  3. OpenHAB
  4. OH3 - MySensors Binding
135 Posts 34 Posters 36.0k Views 40 Watching
    mbedarff
    It seems that still some people are interested in this MySensors binding being updated further.
    I'm currently using in openHAB 3.2 the version that @vores8 kindly provided in post #109 on 21/07/2022, based on the source fork from @ncollins (https://github.com/nikolac/openhab2-addons/tree/mysensors-oh3-migration).
    Now I noticed that there seems to be a bug in the ethernet gateway with reconnecting after the TCP connection is lost. The loss of the connection is detected, but it is not disconnected and re-established afterwards.
    I would like to look at this in the " current" source code and if possible develop a fix and provide it.
    Therefore the question to the community and especially to @vores8 and @ncollins, if the source code adapted to OH 3.2 or now to OH 3.3 has been uploaded by you to GitHub. If so, under which repository and branch? If not, please catch up on it for us so that we can merge the adaption you have made to the source and possibly bundle and ensure further development.
    Thanks a lot in advance! :face_with_cowboy_hat:
    N C 2 Replies Last reply
    • M mbedarff
      N
      N
      ncollins
      @mbedarff good question. Seems @CyborgAndy is keeping the addon alive? If so, @CyborgAndy are you publishing your changes to a public branch/fork?
      • F forexsieno
        just tested OH3 (3.1.0) on PI3 with mysensors openhab binding (org.openhab.binding.mysensors-3.2.0-SNAPSHOT) in the link provided by vores8.
        feature:install openhab-transport-serial and feature:install openhab-core-io-transport-mqtt. done. It's all up and running . bundle:list shows all active.
        But the "MySensors Serial Gateway" which I intend to use in OH3 will not keep ONLINE.
        It always goes back to offline...
        11:48:29.035 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge mysensors:bridge-ser:6e5dca16a9 DONE!
        11:48:29.035 [DEBUG] [ocol.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB1 [baudRate:115200]
        11:48:29.045 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from OFFLINE to ONLINE
        11:48:29.062 [ERROR] [ocol.serial.MySensorsSerialConnection] - Exception found
        java.lang.IllegalStateException: Serial Port Identifier not found
                at org.openhab.binding.mysensors.internal.protocol.serial.MySensorsSerialConnection.establishConnection(MySensorsSerialConnection.java:59) [bundleFile:?]
                at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.connect(MySensorsAbstractConnection.java:145) [bundleFile:?]
                at org.openhab.binding.mysensors.internal.protocol.MySensorsAbstractConnection.run(MySensorsAbstractConnection.java:124) [bundleFile:?]
                at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515) [?:?]
                at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
                at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
                at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) [?:?]
                at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) [?:?]
                at java.lang.Thread.run(Thread.java:829) [?:?]
        11:48:29.073 [DEBUG] [ors.internal.gateway.MySensorsGateway] - MySensorsGateway connection status update -connected: false
        11:48:29.077 [DEBUG] [s.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
        11:48:29.080 [INFO ] [hab.event.ThingStatusInfoChangedEvent] - Thing 'mysensors:bridge-ser:6e5dca16a9' changed from ONLINE to OFFLINE
        11:48:29.081 [DEBUG] [ysensors.internal.event.EventRegister] - Listener org.openhab.binding.mysensors.discovery.MySensorsDiscoveryService@b2d6b0 not present, cannot remove it
        11:48:29.086 [DEBUG] [ensors.handler.MySensorsBridgeHandler] - Connection status mysensors:bridge-ser:6e5dca16a9 updated to false
        11:48:29.090 [DEBUG] [sensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0,4]
        11:48:29.095 [ERROR] [ocol.serial.MySensorsSerialConnection] - Failed connecting to bridge...next retry in 10 seconds (Retry No.:0)
        any ideas?
        Duncan PullenD
        Duncan PullenD
        Duncan Pullen
        @forexsieno Did you solve this one?
        I'm still getting the same error.
        Using 3.3.0-SNAPSHOT
        2022-08-08 02:21:23.200 [ERROR] [col.serial.MySensorsSerialConnection] - Exception found
        • M mbedarff
          C
          C
          CyborgAndy
          Hi.
