  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 467.3k Views 30 Watching
  • SoloamS
    SoloamS
    Soloam
    Hello all!
    Two fast question! Can I have nodes working with ATSHA204A chip and others with software?
    And, can I have nodes with signing on and others off? Or if I add signing to my network, all nodes must have it?
    Thank you all!
    AnticimexA 1 Reply Last reply
    • SoloamS Soloam
      Hello all!
      Thank you all!
      AnticimexA
      AnticimexA
      Anticimex
      @Soloam
      You can mix nodes with soft signing and ATSHA signing as you like.
      You can mix nodes with signing on and off as well. The GW will only sign messages to nodes that require it, and it will also only check signatures from nodes that require signatures. So you can have one node which support/require signing and another which don't. The GW will be able to exchange messages with both nodes.
      • SoloamS
        SoloamS
        Soloam
        Great work indeed!
        Thank you @Anticimex
        • SoloamS Soloam
          Great work indeed!
          AnticimexA
          AnticimexA
          Anticimex
          @Soloam thanks :)
          • alexsh1A
            alexsh1A
            alexsh1
            Slightly silly question, but did anyone manage to get signing working (MySigningAtsha204Soft signer;) on Arduino Uno on MS 1.5.4 on the Ethernet gateway please? I am going out of memory and really hate to upgrade it to Mega
            • alexsh1A alexsh1
              AnticimexA
              AnticimexA
              Anticimex
              @alexsh1 if you feel adventurous try 2.0.0-beta2, or if you are patient, go to 2.0.0 in a few months and redesigns will have made space available for you.
              alexsh1A 1 Reply Last reply
              • AnticimexA Anticimex
                alexsh1A
                alexsh1A
                alexsh1
                #251
                @Anticimex Thanks - I am currently trying an Ethernet GW and a node (Sensebender Micro) with dev branch. I am stuck at personalisation. I cannot lock data. Any idea what I am doing wrong?
                This is Sensebender (with ATSHA204):
                Device revision: 00020009
                Device serial:   {0x01,0x23,0x53,0x3F,0x52,0x6A,0x1A,0x06,0xEE}
                0123533F526A1A06EE
                Skipping configuration write and lock (configuration already locked).
                Chip configuration:
                EEPROM DATA:
                ATSHA204A DATA:
                           SN[0:1]           |         SN[2:3]           | 01   23 | 53   3F
                                          Revnum                         | 00   09   04   00
                                          SN[4:7]                        | 52   6A   1A   06
                    SN[8]    |  Reserved13   | I2CEnable | Reserved15    | EE | 13 | 00 | 00
                  I2CAddress |  TempOffset   |  OTPmode  | SelectorMode  | C8 | 00 | 55 | 00
                         SlotConfig00        |       SlotConfig01        | 8F   80 | 80   A1
                         SlotConfig02        |       SlotConfig03        | 82   E0 | A3   60
                         SlotConfig04        |       SlotConfig05        | 94   40 | A0   85
                         SlotConfig06        |       SlotConfig07        | 86   40 | 87   07
                         SlotConfig08        |       SlotConfig09        | 0F   00 | 89   F2
                         SlotConfig0A        |       SlotConfig0B        | 8A   7A | 0B   8B
                         SlotConfig0C        |       SlotConfig0D        | 0C   4C | DD   4D
                         SlotConfig0E        |       SlotConfig0F        | C2   42 | AF   8F
                  UseFlag00  | UpdateCount00 | UseFlag01 | UpdateCount01 | FF | 00 | FF | 00
                  UseFlag02  | UpdateCount02 | UseFlag03 | UpdateCount03 | FF | 00 | FF | 00
                  UseFlag04  | UpdateCount04 | UseFlag05 | UpdateCount05 | FF | 00 | FF | 00
                  UseFlag06  | UpdateCount06 | UseFlag07 | UpdateCount07 | FF | 00 | FF | 00
                                      LastKeyUse[0:3]                    | FF   FF   FF   FF
                                      LastKeyUse[4:7]                    | FF   FF   FF   FF
                                      LastKeyUse[8:B]                    | FF   FF   FF   FF
                                      LastKeyUse[C:F]                    | FF   FF   FF   FF
                  UserExtra  |    Selector   | LockValue |  LockConfig   | 00 | 00 | 55 | 00
                Take note of this key, it will never be the shown again:
                #define MY_HMAC_KEY [deleted]
                Writing key to slot 0...
                Send SPACE character to lock data...
                Data lock failed. Response: D3
                Halting!
                • alexsh1A alexsh1
                  0123533F526A1A06EE
                  Chip configuration:
                  EEPROM DATA:
                  ATSHA204A DATA:
                  Halting!
