  3. Domoticz
  4. Pulse Powermeter, set to the same value as real power meter?
16 Posts 6 Posters 9.3k Views 3 Watching
  • K
    K
    koen01
    I think you have the same challenge as I do. See my pulse water meter topic here:
    http://forum.mysensors.org/topic/2101/pulse-water-meter
    • F
      F
      fleinze
      I updated the pulse value in the domoticz.db file with an external database editor, then restarted the sensor as it requests the pulse count from domoticz on startup.
      But there should be a better way...
      • alexsh1A
        alexsh1A
        alexsh1
        Is there any other way to set the real meter value please? I know some people are changing the sketch to add the value in the beginning to match the meter value.
        I do not understand why JSON is not working.
        @fleinze what DB editor did you use please?
        • sundberg84S
          sundberg84S
          I think its possible to send the V_Var1 on startup.
          Then you need to wait 24h (new day) since some values are the sum of that day (From midnihgt).
          Then you can remove V_VAR1 on startup och instead request it from Domoticz.
          Br
          Andreas
          • alexsh1A
            alexsh1A
            alexsh1
            Thanks @sundberg84
            @fleinze Which value did you update in the DB please?
              Slorf
              Stop Domoticz
              Copy de Databse to your pc
              ( make a backup of the database )
              Use SQLLite Expert Personal to edit the database
              Go to "Device Status" and look for the row on the right side with your device
              Double click on the row, goto "SValue", edit this, click ok, clock ok again.
              Then the most important one:
              On the leftside goto "MySensorsVars", click on it, on the right side you will see your MySensors devices, click on your device and edit the "Value"
              Both SValue and Value should be the same and match whatever your whatever meter reads when you start using your sensor.
              Regards
              Alex
              alexsh1A 1 Reply Last reply
              • S Slorf
                Stop Domoticz
                Regards
                Alex
                alexsh1A
                alexsh1A
                alexsh1
                @Slorf - Many thanks!
                  Slorf
                  After a couple of days troubleshooting I found a way !!
                  Steps:
                  • Clear the Eeprom of your sensor ( there is a sketch for this in the mysensors librairy ), this because your sensor keeps the readings in Eeprom
                  • Reload your sketch
                  • Connect the Sensor to Domoticz, it will be seen in Domoticz as a new device.
                  • When the sensor starts it has a cleared Eeprom, it will request the values from the gateway, the gateway will request them from Domoticz
                  • Connect the sensor to whatever you want to read, and wait for the first readings in domoticz
                    ( when the sensor sends it first reading it will replace the values it got from the gateway with the values it has in it's own Eeprom, thus sending a wrong reading, when we clear the Eeprom we don't have this problem.
                  • Backup the domoticz database from domoticz
                  Then use the procedure from my previous post:
                  Double click on the row, goto "SValue", edit this: it should read something like:
                  000.000;3424000 ( the first part is todat usage, the second part total usage
                  click ok, click ok again.
                  Goto Meter on the leftside, sort the "device row id" find your device id and edit the value here to ( it could be that when you have a new sensor there is no entry here )
                    Slorf
                    Mhhhhh.. forget what I wrote, I still get strange readings.
                    Next try will be to clear the gateway's Eeprom
                    • sundberg84S
                      sundberg84S
                      @Slorf You are aware that some values are calculated on a daily basis? I think you can do as you said and manually change the db but you need to wait 24h (or after next midnight) to get the daily values right.
                        Slorf
                        @sundberg84
                        I did that, but it did not help.
                        From my observations sofar:
                        • Changed the settings in the Domoticz database ( for example: changed the value of the my solarpanels to 3424000 kwh )
                        • Waited a couple of days
                        • Erased the Eeprom of the sensor
                        • Connected the sensor
                        • Domoticz shows 3424.000 kwh as it should be
                        • On the first watt read by the sensors Domoticz shows 3642.150 kwh, this value is nowhere
                          to be found in the Domoticz database.
                        So the next thing is to erase the Eeprom of the Gateway, it might be that the Gateway still holds a wrong value from testing.
                        Regards
                        Alex
                        • sundberg84S
                          sundberg84S
                          @Slorf
                          and with "connected the sensor" you mean retrieve the V_VAR1 and set kwg as this value as well?
                          This is my example from V_RAIN and a counter (V_VAR1)
                          Example with a bucketsize of 0.5 mm:
                          (V_RAIN counts on, counter counts on)
                          Day1 ................ Day2
                          V_rain 0.5 ............ V_rain 2.5
                          V_rain 1.0 ............ V_rain 3.0
                          Counter 1.0 ............ Counter 3.0
                          V_Rain 1.5 ............ V_Rain 3.5
                          V_Rain 2.0 ............ V_Rain 4.0
                          Counter 2.0 ............ Counter 4.0
                            Slorf
                            @sundberg84
                            With connecting I mean power it on and have it count.
                            I am wondering why the sensor should get the readings from the gw ?, the only thing I want is the sensor to send a signal to Domoticz for every pulse it detects
                            Alex
                            • sundberg84S
                              sundberg84S
                              @slorf Im pretty sure it does not get any reading from the gateway, its stored only in domoticz database or if you have manually entered some value in the sketch.
                                Slorf
                                @sundberg84
                                I cleared the Eeprom from both gateway and sensor, then set the V_VAR2 on the sensor on a start value for example 5555
                                I changed the sketch not to request any values from the gateway
                                When the sensor gets it's first reading it's registered in Domoticz with the value of 5556 ( 5555 + first reading of 1 )
                                Now I have to questions:
                                After the first reading ( 5556 ) is send to Domoticz I can change the sketch back to where it requests the reading form the gateway ?
                                But if the sensor for example quits working for a week, then I have to change the V_VAR2 on the sensor again, which is not very handy ?
                                Thanks for the help !!
                                Alex
                                12.5k