          @mbedarff I fix gateway connection checking issue.
          You can download the fixed version from my Google Disk
          @mbedarff @ncollins I published all changes to GitHub, "mysensors-binding-addon" branch.
          @forexsieno I tested my 3.3.0-SNAPSHOT in different environments (Arduino Nano as serial gateway, OH 3.3 installed on Windows 10 and Ubuntu Server 20.04) and did not find such a problem.
          D od1O 2 Replies Last reply
            mbedarff
            @CyborgAndy Glad to hear, that you have published all your fixes and upgrades to GitHub! So we have a current source code base to continue development or for debugging. :+1:
            Thank you for the gateway connection fix! I just upgrade my OH instance from 3.2 to 3.3 and successfully tested your snapshot. :smiley:
            Have a nice weekend!
            • N
              N
              niccodemi
              After upgrading OH from 3.2.0 to 3.3.0 and placing latest Mysensors binding (3.3.0-SNAPSHOT) into addon folder I can only get it to "Installed" status but not "active".
              Any advise how to remove following issues?
              openhab> feature:install openhab-transport-serial
              openhab> feature:install openhab-core-io-transport-mqtt
              openhab> diag 291
              openHAB Add-ons :: Bundles :: MySensors Binding (291)
              Status: Installed
              Unsatisfied Requirements:
              osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mqtt.handler)"
              osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.action)"
              osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.config)"
              osgi.wiring.package; filter:="(osgi.wiring.package=org.openhab.binding.mysensors.factory)"
              Declarative Services
              • C CyborgAndy
                Hi.
                daanjjansen
                @CyborgAndy work perfectly here.
                Thanks for you effort!
                • jerseyguy1996J
                  jerseyguy1996J
                  jerseyguy1996
                  @CyborgAndy @vores8 and @TimO and everyone else that worked on getting this binding to work on OH3, you guys are rockstars. I fubar'd my OH2 installation and decided that i might as well upgrade to OH3. I'm so glad that the mysensors binding works with it. I'm running a Raspberry Pi Serial Gateway which amazingly also installed with only a few minor hick-ups. Thank you all so much!
                  • C CyborgAndy
                    Hi.
                    od1O
                    od1O
                    od1
                    @CyborgAndy said in OH3 - MySensors Binding:
                    Is it normal than the add-on is not displayed on the official listing available through the UI of openHAB 3.3.0?
                    • V vores8
                      i've managed to build new version from the sources found here https://github.com/nikolac/openhab-addons/tree/mysensors-oh3-migration
                      So far, so good - working with the latest OH 3.1.0
                      please download from https://disk.yandex.ru/d/Yq3gn8N7tXSQxA
                      ChachaC
                      ChachaC
                      Chacha
                      I've upgraded to OH4 and tried Mysensors binding 3.3.0-SNAPSHOT. It fails to load with error:
                      Unresolved requirement: Import-Package: org.openhab.binding.mqtt.handler
                      However 3.2.0-SNAPSHOT works perfectly with OH4!!!
                      You can download it from this post:
                      @vores8 said in OH3 - MySensors Binding:
                      Install instructions: https://github.com/tobof/openhab-addons/wiki/Installation
                      C 1 Reply Last reply
                      • ChachaC Chacha
                        C
                        C
                        CyborgAndy
                        Hi @Chacha
                        Download org.openhab.binding.mysensors-4.0.4-SNAPSHOT.jar from my Google Disk and try it.
                        I only tested as a MySensors MQTT Gateway
                        kerberosK 1 Reply Last reply
                        • C CyborgAndy
                          Hi @Chacha
                          kerberosK
                          kerberosK
                          kerberos
                          Hi @CyborgAndy
                          many thanks for providing the binding update for MySensors 4.0.4! I upgrade my OpenHAB 3.4.4 a few minutes ago to 4.0.4 successfully with your binding update. I use a USB connected serial-gateway. The OpenHAB manual installation upgrade works perfect. I need to do afterwards the following steps in the Karaf console, to get the gateway online again, after the update:
                          feature:install openhab-core-io-transport-serial-javacomm
                          Many thanks again!
                          kerberos
