  3. 💬 Mysensors 2.0 ethernet gateway (W5100) build.
diyethernetbuildgateway
16 Posts 7 Posters 7.9k Views 7 Watching
  • aag86A
    aag86A
    aag86
    Nice job on the build. I was curious if you ended up needing to comment out MY_DEBUG in the GatewayW5100 sketch for MySensors 2.0, or whether you left it in so you could still review the serial monitor feedback. I have downgraded the AVR board definition as you noted from tekka, but wasn't sure whether commenting out debug was still necessary. I am trying to get an Ethernet GW connected up to a Vera Plus and am having a difficult time with connectivity so far.
    Thank you for any feeback.
    • aag86A aag86
      sundberg84S
      sundberg84S
      @aag86 nope, still has debug included. I use domoticz and have not seen any reconnections or timeouts in the log so far.
      aag86A 1 Reply Last reply
      • sundberg84S sundberg84
        aag86A
        aag86A
        aag86
        @sundberg84 Thanks for the feedback. I'll keep debug in and see what happens - will try later today.
        • LOSTL
          LOSTL
          LOST
          Looking good!
          How do you power this? From the USB or a separate powersource?
          • LOSTL LOST
            Looking good!
            sundberg84S
            sundberg84S
            @LOST i have cut and stripped a USB kable. So 5v from a phone charger. From 5 to 3.3v I use a le33az with capacitors.
            I dont use a usb cable connected to the arduino because the output pins on the arduino cant to provide the radio (PA/LNA version) with enough mA to work good.
            (The image is from another project, but like this:
              marcoseduardo
              Hello, may I ask you why do you use wifi and ethernet module? Does this gateway works with both connections type? Regards.
              • M marcoseduardo
                sundberg84S
                sundberg84S
                @marcoseduardo - you are misstaking, im using a ethernet module and a arduino uno. There isnt any wifi module.
                • sundberg84S
                  sundberg84S
                  Just need to ask a general question about the voltage converter - I think i messed up.
                  Im using LE33A for 3.3v but i now read here it has a limit of 0.1A. Is this enough for the LA/PNA module?
                  Maybe i should go with LD111 instead, seems like it can handle 0.8A.
                  Any thoughts?
                  • kalinaK
                    kalinaK
                    kalina
                    @sundberg84 LE33A isn't enough, because in your project also are W5100 Ethernet Module, Arduino and leds. Only NRF24L01+PA+LNA consumes 100 mA in peak. You can look here. LM1117-3.3V looks much better.
                    • kalinaK kalina
                      sundberg84S
                      sundberg84S
                      Thanks @kalina. As i suspected it might be tight.
                      It works for me so far, but to be sure i think the conclusion would be to use a better voltage regulator.
                      kalinaK 1 Reply Last reply
                        kalinaK
                        kalinaK
                        kalina
                        @sundberg84 One more note, you use long wires to connect NRF24L01+PA+LNA, you must put capacitor 100uF (at least) close to it.
                        • kalinaK kalina
                          sundberg84S
                          sundberg84S
                          @kalina - thanks, good info.
                          Im using a 4.7uF (only seen in the last picture) connected directly to VCC/GND on the radio. Works great.
                          • A
                            Atilla Y.
                            Hello to all,
                            First thank you for this great project. I'm trying to build this one but I have questions about power supply:
                            1.I want to use Orange Pi zero as controller and want to use same power supply with Arduino.
                            Is it possible?
                            2. If separately used; Is it possible to use only Arduino without -capacitors and LM or LE- by using 5V out on the Arduino for Ethernet module? Just plug the USB to the Arduino and system works?
                            • A Atilla Y.
                              Hello to all,
                              Is it possible?
                              sundberg84S
                              sundberg84S
                              @atilla-y
                              1. Orange Pi is a controller and not a gateway. If you are suggesting you want to use the 5v adapter to power both controller and gateway I can not answer you. It might work but in the same time it might be to weak or to much interference. Try! If you get alof of random freezes and/or bad network communication you might want to seperate them
                              2. It might work - but using the nrf24l01+ amplified requiers some more juice than then pro mini/uno/nano can handle so I suggest using a power in with a good voltage regulator (that can provide high current) and then split of to each unit.
