  3. RS485 transmit errors
4 Posts 3 Posters 1.4k Views 3 Watching
  • sebastiengS Offline
    sebastiengS Offline
    sebastieng
    I am trying to setup a RS485 gateway on a raspberry with an arduino node.
    Raspberry gateway is build with
    ./configure  --my-gateway=ethernet --my-port=8011 --my-transport=rs485 --my-rs485-serial-port=/dev/ttyAMA0 --my-rs485-de-pin=37
    The arduino sketch is configured with
    #define MY_RS485
    #define MY_RS485_DE_PIN 2
    #define MY_BAUD_RATE 9600
    #define MY_NODE_ID 2
    On each RS485 I have a 120 ohm resistor. The arduino and the raspberry are very close so the wires are short
    The parent request from the node to the gateway fails. I have added extra logging on each side, and I see following issue
    • the parent request is received by the gateway
    • but the response to the node is corrupted.
    The gateway write following bytes
    • 1 -> SOH
    • 2 -> destination node
    • 0 -> source address
    • 88 -> command
    • 8 -> message length
    • 2 -> STX
    The node receives
    • 1 -> SOH
    • 65534-> destination node -> ERROR
    • 65496-> command-> ERROR
    • 2 -> STX
    As you can see some bits are corrupted
    Expected destination node =2 (in binary 0000 0000 0000 0010), while we received 65534 (in binary 1111 1111 1111 1110). The leading bits are 1 instead of 0
    Same issue about command byte.
    It is 100% reproductible, this message is always received with same values so I don't think it is caused by noise or something like that.
    Any idea about the root cause?
    F 1 Reply Last reply
    • sebastiengS sebastieng
      #define MY_RS485
      • 1 -> SOH
      • 88 -> command
      • 2 -> STX
      The node receives
      • 1 -> SOH
      • 2 -> STX
      F Offline
      F Offline
      fsgraz
      @sebastieng too much load ? one 120ohm on the far one should be enough
        sebastiengS Offline
        sebastieng
        FYI, I have found my error
        The description of my setup was not totally correct, I don't use an arduino but a atmega328p standalone.
        The root cause was the use of the internal oscillator, it is not enough accurate. I am now using an external quarz and it is working fine
        OldSurferDudeO 1 Reply Last reply
          OldSurferDudeO Offline
          OldSurferDude
          @sebastieng Thanks for letting us and future readers know.
          -OSD
