  3. How low can arduino can go?
powerarduino pro minlow consumption
29 Posts 10 Posters 25.1k Views 5 Watching
  • funky81F funky81
    @iask I haven't upload my latest door sketch to my node yet. But if I'm using above sketch, idle 4uA and around 18mA while transfer.
    Do you have any issues like me before?
    I
    I
    iask
    @funky81 Well I am not sure what else to try to get lower than 11.5uA. If you are getting 4uA then it's possible. I will have to try your sleep method
    void sleep(){
       // disable ADC
      ADCSRA = 0;
      // clear various "reset" flags
      MCUSR = 0;
      // allow changes, disable reset
      WDTCSR = bit (WDCE) | bit (WDE);
      // set interrupt mode and an interval
      WDTCSR = bit (WDIE) | bit (WDP3) | bit (WDP0);    // set WDIE, and 1 second delay
      wdt_reset();  // pat the dog
      set_sleep_mode (SLEEP_MODE_PWR_DOWN);
      noInterrupts ();           // timed sequence follows
      sleep_enable();
      // turn off brown-out enable in software
      MCUCR = bit (BODS) | bit (BODSE);
      MCUCR = bit (BODS);
      interrupts ();             // guarantees next instruction executed
      sleep_cpu ();
      // cancel sleep as a precaution
      sleep_disable();
    currently I am using
    gw.sleep(INTERRUPT,CHANGE, 0);
    funky81F 1 Reply Last reply
    • I iask
      void sleep(){
         // disable ADC
        ADCSRA = 0;
        MCUSR = 0;
        sleep_enable();
        MCUCR = bit (BODS);
        sleep_cpu ();
        sleep_disable();
      funky81F
      funky81F
      funky81
      @iask how is the result?
      • T
        Tibus
        I use the @funky81 's sleep method but the nrf doesn't go to sleep so I draw 14ma. When I use the gw.sleep method, I draw +-26ua. Is it possible to go below? (without the nrf, my own pcb with atmega328 go to 5ua in sleep mode with your function (doesn't work with gw.sleep because it's a test without the nrf ;D)
        • T Tibus
          funky81F
          funky81F
          funky81
          wrote on last edited by funky81
          #23
          @Tibus do you have other nrf to try? I'm affraid you're using fake nrf.
          30% of my nrf (out of 10), are fake...
          one more thing, sleep method in above post dont turn off nrf radio while sleep.
          you can try gw.sleep() if you want turn off nrf radio while sleep (MyGateway gw)
          • T
            Tibus
            yes, when I use de gw.sleep it works great but I can't go lower than 26ua+-. My test with your function draw 14ma because the nrf doesn't go to sleep... But is there a method to go lower than 26ua with the nrf? I'm already verry happy of the 26ua but if I can go lower, it would be even better ;D
            Do you things it's because I use fake nrf? where can i bought real nrf? The one I use is from electrodragon.
            • T Tibus
              funky81F
              funky81F
              funky81
              @Tibus my suggestion is that try other nrf radio.
              Right now I can low as 10uA while sleeping
              • T
                Tibus
                ok thanks
                • E
                  E
                  ericvdb
                  What do you guys use to measure such low currents?
                  • E ericvdb
                    funky81F
                    funky81F
                    funky81
                    Hi @ericvdb , you can use multi tester like in this link....
                    • B
                      B
                      brolly759
                      This is an old thread but Tibus, the problem I had was exactly yours with 26uA. I had to downgrade my Arduino software to 1.0.6 . Then I got normal numbers 3uA.
