  3. NodeManager
  4. Nodemanager: How to control a local output from a local input?
2 Posts 1 Posters 1.0k Views 1 Watching
  • A
    A3V
    I am trying to make a temperature control system that has a temperature sensor and a relay.
    I use an ESP32 and set it op as gateway. The sensor and relay are connected to the ESP32
    The sensor and relay should form a closed loop and should be able to run independently from the (Domoticz) controller.
    I want to use the Nodemanager to be able to track the temperature and relay state.
    In my first test I can read my sensor and I can switch my relay from Domoticz.
    I tried to add some code to the loop() to read the temperature locally and print it to the serial port:
    When I e.g. try to print Tsensor.getChild(0)->getValueString() it throws an error.
    My question: what is the proper way to do this?
    How can I get the sensor value and set the relay?
    Any suggestions are much appreciated
    • A
      A3V
      Reply to myself:
      Looking thought the sources and the forum found out that you can do this using hooks.
      so enabled hooking
      #define NODEMANAGER_HOOKING ON
      and added the reference to the hook to before.
      void before() {
       Tsensor.setMeasureTimerMode(TIME_INTERVAL);   // set timer
       Tsensor.setMeasureTimerValue(1); // interval to 1 sec measurement
       Tsensor.setPostLoopHook(&myfirstHook);
       ..etc.etc...
       nodemanager.before();
      And finally the hook
      void myfirstHook(Sensor* sensor){
        float temperature =  Tsensor.children.get(1)->getValueFloat()
        if (temperature>setpoint) {
              if (Relay.getStatus()==OFF){
              Relay.setStatus(ON);      // switch off
      The error that I got initially was caused by using the wrong child: 0 (it starts from 1).
      I wonder if it is possible to do interval < 1 second?
