  3. Node-RED
  4. node-red-contrib-mysensors release thread
Scheduled Pinned Locked Moved Node-RED
36 Posts 6 Posters 10.2k Views 8 Watching
  • tbowmoT
    tbowmoT
    tbowmo
    NPM is trying to build sqlite, because it cannot find a suitable pre-built one for your architecture, it fails because you do not have the needed tools installed for this on your machine.
    Might help if you install build-essentials (sudo apt-get install build-essentials, assuming you are on a debian like install)
    I currently use it on node-red 1.1.2, without problems. But I'm using plain node-red in a docker container..
    • D
      DenisJ
      @tbowmo said in node-red-contrib-mysensors release thread:
      Thanks for the answer.
      I have now Node-Red 1.3.3 under Home Assistant installed.
      But I must search on net how can I install the build-essentials from the docker console.
      Do you know if is there some other node that I can install from the palette that maybe incluse the build-essentials please ?
      Thanks again
      Denis
      • tbowmoT
        tbowmoT
        tbowmo
        What I did way back when I got it up and running in docker, was to jump into the container shell, and install the package manually (So you are using the same node.js version that node-red is using).
        You could also (in that docker shell) do a apt install (given that it builds upon a debian based image).
        something in the line of:
        $ docker exec -it <id of container running node-red> /bin/bash
        # now you are in docker..
        $ apt install build-essentials
        $ cd <to your node-red data directory>
        $ npm install node-red-contrib-mysensors
        $ exit
        Above is taken purely from what I think is the right commands, as I have not tried working with home-assistant for a while.
        • D
          DenisJ
          I think I have not the apt inside of Node_red docker.
          Can I install it from outside in this case.
          Sorry but I'm very beginner so I need some basic info in this case.
          Thanks a lot again
          Denis
          • electrikE
            electrikE
            electrik
            In Home Assistant you have the Node Red configuration (under supervisor). There you can add packages to be installed under system_packages: []
            • D
              DenisJ
              @electrik said in node-red-contrib-mysensors release thread:
              system_packages
              I have try to insert in the system_packages like this:
              But it give me errore when start:
              I think I'll make some translate node by my self
              Thanks a lot again
              Denis
              • electrikE
                electrikE
                electrik
                wrote on last edited by electrik
                #31
                Shouldn't it be
                build-essentials
                • D
                  DenisJ
                  build-essentials
                  I try it but it give me same errore.
                  I think that that package must be here in this link like the error log tell
                  Do you have Home Assistant installed ? if yes... do you have this "essentials" installed also ?
                  Thanks again
                  Denis
                  • electrikE
                    electrikE
                    electrik
                    Yes I have home assistant but don't have the build essentials. I did some more reading and it seems like a package of build tools. Perhaps @tbowmo knows which specific one is needed?
                    tbowmoT 1 Reply Last reply
                    • D
                      DenisJ
                      No problem @electrik I have already set the Node-Red to translate my node sensor in human leggibile data :-)
                      And now I can see it like this:
                      All ok and thanks a lot for the help
                      Denis
                      • electrikE electrik
                        tbowmoT
                        tbowmoT
                        tbowmo
                        @electrik
                        When I said that you needed the package "build-essentials" I assumed that you where running on a barebone ubuntu distribution, and not in docker. This complicates things, but it seems that others do have the same issue with node-red and sqlite on home-assistant forum.
                        One solution is given here: https://community.home-assistant.io/t/how-to-get-access-to-sqlite-on-hassio/241439/3
                        As said earlier I do not know anything about the internals in home-assistant and their specific docker / node-red setup.
                        • D
                          DenisJ
                          Thanks a lot @tbowmo
                          Denis
