  3. OpenHAB
  4. openHAB 4 MySensors Binding
19 Posts 9 Posters 3.9k Views 8 Watching
  • F
    F
    forexsieno
    Hello anybody runing openhab4 with latest bindings (3.3.0) and serial gateway?
    I'm not able to get the bindings active. They are installed but not active.
    diag gives following message:
    Any ideas?
    N 1 Reply Last reply
    • F forexsieno
      Any ideas?
      N
      N
      niccodemi
      wrote on last edited by niccodemi
      @forexsieno I am running OH4 but have migrated MySensors to MQTTGateway. Below example of how to control relays.
      thing file
      Bridge mqtt:broker:Mosquitto "Mysensors MQTT Broker" [host="192.xxx.xxx.xxx", secure=false, port=1883, clientID="Openhab"]
          Thing topic relunderstair "Relay" (mqtt:broker:Mosquitto) {
              Channels:
                  Type switch : relunderstair0101 "LED-stairs" [ stateTopic="mygateway1-out/1/1/0/0/2", commandTopic ="mygateway1-in/1/1/0/0/2", on="1", off="0" ]
      item file
      Switch relunderstair0101  "LED-stairs" { channel="mqtt:topic:Mosquitto:relunderstair:relunderstair0101" }
      • Z zkarolyi
        After changed to develop branch, the make was successfull, but how to get MySensors binding?
        I have found this: https://github.com/tobof/openhab-addons/wiki/Installation but it is for OpenHab 3.
        When I installed the jar, I get this error:
        [WARN ] [org.apache.felix.fileinstall        ] - Error while starting bundle: file:/usr/share/openhab/addons/org.openhab.binding.mysensors-3.1.0.jar
        org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.mysensors [265]
          Unresolved requirement: Import-Package: org.apache.commons.lang; version="[2.6.0,3.0.0)"
        How to get a new binding?
        How to solve this?
        ChachaC
        ChachaC
        Chacha
        Hi @zkarolyi
        You can download the 3.2.0-Snapshot version from here:
        https://forum.mysensors.org/post/110626
        It is working in OH3 and OH4!
        There is also a 3.3.0-Snapshot version, but it doesn't work in OH4.
        See my post here: https://forum.mysensors.org/post/113864
        • Z zkarolyi
          How to solve this?
          C
          C
          CyborgAndy
          wrote on last edited by CyborgAndy
          Hi @zkarolyi
          Download org.openhab.binding.mysensors-4.0.4-SNAPSHOT.jar from my Google Disk and try it.
          I only tested as a MySensors MQTT Gateway
          kerberosK Z 2 Replies Last reply
          • C CyborgAndy
            Hi @zkarolyi
            kerberosK
            kerberosK
            kerberos
            Hi @CyborgAndy
            many thanks for providing the binding update for MySensors 4.0.4! I upgrade my OpenHAB 3.4.4 a few minutes ago to 4.0.4 successfully with your binding update. I use a USB connected serial-gateway. The OpenHAB manual installation upgrade works perfect. I need to do afterwards the following steps in the Karaf console, to get the gateway online again, after the update:
            feature:install openhab-transport-serial
            feature:install openhab-core-io-transport-mqtt
            feature:install openhab-core-io-transport-serial-javacomm
            Many thanks again!
            kerberos
            • kerberosK
              kerberosK
              kerberos
              As x-mas gift :santa: works with OpenHAB 4.1 as well...
              • C CyborgAndy
                Hi @zkarolyi
                Z
                Z
                zkarolyi
                Hi @CyborgAndy
                Really thank you for this jar so much, I finally managed to bring my sensors to life!
                A thousand thanks and gratitude!
                zkarolyi
                • A
                  adds666
                  As an OH3 user looking to upgrade, I'm wondering, do all of the binding points from OH to mysensor nodes, children etc work after upgrade and loading this new .jar?
                  Or do I have to re-build everything in OH?
                  kerberosK 2 Replies Last reply
                  • A adds666
                    kerberosK
                    kerberosK
                    kerberos
                    • A adds666
                      kerberosK
                      kerberosK
                      kerberos
                      Hi @adds666
                      I did in between the switch from 2.5.12 to 3.4.4 a change from pure textual configuration in 2.5.12 to a UI configuration in 3.4.4. This requires some homework. Can't remember beside the exchanged mysensors binding files anything else to upgrade to 4.0.4 from 3.4.4 and finally to current 4.1.1. Keep in mind, I use a OpenHAB manual installation on a non-Debian Linux system, not openHABian. This may have an influence, but I don't expect any hiccups.
                      kerberos
