  3. OpenHAB
  4. My final setup to get MySensors and OpenHab communicating via MQTT
mqttopenhab
24 Posts 7 Posters 20.1k Views 13 Watching
  • zuolanZ
    zuolanZ
    zuolan
    wrote on last edited by zuolan
    Eric,
    Thanks for posting. It looks exactly what I need to follow.
    Can you describe how the hardware(Ethernet Shield and nRF24L01, SPI pins) are connected?
    Also where to look for them in the header file?
    Martin TellblomM 1 Reply Last reply
    • zuolanZ zuolan
      Eric,
      Martin TellblomM
      Martin TellblomM
      Martin Tellblom
      @zuolan
      Follow this guide Ethernet Gateway
      MySensors MQTT Client Gateway, Openhab, Dashing, Razberry, 1-wire
      • zuolanZ
        zuolanZ
        zuolan
        Thanks for the help.
        I keep getting these messages on the COM port for the MQTT Gateway. What does it mean and what should I do to proceed? Thx.
        0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.0.1-beta
        0;255;3;0;9;TSM:INIT
        0;255;3;0;9;TSM:FAILURE
        0;255;3;0;9;TSM:FAILURE:PDT
        0;255;3;0;9;TSM:FAILURE:RE-INIT
        • zuolanZ
          zuolanZ
          zuolan
          Update on this. It seems to be working after I found I did not modify the MyConfig.h being used.
          After uncommenting #define MY_SOFTSPI
          I got below.
          0;255;3;0;9;TSM:INIT:TSP OK
          0;255;3;0;9;TSM:INIT:GW MODE
          0;255;3;0;9;TSM:READY
          IP: 192.168.1.108
          0;255;3;0;9;MCO:BGN:STP
          0;255;3;0;9;MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
          IP: 192.168.1.108
          0;255;3;0;9;MQTT connected
          0;255;3;0;9;TSF:SANCHK:OK
          IP: 192.168.1.108
          • zuolanZ zuolan
            I got below.
            IP: 192.168.1.108
            IP: 192.168.1.108
            IP: 192.168.1.108
            Martin TellblomM
            Martin TellblomM
            Martin Tellblom
            @zuolan Good that you found the problem. Don't forget to comment out define MY_SOFTSPI again
            zuolanZ 1 Reply Last reply
            • Martin TellblomM Martin Tellblom
              zuolanZ
              zuolanZ
              zuolan
              @Martin-Tellblom Something is still not right. I looked at the MQTT messages using
              mosquito_sub -v -t 'mygateway1-out/#'
              I got below:
              mygateway1-out/0/255/0/0/18 2.0.1-beta
              mygateway1-out/255/255/3/0/3 (null)
              It seems the (null)is where the message body should have been. So the payload is missing.
              The sensor node is the 'LightSensor' sketch taking an analog data
              #define CHILD_ID_LIGHT 0
              int lastLightLevel;
              sendSketchInfo("Light Sensor", "1.0",true);
              int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
              Serial.println(lightLevel);
              send(msg.set(lightLevel));
              lastLightLevel = lightLevel;
              sleep(SLEEP_TIME);
              Why the sensor node is not returning the voltage reading?
              What am I doing wrong?
              • zuolanZ zuolan
                I got below:
                int lastLightLevel;
                sleep(SLEEP_TIME);
                Martin TellblomM
                Martin TellblomM
                Martin Tellblom
                @zuolan
                Hi , mygateway1-out is used when sending commands to MySensors devices. In my setup I have renamed it like this:
                #define MY_MQTT_PUBLISH_TOPIC_PREFIX "MySensors"  //Changed from "MySensors-in"
                #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "MySensors-out"
                You should subscribe to the topic that the Gateway is Publishing (i.e MySensors-in)
                  @zuolan
                  zuolanZ
                  zuolanZ
                  zuolan
                  @Martin-Tellblom
                  OK. I will. Can you post an example of messages you are getting so I have a rough idea?
                  Many thanks.