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @alexsh1 actually, I have never actually locked data. Could be a bug there. But I also highly recommend that you don't. If you do, you will never be able to change hmac key in that device.
                    alexsh1A
                    alexsh1A
                    alexsh1
                    #253
                    @Anticimex So this is no problem if the key is not locked? I was just following the manual
                    On a separate note, I cannot get soft_serial written into the EEPROM:
                    #define LOCK_CONFIGURATION
                    //#define LOCK_DATA
                    //#define SKIP_KEY_STORAGE
                    //#define USER_KEY
                    #define USE_SOFT_SIGNING
                    #define STORE_SOFT_KEY
                    #define USER_SOFT_KEY
                    #define STORE_SOFT_SERIAL
                    #define USER_SOFT_SERIAL
                    #define STORE_AES_KEY
                    #define USER_AES_KEY```
                    I have defined the key under #define MY_SOFT_SERIAL [key]
                    This value will be stored in EEPROM as soft HMAC key:
                    #define MY_SOFT_HMAC_KEY [deleted]
                    Using this user supplied AES key:
                    #define MY_AES_KEY [deleted]
                    EEPROM configuration:
                    SOFT_HMAC_KEY | [deleted]
                    AES_KEY       | [deleted]
                    • alexsh1A alexsh1
                      //#define LOCK_DATA
                      //#define USER_KEY
                      AES_KEY       | [deleted]
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alexsh1 Hopefully the manual informs about the risks with locking data (that you cannot change the key afterwards). Atmel is somewhat vague on the security implications; they say that you can not read the key anyway but it is "more secure" to lock data. But personally, I have not found a way to read it, and I prefer to be able to change my HMAC key in my devices if it should be compromised.
                      Strange that you don't get the soft serial. I see nothing obviously wrong with your config. But I do see that you probably sensored your uart log a bit too hard because there are other lines missing there.
                      You should have seen this
                      Using this user supplied soft HMAC key:
                      if you have enabled this:
                      You are sure you have no #undef or some accidental comment or similar. As you see in the personalizer code, it is not that complicated. If the flags are enabled, you should at least get some printouts. But since (if your UART dump is correct) you get nothing, I suspect the flags are not really "on".
                        alexsh1A
                        alexsh1A
                        alexsh1
                        #255
                        OK, it was Arduino glitch - any changes in the sketch were not reflected on the compilation. Rebooted my PC and restarted Arduino and all works as expected.
                        A few questions: Mixing ATSHA204 and soft signing - Does HMAC key (one stored in ATSHA204 of say a node and another one in GW's EEPROM) have to be the same? Also I understand one can store HMAC key on both ATSHA204 and EEPROM of one device (say, Sensebender)? I understand that SOFT_KEY has to be unique for every device?
                        • alexsh1A alexsh1
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @alexsh1 Ok, well Arduino IDE sucks totally.
                          You can mix ATSHA204A and soft signing as much as you like. But for any two nodes to exchange signed data the HMAC keys have to be identical.
                          Yes, you can store a HMAC key in both ATSHA204A and EEPROM. These can be different if you like (and I recommend they are as the EEPROM can be dumped if the node falls into the wrong hands).
                          However, if you want that node to communicate signed data to another node, that node must use a matching HMAC key.
                          SOFT_KEY is the HMAC key stored in EEPROM, it must not be unique for every device. If it is, no device will be able to sign data to any other node and expect that node to accept that data.
                          SOFT_SERIAL on the other hand, must be unique to serve any useful purpose for whitelisting. If you use the ATSHA204A, the serial fused in the device will be used and that cannot be changed, and is according to Atmel, unique.
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @Anticimex Ok, but is there a reason why one would have HMAC key in both ATSHA204a and EEPROM?
                            • alexsh1A alexsh1
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @alexsh1 no, not really. If you have a atsha204a the only reason to not use it would be performance. Software signing executes slightly faster due to the single write protocol of the atsha.
                                alexsh1A
                                alexsh1A
                                alexsh1
                                @Anticimex Thanks very much for your help - I must admit it was a bit of a challenge to jump straight away from a stable 1.5.4 to 2.0 beta
                                • alexsh1A alexsh1
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @alexsh1 yes there have been a lot of changes but hopefully they are perceived as improvements. Feedback on signing usability is always welcome :)
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @Anticimex BTW, is signing compatible between 1.5.4 and 2.0b?
                                    • alexsh1A alexsh1
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @alexsh1 no, it is not
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #263
                                        @Anticimex Right, this is why I am not able to sign 1.5.4 nodes with 2.0b GW.
                                        In fact when I inserted #define MY_SIGNING_REQUEST_SIGNATURES into the GW code, some nodes stopped working and I think it has to be with signing as GW is throwing a lot of messages that signing failed.
                                        Bottom line is that I need to upgrade pretty much all sensors :-(
                                        • alexsh1A alexsh1
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @alexsh1 yes, Unfortunately. But it is a huge release upcoming. And a major version step, hence the incompatibilities. Hopefully, the changes made will make it easier to do future maintenance.
