  3. INA219 DC Current Sensor
ina219
23 Posts 14 Posters 21.0k Views 8 Watching
    A Former User
    Very interesting, I would like to follow!
    • jeylitesJ
      jeylitesJ
      jeylites
      Has anyone made any progress implementing the AC current sensor or is there a My Sensor plugin?
      N 1 Reply Last reply
      • jeylitesJ jeylites
        N
        N
        niccodemi
        +1 I would be also interested in AC current sensor.
          Mrlynx
          I have some ACS712 current sensors on order.
          They are easy to use as they give a voltage that corresponds to the current flowing through it.
          I am planning to use them to measure current in my LED pwm-dimmer.
          I am going to power them with old laptop charger ~18V and limit current depending on length of led-strip.
          http://www.sa2avr.se
          • N
            N
            NotYetRated
            Just ordered a 100A sensor, going to look to tackle this sometime early January. Will post details if no one else has by then.
              mainali
              I am using ACS712 current sensor with the relay actuator code to sense if someone has manually switched on the light from the physical switch mounted on the walls. If I can help ping me.
              chatainsimC 1 Reply Last reply
              • M mainali
                chatainsimC
                chatainsimC
                chatainsim
                Hello @mainali
                Can you provide more details regarding the ACS712 current sensor ?
                Maybe a drawing on ho to connect to the arduino nand the sketch ?
                  mainali
                  wrote on last edited by mainali
                  I am using a two way switch to control my device. The idea is to control the state from arduino as well as physical switch parallely.
                  Physical switch ON, Arduino can switch it OFF
                  Arduino switches it ON, Physical switch whatever be the state on push should switch it OFF.
                  I have used the Relay actuator example code from mysensor and little more code which I found in arduino forum.
                  I am not able to use the plugin to embed the code, anyways the following is the code.
                  // Example sketch showing how to control physical relays.
                  // This example will remember relay state even after power failure.
                  #define RELAY_1 2 // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                  #define RELAY_2 3
                  #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                  #define RELAY_ON 1 // GPIO value to write to turn on attached relay
                  #define CHILD_ID 1
                  #define CURRENT_SENSOR A0 // Analog input pin that sensor is attached to
                  MyMessage msg(CHILD_ID, V_TRIPPED); //Using this as the message to report the physical switch on status
                  float amplitude_current; //amplitude current
                  float effective_value;
                  bool switch_1_on;
                  int count = 0;
                  gw.begin(incomingMessage, 21, true);
                  gw.sendSketchInfo("Relay with current sensor", "1.0");
                  pins_init();
                  // Fetch relay status
                  gw.present(sensor, S_LIGHT);
                  pinMode(pin, OUTPUT);
                  digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
                  int sensor_max;
                  sensor_max = getMaxValue();
                  Serial.print("sensor_max = ");
                  Serial.println(sensor_max);
                  //the VCC on the Grove interface of the sensor is 5v
                  amplitude_current=(float)(sensor_max-512)/10245/1851000000;
                  effective_value=amplitude_current/1.414;
                  //minimum_current=1/10245/1851000000/1.414=18.7(mA)
                  //Only for sinusoidal alternating current
                  Serial.println("The amplitude of the current is(in mA)");
                  Serial.println(amplitude_current,1);//Only one number after the decimal point
                  Serial.println("The effective value of the current is(in mA)");
                  Serial.println(effective_value,1);
                      if (count == 0 && amplitude_current > 30) {
                         switch_1_on = true;
                        Serial.println("physical switch on");
                        gw.send(msg.set(switch_1_on?"1":"0"));
                        count = 1 ;
                      else {
                        count = 0 ;
                  if (message.type == V_FAN) {
                  Serial.println("Message arrived for FAN");
                  for(int i=4 ; i<=7; i++) {
                  digitalWrite(i,0);
                  if (message.type==V_LIGHT) {
                  // Change relay state
                  // Store state in eeprom
                  void pins_init()
                  pinMode(CURRENT_SENSOR, INPUT);
                  /Function: Sample for 1000ms and get the maximum value from the S pin/
                  int getMaxValue()
                  int sensorValue; //value read from the sensor
                  int sensorMax = 0;
                  uint32_t start_time = millis();
                  while((millis()-start_time) < 1000)//sample for 1000ms
                  sensorValue = analogRead(CURRENT_SENSOR);
                  if (sensorValue > sensorMax)
                  /record the maximum sensor value/
                  sensorMax = sensorValue;
                  return sensorMax;
                  jeremushkaJ 1 Reply Last reply
                  • chatainsimC
                    chatainsimC
                    chatainsim
                    Thanks !
                    • epierreE
                      epierreE
                      epierre
                      has anyone made something usefull with the ACS712 yet ?
                      z-wave - Vera -> Domoticz
                      • M mainali
                        #define RELAY_2 3
                        #define CHILD_ID 1
                        bool switch_1_on;
                        int count = 0;
                        pins_init();
                        int sensor_max;
                               switch_1_on = true;
                              count = 1 ;
                            else {
                              count = 0 ;
                        digitalWrite(i,0);
                        void pins_init()
                        int getMaxValue()
                        int sensorMax = 0;
                        return sensorMax;
                        jeremushkaJ
                        jeremushkaJ
                        jeremushka
                        @mainali said in INA219 DC Current Sensor:
                        I am building similar system. However, i am facing a lot of difficulties to make the ACS712 working. I have tried your code as well without success. The effective value of the current is always 0 mA even if the light is ON.
                        For the moment, i am testing with 5V current and i switch on a LED. maybe the current is too low to make working my 20A ACS712?
                        If anyone has some ideas, it will be very greatful :) Thanks a lot.
