd /root/MySensors \
            && mkdir -p /data \
            && LDFLAGS="-static" ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-is-rfm69hw --my-gateway=ethernet --my-port=5003 --my-leds-err-pin=29 --my-leds-rx-pin=31 --my-leds-tx-pin=33 --my-rfm69-encryption-enabled --my-signing-request-signatures --my-signing=software --my-config-file="/data/mysensors.conf" \
            && make \
            && cd /root \
            && apt-get remove -y git make g++ && apt-get autoremove -y
          EXPOSE 5003
          ENTRYPOINT ["/root/MySensors/bin/mysgw"]
          And a Docker-compose.yml file (ports needs to be configured. I think 5003 is not needed, since 5003 would be used if the gateway was handling the radio wired to the pins of the pi. Run with serial instead)
          version: '3'
          services:
            portainer:
              container_name: portainer
              image: portainer/portainer:arm
              restart: always
              volumes:
                - '/var/run/docker.sock:/var/run/docker.sock'
              expose:
                - 9000
              ports:
                - 9000:9000
            mysensors:
              build:
                context: .
                dockerfile: Dockerfile
              container_name: mysensor_eth
              restart: unless-stopped
              privileged: true
              devices:
                - /dev/ttyACM0:/dev/ttyACM0
              ports:
                - 5003:5003
              volumes:
                - /mnt/usb1/mysensorsd/data:/data:rw
                - /sys:/sys:rw
                - /tmp:/tmp
          The config file needs to be on a exposed volume and have the eeprom file pointed to the same volume
          File mysensors.conf and it needs to be modified for signing keys and path to log aqnd eeprom
          i had everything on /mnt/usb1/mysensors and folders data created within that path. I set access to full RW for everyone
          # Logging
          # Verbosity: debug,info,notice,warn,err
          verbose=debug
          # Enable logging to a file.
          log_file=1
          # Log file path.
          log_filepath=/mnt/usb1/mysensors/data/mysgw.log
          # Enable logging to a named pipe.
          # Use this option to view your gateway's log messages
          # from the log_pipe_file defined bellow.
          # To do so, run the following command on another terminal:
          #   cat "log_pipe_file"
          log_pipe=1
          log_pipe_file=/tmp/mysgw.pipe
          # Enable logging to syslog.
          syslog=0
          # EEPROM settings
          eeprom_file=/mnt/usb1/mysensors/data/mysensors.eeprom
          eeprom_size=1024
          # Software signing settings
          # Note: The gateway must have been built with signing
          #       support to use the options below.
          # To generate a HMAC key run mysgw with: --gen-soft-hmac-key
          # copy the new key in the line below and uncomment it.
          soft_hmac_key=****************
          # To generate a serial key run mysgw with: --gen-soft-serial-key
          soft_serial_key=*******************
          # Encryption settings
          # Note: The gateway must have been built with encryption
          # To generate a AES key run mysgw with: --gen-aes-key
          aes_key=**************
          I do not use the MySensors on a docker. I had som many problems with it, SPI beeing one, and the LEDs an other.
          It literally takes 3 minutes to set it up and run nativelly on a Pi, and this gives you full access to everything.
          I run everything else in a docker.
          Z 1 Reply Last reply
          • magpernM magpern
              && cd /root \
              && mkdir -p /data \
              && make \
              && cd /root \
            EXPOSE 5003
            version: '3'
            services:
              portainer:
                restart: always
                volumes:
                expose:
                  - 9000
                ports:
                  - 9000:9000
              mysensors:
                build:
                  context: .
                privileged: true
                devices:
                ports:
                  - 5003:5003
                volumes:
                  - /sys:/sys:rw
                  - /tmp:/tmp
            # Logging
            verbose=debug
            log_file=1
            # Log file path.
            log_pipe=1
            syslog=0
            # EEPROM settings
            eeprom_size=1024
            Z
            Z
            zurajm
            @magpern SPI access in Docker container is possible, you have to use --privileged switch when creating container and some other switches when compiling. I ended up with the following Dockerfile:
            FROM raspbian/stretch AS build
            WORKDIR /root
            WORKDIR MySensors
            RUN echo "##### Building version: $(cat library.properties | grep version | cut -d= -f2)-$(git describe --tags)"
            RUN LDFLAGS="-static" ./configure --my-transport=rfm69 --my-rfm69-frequency=433 --my-is-rfm69hw --my-gateway=mqtt --my-controller-ip-address=<ip of the mqtt server> --my-mqtt-user=<user> --my-mqtt-password=<password> --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in  --my-leds-err-pin=12 --my-leds-rx-pin=16 --my-leds-tx-pin=18 --my-config-file=/data/mysensors.conf --spi-driver=BCM --soc=BCM2836 --cpu-flags="-mcpu=cortex-a53 -mfloat-abi=hard -mfpu=neon-fp-armv8 -mneon-for-64bits -mtune=cortex-a53" \
              && make
            FROM hypriot/rpi-alpine-scratch
            RUN mkdir /data
            WORKDIR /root
            COPY --from=build /root/MySensors/bin/mysgw .
            EXPOSE 5003
            ENTRYPOINT ["./mysgw"]
            I couldn't get ethernet mode to work (I got core dump as soon as client connected to gateway) so I'm using MQTT mode which works great. Here is the relevant run command:
            docker run --privileged --volume /opt/mysensors:/data --restart unless-stopped --name mysgw zurajm/mysgw-mqtt-alpine:latest
            the mysensors.conf resides in /opt/mysensors:
            # Logging
            verbose=debug
            log_file=0
            # Log file path.
            log_filepath=/tmp/mysgw.log
            log_pipe=0
            syslog=0
            # EEPROM settings
            eeprom_file=/data/mysensors.eeprom
            eeprom_size=1024
            #soft_hmac_key=
            #soft_serial_key=
            #aes_key=
            I only modified eeprom_file location to /data folder.
            I hope someone can benefit from it.
            BR, Miha
            • joaoabsJ
              joaoabsJ
              joaoabs
              I was looking for this!
              How can I get this docker container?
              Cheers,
              Joaoabs