                  • zuolanZ zuolan
                    @Martin-Tellblom
                    Many thanks.
                    Martin TellblomM
                    Martin TellblomM
                    Martin Tellblom
                    @zuolan
                    This is how my Light sensor present itself and submitting data:
                    MySensors/100/255/0/0/17    2.0.0
                    MySensors/100/255/3/0/6		0
                    MySensors/100/255/3/0/6		Light Sensor
                    MySensors/100/255/3/0/12	1.0
                    MySensors/100/100/0/0/16	null
                    MySensors/100/100/1/0/23	7  <--This is the actual light value
                    So in my case to monitor the light value in openhab I use this address: MySensors/100/100/1/0/23
                      @zuolan
                      zuolanZ
                      zuolanZ
                      zuolan
                      @Martin-Tellblom
                      OK. I am not getting any from 'mygateway1-in/#'. Let me check.
                      Just to be clear, in the above sketch
                      should have caused messages in 'mygateway1-in/#'?
                      • zuolanZ zuolan
                        @Martin-Tellblom
                        Martin TellblomM
                        Martin TellblomM
                        Martin Tellblom
                        @zuolan
                        Hi.
                        That's correct, whats shown is the presentation and the last row the LightValue, MySensors/100/100/1/0/23
                        First of all I don't think there is any problem at all in your sensor sketch, the only thing I have changed in my is that I have changed is that I added this row:
                        #define MY_NODE_ID 100
                        What I think the problem is that you are subscribing the wrong topic:
                        As I mentioned before my MQTT settings are:
                        Observerve that the MQTT topics is case sensative ie MySensors is NOT the same as mysensors.
                        I use MQTT-SPY (java based listener) to look at the messages and here you can look at every message sent when subscribing to # (And there is a BIG differense if you publish to MySensors or /MySensors). I suggest that you use MQTT-SPY and subscribe to both /# and # and that should catch all messages that comes to your broker (exept system messages)
                        Here you can se the differense between using the correct upper and lowercase and not. The first picture subribes to MySensors/#
                        And this one subscribes to mysensors/#
                        zuolanZ 3 Replies Last reply
                          @zuolan
                          Hi.
                          zuolanZ
                          zuolanZ
                          zuolan
                          @Martin-Tellblom
                          Thanks again.
                          I installed mqttspy and changed #define MY_NODE_ID 100.
                          I subscribe to the following topics:
                          mygateway1-in
                          I'm still not getting any messages in mygateway1-in.
                          Especially not this one: "MySensors/100/255/3/0/6 Light Sensor" that you are getting.
                          All the messages I can see still in mygateway1-out/255/255/3/0/3 topic.
                          So I think data from my Light Sensor node is not getting through.
                          Your thoughts? And how to debug this?
                          On the COM port of the Light Sensor I got below. Do you see any indication showing it is sending data to mqtt? What about the !TSM:FALILURE?
                          !TSM:CHKID:FAIL (ID=255)
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                          TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                          TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          TSP:MSG:PAR OK (ID=0, dist=1)
                          TSM:FPAR:OK
                          TSM:ID
                          TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                          TSM:ID
                          TSM:ID
                          TSM:ID
                          !TSM:FAILURE
                          TSM:PDT
                          TSM:INIT
                          TSM:RADIO:OK
                          TSM:FPAR
                            @zuolan
                            Hi.
                            zuolanZ
                            zuolanZ
                            zuolan
                            @Martin-Tellblom
                            I actually have the problem below solved. Since I already finished writing, so I am leaving this here for other people.
                            More information on this.
                            Although the Light Sensor data is not getting through, the Light Sensor node does cause all these MQTT messages to be sent.
