  3. HumiditySensor code does not compile
3 Posts 2 Posters 2.7k Views 1 Watching
  • P
    P
    phil83
    Hi everyone,
    I tried to compile the code for the HumiditySensor but it does not work. I downloaded the latest Arduino-master from Github, added all libraries but when I compile the code of the HumiditySensor, I get this answer:
    HumiditySensor.cpp.o: In function loop': /Users//Desktop/Desktop/HumiditySensor.ino:38: undefined reference to DHT::getTemperature()'
    /Users//Desktop/Desktop/HumiditySensor.ino:51: undefined reference to DHT::getHumidity()' HumiditySensor.cpp.o: In function setup':
    /Users//Desktop/Desktop/HumiditySensor.ino:22: undefined reference to `DHT::setup(unsigned char, DHT::DHT_MODEL_t)'
    I tried other sensors (for example distance) and they compile and work.
    I'm using a Mac, any other things of relevance?
    Thanks a lot,
    Philipp
    • P phil83
      Hi everyone,
      Thanks a lot,
      Philipp
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @phil83
      compliles fine for me... Arduino Version 1.6.3; my sensors version 1.4 (latest release)
      you have the DHT library in your arduino library folder:
      Code:
      #define CHILD_ID_HUM 0
      #define CHILD_ID_TEMP 1
      DHT dht;
      float lastTemp;
      float lastHum;
      boolean metric = true;
        gw.begin();
        gw.sendSketchInfo("Humidity", "1.0");
        if (isnan(temperature)) {
          lastTemp = temperature;
          if (!metric) {
          Serial.print("T: ");
        if (isnan(humidity)) {
            lastHum = humidity;
            Serial.print("H: ");
            Serial.println(humidity);
      • P
        P
        phil83
        @BulldogLowell I just reinstalled arduino and now it is working... thank you for testing and telling me!
