  3. Double SPI Radio Raspberry Pi
7 Posts 5 Posters 7.6k Views 5 Watching
  • TriXwooDT
    TriXwooDT
    TriXwooD
    wrote on last edited by TriXwooD
    I have connected as an experiment two nrf24l01+ to the raspberry pi (spi enabled), my goal is to change one of the nrf24l01 for a lora or a 433... but since I do not have either yet, two nrf24l01+ it is :-)
    I decided to try spi0.1 (with the cs on pin 26) because of the bluetooth/spi1 stuff...
    The first radio is wired like on the homepage
    The second radio has its MOSI,MISO, SCLK, GND, 3.3v connected on the same wires as the first radio
    And the additional wires to
    IRQ=pin 16
    CE=pin 18
    CS=pin 26
    And 47pF cap between ground and vcc on the radio's (4.7pF does not work even if I wire one radio)
    So I have two MySensor folders configures with
    ./configure --my-transport=nrf24 --my-rf24-ce-pin=18 --my-rf24-cs-pin=26 --my-rf24-irq-pin=16 --spi-spidev-device=/dev/spidev0.1 --spi-driver=SPIDEV --my-port=5004 --my-node-id=15
    ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --spi-spidev-device=/dev/spidev0.0 --spi-driver=SPIDEV
    Anyway although the both run and something got transmitted and received... its kinda not working... individually (one 3.3v disconnected or both connected) they work fine communicating with my vento sensor... so the radio's are fine. (and so are the use of the alternative pins)
    but when both powered, the original pin radio works but the second radio does not (even with 3.3v/ground on other pins) or visa versa...
    when both using mysensors it crashes
    Was kinda hoping somebody could shed a light on why...
    is it the cs line not being low from the other radio? signal too weak?
    interference with packages? ?
    also tested dtoverlay=spi0-cs,cs0_pin=24,cs1_pin=26 and dtoverlay=spi0-hw-cs in the /boot/config.txt to no avail,
    also note with one radio I did not activate the dtparam=spi=on, it still worked...
    2x nrf24l01 is one mysensors gateway and one milight, although I have milight in rflink :-)
    Some logs...
    Controller...
    mysgw: MCO:BGN:INIT GW,CP=RNNG--Q-,VER=2.2.0-beta
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: TSF:MSG:READ,0-0-0,s=0,c=0,t=0,pt=0,l=0,sg=0:
    mysgw: !TSF:MSG:LEN,0!=7
    Reset controller...
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: MCO:BGN:STP
    mysgw: TSF:MSG:READ,15-255-255,s=255,c=7,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:READ,0-0-14,s=14,c=6,t=0,pt=0,l=0,sg=0:
    mysgw: !TSF:MSG:LEN,14!=7
    mysgw: TSF:MSG:READ,255-62-2,s=255,c=7,t=255,pt=0,l=0,sg=0:
    mysgw: !TSF:MSG:PVER,3!=2
    Node 15
    mysgw: MCO:BGN:INIT NODE,CP=RNNN--Q-,VER=2.2.0-beta
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:STATID=15
    mysgw: TSF:SID:OK,ID=15
    mysgw: TSM:FPAR
    mysgw: TSF:MSG:SEND,15-15-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    mysgw: !TSM:FPAR:NO REPLY
    mysgw: TSM:FPAR
    mysgw: TSM:FPAR
    mysgw: TSM:FPAR
    mysgw: !TSM:FPAR:FAIL
    mysgw: TSM:FAIL:CNT=1
    mysgw: TSM:FAIL:DIS
    mysgw: TSF:TDI:TSL
    mysgw: TSM:FAIL:RE-INIT
    mysgw: TSM:INIT
    mysgw: TSM:FPAR
    <reset controller>
    mysgw: TSF:MSG:READ,15-15-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSM:FPAR
    TriXwooDT 1 Reply Last reply
    • TriXwooDT TriXwooD
      IRQ=pin 16
      CE=pin 18
      CS=pin 26
      Some logs...
      Controller...
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      Reset controller...
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: MCO:BGN:STP
      mysgw: TSF:MSG:BC
      Node 15
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:FPAR
      mysgw: TSM:FPAR
      mysgw: TSM:FPAR
      mysgw: TSM:FPAR
      mysgw: TSM:FAIL:DIS
      mysgw: TSF:TDI:TSL
      mysgw: TSM:INIT
      mysgw: TSM:FPAR
      <reset controller>
      mysgw: TSF:MSG:BC
      mysgw: TSM:FPAR
      TriXwooDT
      TriXwooDT
      TriXwooD
      @TriXwooD Update:
      Two radio's (or alternative pins for one radio :-))
      for the nrf24l01
      For Raspberry Pi with 40 pins header (pi zero, pi 3,..)