                            Before I turn on the Light Sensor node, there is no MQTT message on the mqttspy and on the GatewayW5100MQTTClient COM port it is very quiet and I got this:
                            0_1472865801909_upload-09c39b2c-b30d-4e72-ad66-cfebf0e577f9
                            After I turn on the Light Sensor node the MQTT messages started comming and on the GatewayW5100MQTTClient COM port:
                            0;255;3;0;9;TSM:RADIO:OK
                            0;255;3;0;9;TSM:GW MODE
                            IP: 192.168.1.108
                            IP: 192.168.1.108
                            0;255;3;0;9;TSP:SANCHK:OK
                            <<Light Sensor Turned on>>
                            0;255;3;0;9;TSP:MSG:READ 255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
                            0;255;3;0;9;TSP:MSG:BC
                            0;255;3;0;9;TSP:MSG:FPAR REQ (sender=255)
                            0;255;3;0;9;TSP:CHKUPL:OK
                            0;255;3;0;9;TSP:MSG:GWL OK
                            0;255;3;0;9;TSP:MSG:SEND 0-0-255-255 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=bc:0
                            0;255;3;0;9;TSP:MSG:READ 255-255-0 s=255,c=3,t=3,pt=0,l=0,sg=0:
                            0;255;3;0;9;Sending message on topic: mygateway1-out/255/255/3/0/3
                            So question is why the messages from Light Sensor do not get through (or I am still not capturing them) while causing messages being sent on mygateway1-out/255/255/3/0/3?
                            See next post.
                              @zuolan
                              Hi.
                              zuolanZ
                              zuolanZ
                              zuolan
                              @Martin-Tellblom
                              Your advice of changing the MY_NODE_ID made the difference. I foolishly left it in the MyConfig.h file so it is conflicting with the gateway.
                              0_1472868188693_upload-d04ad5d6-6464-4ea1-a04b-7041c0c69d11
                              So on mqttspy I now get this!!!!!!!!!!!!!!!!!!!!!!!!!!!
                              0_1472868619367_upload-c2f43e88-cef2-4e4d-ab66-4630557a3035
                              Thanks so much for helping me.
                              • zuolanZ
                                zuolanZ
                                zuolan
                                On the topic of editing header files, I found (maybe this is obvious for other people) many including the #define MY_SOFTSPI should be done in the sketch (before the corresponding header file is included?). In this way you don't have to worry about changing it back or conflict.
                                0_1472869645982_upload-baa7801e-73be-4043-939f-26d87b164866
                                • Martin TellblomM
                                  Martin TellblomM
                                  Martin Tellblom
                                  Thats good that you found the problem.
                                  • zuolanZ
                                    zuolanZ
                                    zuolan
                                    I now try to get MQTT to talk to openhab by following the RelayActuator example. I only have the openhab demo running.
                                    I am not sure I have enough information in the above instruction to comple the mqtt.items file. For the following MQTT topics setup of mine,
                                    0_1472974737805_upload-cf617565-c688-456b-b996-24ef8efdf40b
                                    I will try the following for the first line:
                                    String Garage_Door "Garage Door [%s]" (gGarage, Windows) {mqtt="<[broker:mygateway1-out/102/1/1/0/2:state:MAP(1closed0open.map)]"}
                                    For the second line I am really stuck about how the do the "/2/2/0/0/2/"part:
                                    Switch MQTTTestSwitch "MQTT Test Switch" (gBasement) {mqtt=">[broker:mygateway1-in/2/2/0/0/2:command:ON:1],>[broker:mygateway1-in/2/2/0/0/2:command:OFF:0]"}
                                    How should one figure out?
                                    OK. To answer my own question the information is clearly here:
                                    https://www.mysensors.org/download/serial_api_20#sensor-types
                                    I will be reading up.
                                    • Meshx86M
                                      Meshx86M
                                      Meshx86
                                      My delimma here is Address distribution, i can't get openhab to distribute Address to the nodes when connecting, the MQTT Gateway sketch of my sensors doesn't do that right ?
                                      Any tips that would be great
                                      • Martin TellblomM
                                        Martin TellblomM
                                        Martin Tellblom
                                        Set a static node id using
                                        #define  MY_NODE_ID 20
                                        20 in this case is the node id.
                                        Meshx86M 1 Reply Last reply
                                          Meshx86M
                                          Meshx86M
                                          Meshx86
                                          @Martin-Tellblom cheers
