  3. SI7021 Multisensor - first try
multisensorsi7021
26 Posts 9 Posters 23.9k Views 6 Watching
  • n3roN n3ro
    Big THX,
    now i have understand how to use the si7021 :)
    Reading works great!
    But the sleeping current is very high ~1500uA
    R
    R
    riataman
    wrote on last edited by riataman
    @n3ro said:
    Big THX,
    If you got this breakout: http://www.aliexpress.com/item/Industrial-High-Precision-Si7021-Humidity-Sensor-with-I2C-Interface-for-Arduino/32340228487.html?ws_ab_test=searchweb201556_1_79_78_77_80,searchweb201644_5,searchweb201560_1 it includes a 3.3v regulator and level shifting so you can actually use the sensor with a 5v arduino but it consumes quite a bit of current (60uA in the ones I got) even when idling.
    What I did was desolder the regulator and solder a small wire to bypass it (sorry for potato quality pic).
    Then I ordered this breakout for future nodes: http://www.aliexpress.com/item/New-HTU21D-Temperature-and-Humidity-Sensor-Module/1970355069.html?ws_ab_test=searchweb201556_1_79_78_77_80,searchweb201644_5,searchweb201560_1 that one doesn't seem to include any additional circuits (other than the pull up resistor and safety? resistor).
    n3roN M 2 Replies Last reply
    • korttomaK korttoma
      Speaking of the Si021, has anyone tried to use 2 Si7021 sensors on the same node?
      R
      R
      riataman
      Since the i2c address is hardcoded I see two ways of doing this:
      1. Power the two sensors from gpio pins (instead of connecting them to vcc, connect each to a separate gpio pin), when you want to read one sensor you put one high and the other low. I'm not really sure if this will work at all.
      2. Use a soft i2c library like this one: https://github.com/todbot/SoftI2CMaster that way you have two sets of i2c pins. I'm pretty sure this one should work.
      • R riataman
        @n3ro said:
        Big THX,
        n3roN
        n3roN
        n3ro
        @riataman said:
        with a 5v arduino
        Hey =)
        the operating voltage of this component is 1.9 to 3,6 v. not 5v =)
        But the idea to remove the regulator to save a little bit energy is cool. i will try it =)
        pimatic + MySensors + Homeduino + z-way
        https://github.com/n3roGit/MySensors_n3ro
        R 1 Reply Last reply
        • n3roN n3ro
          @riataman said:
          with a 5v arduino
          Hey =)
          R
          R
          riataman
          @n3ro said:
          @riataman said:
          with a 5v arduino
          Hey =)
          That's true for the individual SI7021 IC, but in the breakout the regulator steps down the voltage to 5v and additional circuitry does 3.3<->5v level shifting. I have tested that particular breakout with a 5v arduino and it works just fine.
          • dakkyD
            dakkyD
            dakky
            does the sleeping current come down to an acceptable level when removing the regulator? 1500uA is quite much for a battery powered node.
            Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
            Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
            Software: MySensors 2.0development
            • n3roN
              n3roN
              n3ro
              wrote on last edited by n3ro
              #22
              @dakky said:
              1500uA
              The sleeping current is ~240uA.
              But it's possible to tune it a little bit more.
              • dakkyD
                dakkyD
                dakky
                hmm ok 240uA is better of course, but still far away from
                @m26872 said:
                Mine sleeps at 11uA.
                n3roN 1 Reply Last reply
                • dakkyD dakky
                  n3roN
                  n3roN
                  n3ro
                  @dakky Yes, this is because of the multiple sensors on my board. maybe somebody have more tuning tipps.
                  • R riataman
                    @n3ro said:
                    Big THX,
                    Maciej Kulawik
                    Thanks for tip!
                    Unfortunatelly quite expensive. I bought my Si7021 modules on ali for 2,9$.
                    And what chip is used on this HTU21D module? Si2071 too?
                    If not, what library is to be used to communicate?
                    • GertSandersG
                      GertSandersG
                      GertSanders
                      #26
                      Adafruit have a library for the htu21d which works well with Mysensors
