  3. Mi-Light controller for Mysensors
69 Posts 15 Posters 52.6k Views 27 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    I just ordered four 9w rgbww bulbs to try your script out. But when reading the reviews one of the main disadvantages I found where that it was not possible to query the bulbs for the current state/color/dim-level.
    But if the bulbs are wired so that they are always on then the script/repeater-node or the controller keep track of all the states, right?
    Also is it possible to connect an battery powered arduino/nrf to the existing non powered wall-switch and have the arduino to send the switch-commands directly to the mi-light-repeater-node for faster reaction times for turning the bulbs on/off?
      ted
      @Cliff-Karlsson
      Yes, it is possible to keep track of the bulb state from the controller.
      As to the switching speed, it is almost instantaneous (<<1 s). You can for sure add another node, but that will make the whole thing much more complicated to build.
      Cliff KarlssonC 1 Reply Last reply
      • T ted
        @Cliff-Karlsson
        Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        @ted
        Thanks, I forgot to ask but if the node(s) have the full capability as the original remote controler. That means that I can also control ledstrips using the mi-light led dimmers like this: Led controller right?
          @ted
          ted
          Assuming the on-air protocols are the same, yes.
          I only have the RGB-W light bulb and were able to control it without ever using the remote controller.
          @Cliff-Karlsson
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            @ted said:
            (1) turn the white light on/off using a light switch node
            What does this mean? do I connect a light switch to the repeater-node? Or does it just mean that I can use another arduino to detect button-switches and send command to domoticz or other controller?
            • Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              I have received my lamps now but no controller yet. Is it possible to pair/control the bulbs without controller?
                ted
                @Cliff-Karlsson
                To pair, turn on the light switch, and send 'ON' command within 2-3 seconds. If successful, you will see the light flash on and off a couple of times.
                The repeater-node simply relay any command it receives from the controller (I use openhab) to the light wirelessly. There is no physical wire connection between the node and milight.
                • Cliff KarlssonC
                  Cliff KarlssonC
                  Cliff Karlsson
                  Ok, I meant to say that I had not got any bridge for the mi-light yet. In the first post it is mentioned that you need to pair using a bridge.
                    ted
                    @Cliff-Karlsson
                    thanks, the original post was updated to clarify this.
                    • Cliff KarlssonC
                      Cliff KarlssonC
                      Cliff Karlsson
                      Thanks, next stupid question. How do I control the rgb/dimming features of the lamp? I got a ordinary on/off lamp under device in domoticz.
                        ted
                        @Cliff-Karlsson
                        You have to program your controller to produce the command string and send it to the node. The command string is transmitted as a ASCII string to the 'custom' node. See https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol for the command format. Sorry I don't use domoticz.
                        • Cliff KarlssonC
                          Cliff KarlssonC
                          Cliff Karlsson
                          Do I need to unpair the bulbs if I want to try pairing again? It got paired as a regular on/of bulb the first time. But I think I found out that I could add mi-lights using a dummy switch. But The bulb are not pairing.
                            ted
                            @Cliff-Karlsson
                            I don't know. Let us know what you find out. :)
                            To unpair, you turn on the power to the bulb and send 'off' command within seconds.
                            • Cliff KarlssonC
                              Cliff KarlssonC
                              Cliff Karlsson
                              Ok, I tried with several bulbs now. First time I managed to pair as on/off switch but after that I had no luck. If anyone is using this with domoticz please describe the procedure of how to add the bulbs.
                              • Cliff KarlssonC
                                Cliff KarlssonC
                                Cliff Karlsson
                                @ted
                                I forgot to ask, but what controller have you been trying them out on? And are there any limitation to how many bulbs one repeater-node can control? I recall reading something about one original controller only being able to control 4 bulbs or similar.
                                • Cliff KarlssonC
                                  Cliff KarlssonC
                                  Cliff Karlsson
                                  Ok, I think I found a clue :), S_CUSTOM seams not to be supported by domoticz so I changed it to "gw.present(0, S_RGBW_LIGHT);"
                                  So now everything looks ok with a RGB selector and everything. But I still can only turn on and off the bulb and am not able to dim or set colors. So I guess there is some more serious witchcraft going on thats over my head.
                                    @ted
                                    ted
                                    wrote on last edited by ted
                                    #24
                                    @Cliff-Karlsson
                                    The milight uses a speical command, it is not likely to be compatible with the standard RGB light module in domoticz. The information about the milight protocol can be found here: https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                                    I used openhab to assemble the command string for S_CUSTOM. Using the S_CUSTOM, you can control as many bulb as you want (by using different remote ID field in the milight protocol), although I only have 1 bulb. The node receives the milight protocol in plain ASCII string and convert the string to HEX before sending it out to the bulb. Hope this helps.
                                    • Cliff KarlssonC
                                      Cliff KarlssonC
                                      Cliff Karlsson
                                      Ok, thanks for the help but it seams that I will have to use the standard-wifi bridges for now until someone smarter than me fixes the domoticz support.
                                      • Łukasz KostrzewaŁ
                                        Łukasz KostrzewaŁ
                                        Łukasz Kostrzewa
                                        Thank You for this solutin. Everythin works great but...
                                        I was able to pair with one bulb but I I do not know what to do to pair with others?
                                        Any idea?
                                        Best regard
                                        • Łukasz KostrzewaŁ Łukasz Kostrzewa
                                          Any idea?
                                          Best regard
                                          ted
                                          @Łukasz-Kostrzewa
                                          Each bulb is associated with a particular 'remote ID'. Bulbs having the same remote ID will repond to all commands having the same remote ID. Therefore, you can simply pick a different(or the same) remote ID to pair with a second bulb, and the second bulb can be controlled separately(or simultaneously) with the first one. I have not tried it but that should work according to the mi-bulb protocol.