      Note on post above: I tried spi1.0 instead of spi0.0 and spi0.1 and it works... (cs lines not interfering?)
      Still not sure why did spi0.0 and spi0.1 not work... what did I wrong there? It should be possible to share the mosi/miso/sclk/gnd/3.3v pins... (maybe it is the cs? or ce?... anyway)
      This probably means rfm69 wired correctly and a nrf24l01 will work both at the same time on a pi ;-)
      Can I compile one gateway with both rfm69 and rf24 enabled at the same time, thus not running two gateways?
      For now two gateways running on a pi zero (pi3 with bluetooth not yet tested)
      Step Zero
      Enable spi1 in /boot/config.txt
      sudo nano /boot/config.txt
      dtparam=spi=on
      dtoverlay=spi1-1cs,cs0_pin=36
      First Radio Pin
      Same as Building a Raspberry Pi Gateway page (with irq pin 15!)
      First Radio Configure
      With irq pin 15!
      cd MySensors
      Configuring...
      ./configure --my-transport=nrf24 --my-rf24-irq-pin=15 --spi-spidev-device=/dev/spidev0.0 --spi-driver=SPIDEV --my-port=5003
      make
      Running...
      cd bin
      sudo ./mysgw -d
      Second Radio Pin
      pin 01 3.3v
      pin 33 for irq
      pin 35 miso
      pin 36 cs
      pin 37 ce
      pin 38 mosi
      pin 39 gnd
      pin 40 sclk
      Second Radio Configure
      (in another terminal)
      A copy of the source
      cp -r MySensors MySensorsSecond
      cd MySensorsSecond
      Configuring...
      Note the port is 5004 instead of 5003, you can not run two gateways on the same port
      ./configure --my-transport=nrf24 --my-rf24-irq-pin=33 --my-rf24-ce-pin=37 --my-rf24-cs-pin=36 --spi-spidev-device=/dev/spidev1.0 --spi-driver=SPIDEV --my-port=5004
      make
      Running...
      cd bin
      sudo ./mysgw -d
      it works... Fin!
      currently running openmilight on radio 1 and mysensors on radio 2 ;-)
      mfalkviddM T 2 Replies Last reply
        @TriXwooD Update:
        for the nrf24l01
        Step Zero
        dtparam=spi=on
        First Radio Pin
        With irq pin 15!
        cd MySensors
        Configuring...
        make
        Running...
        cd bin
        sudo ./mysgw -d
        Second Radio Pin
        pin 01 3.3v
        pin 33 for irq
        pin 35 miso
        pin 36 cs
        pin 37 ce
        pin 38 mosi
        pin 39 gnd
        pin 40 sclk
        cd MySensorsSecond
        Configuring...
        make
        Running...
        cd bin
        sudo ./mysgw -d
        it works... Fin!
        @TriXwooD nice work, thanks for sharing!
        About your question; MySensors only supports one transport per instance so you need to compile two gateways.
        • sealS
          sealS
          seal
          @TriXwooD : i can confirm - i succesfully run two radios - rfm69 and nrf24 on RPi - on the spi0 runs rfm69 and on spi1 runs nrf24. Started two separated mysensors gateway on ports 5003 and 5004 and everythng runs fine! :)
            I finally got RFM69 and NRF24 working on the same RPI3 with dietpi running :grin:
              @llegoff @TriXwooD I think it would also worth mentioning that also the install scripts in "MySensorsSecond/initscripts" folder need to be modified if you want the service to get properly registered with the new name
                @TriXwooD Update:
                for the nrf24l01
                Step Zero
                dtparam=spi=on
                First Radio Pin
                With irq pin 15!
                cd MySensors
                Configuring...
                make
                Running...
                cd bin
                sudo ./mysgw -d
                Second Radio Pin
                pin 01 3.3v
                pin 33 for irq
                pin 35 miso
                pin 36 cs
                pin 37 ce
                pin 38 mosi
                pin 39 gnd
                pin 40 sclk
                cd MySensorsSecond
                Configuring...
                make
                Running...
                cd bin
                sudo ./mysgw -d
                it works... Fin!
                toigo
                @TriXwooD said in Double SPI Radio Raspberry Pi:
                dtparam=spi=on
                @TriXwooD : Thank you, this helped me a lot. I had to use a different pin number in /boot/cmdline.txt though for that it matches the pin number given in the configure statement:
                dtparam=spi=on
                dtoverlay=spi1-1cs,cs0_pin=16
                ./configure --my-rf24-cs-pin=36 ...
                Configure wants the BCM pin number (36), but the dtoverlay wants the corresponding GPIO pin number (16).
