  3. Error flashing bootloader to atmega328p au board I design
15 Posts 4 Posters 16.7k Views 3 Watching
  • GertSandersG GertSanders
    @Mickey Nice board ! Just a question: why did you add the 56K (R1) ?
    The schematic does not show U3, is the schematic complete ?
    Mickey
    U3 is not relevant to topic but yes the schematic is short u3 which is ADXL345
    Also I used 56k because I didnt find 47k in my stock...(is it a problem?)
    • GertSandersG
      GertSandersG
      GertSanders
      @Mickey I'm just wondering why you would need a pull up of 56K, since the internal pullup resistor of those pins in the atmega328 is about the same value (somewhere between 30K and 50K according to datasheet). I see no need for R1.
        Mickey
        @GertSanders said:
        @Mickey I'm just wondering why you would need a pull up of 56K, since the internal pullup resistor of those pins in the atmega328 is about the same value (somewhere between 30K and 50K according to datasheet). I see no need to R1.
        When I design the board I use the sensebender micro as reference. I did ask my self is it really needed but Deside to go with that but its not part of the problem...
        • GertSandersG
          GertSandersG
          GertSanders
          @Mickey Correct, if electrically your board is OK, and you do not have a spare working Arduino board, you will need to use an AVR programmer to flash the bootloader.
            Mickey
            What is correct? I use an Avr programmer - Usbasp as I mention . I have a few working arduinos is it better to use them as a programmer? Can you tell me what values should I need to the fueses?
            • GertSandersG
              GertSandersG
              GertSanders
              @Mickey As I do not have a AVR programmer, I flash my processors with my old Arduino. The fuses I use are the same I have in one of the earlier messages.
              For me, the easiest way to work was to extend the sketch made by GAMMON (Atmega_Board_Programmer), but how I changed that sketch is a bit complicated to explain in a mail. I basically converted my bootloader HEX file into an ascii string, which I added in a '.h' file to his sketch. Then I hacked his code so that when I choose atmega328 I get my boatloader, instead of the default.
              GAMMON's sketch also reprograms the fuses.
              In his sketch I started with this change:
              //#define USE_ATMEGA168 true
              //#define USE_ATMEGA328P_8M true
              #define USE_ATMEGA328P_8Mi true
              //#define USE_ATMEGA328P true
              another piece of code I changed was this:
              // ATmega328P
              { { 0x1E, 0x95, 0x0F },
              0x7E00, // start address
              #if USE_ATMEGA328P_8Mi
              optiboot_atmega328_8Mhz_B0_hex, // loader image
              sizeof optiboot_atmega328_8Mhz_B0_hex,
              // 0xE2, // fuse low byte: internal clock, max start-up time
              0xFF, // fuse low byte: external clock, max start-up time
              0xDE, // fuse high byte: SPI enable, boot into bootloader, 512 byte bootloader
              0x07, // fuse extended byte: brown-out detection off
              atmega328_optiboot,
              sizeof atmega328_optiboot,
              0x05, // fuse extended byte: brown-out detection at 2.7V
              0x2F
              }, // lock bits: SPM is not allowed to write to the Boot Loader section.
              I also added the attached '.h' file to his sketch:
              optiboot_atmega328p_8M_B0.h
              For me this is the fastest and most reliable way to flash my processors.
                @Mickey: I think you have to change fuses. What I usually do is:
                • program fuses with : avrdudess+usbasp.
                  you can check your fuse here: http://www.engbedded.com/fusecalc/
                • Then copy atmega boards files, and you can use arduino ide to upload your bootloader, still with usbasp of course.
                • Finally, you can bootload with ftdi.
                But, adding atmega board files doesn't reprogram the fuses if I remember right. If it doesn't work like I explained, then maybe hardware connection..
                On my side, I prefer usbasp/avrspi. it's very easy too, I think :smiley: most important is that it works :wink:
                • scalzS scalz
                  Mickey
                  wrote on last edited by Mickey
                  Hi
                  How can I change fuses if the avr programmer doesn't even detect the chip? when I run
                  avrdude -b 19200 -c usbasp -p m328p -v
                  I get
                  AWIA 1 Reply Last reply
                  • GertSandersG
                    GertSandersG
                    GertSanders
                    Double check the connections. If the programmer does not see your processor, there is not much more that can be done on the software side. First check hardware again.
                    • M Mickey
                      Hi
                      I get
                      AWIA
                      AWIA
                      AWI
                      @Mickey Maybe you need to disconnect the radio. I am not able to use SPI programming with the radio connected...
                      • AWIA AWI
                        Mickey
                        I also thought that but I made another board without the radio with the same error.
                        I needed a fast way to figure it out so I desolder the atmega from an old arduino nano board but before I did it I read the fuses and got this:
                        then I soldered the virgin series I have and read the fuses:
                        so first of all It appears that I need the chips first hook up to an external clock just to be able to read the fuses and then change them.
