  3. Copy philps Hue settings to other RGB device with Domoticz/Mysensor
2 Posts 1 Posters 4.1k Views 2 Watching
  • franzelareF
    franzelareF
    franzelare
    I have been annoyed by the high price of the HUE LED strips, we have a few HUE lamps at home and one led strip and would like more of the LED strips but not the retail price... The led strips are behind different cabinets in the living and we normally pick about the same color for them and we only set them once or twice a day, so I don't care about latency.
    So my target was to make a cheap small copy of the HUE led strip with a wireless connection to domoticz that can copy over the colors of a HUE bulb or other LED strip.
    Since I want it wireless mysensor seemed the most easy and since I already have a few other mysensor nodes.
    To keep it wireless I decided to use a ESP unit and not a normal arduino with radio, just because of the size.
    I made a small PCB with:
    • 3 transistor's BC337 for PWM output to the led strip up to 0.8A per color (~10W/color)
    • DB18B20 (to measure temperature and detect overheating)
    • 3.3V power supply
    • reset button
    • header for programming
    • jumper for GPIO 0 to set the unit to programming mode
    I use a CP2102 programmer to program the ESP unit with arduino IDE
    and with a little 12V supply I can hook up any RGB LED strip
    I have made 2 arduino scripts to control the LED's, one based on the fastled library and one just writing analog output values for the PWM signal
    Only open now is to fade in and out when changing brightness, but the start of that is already in the script
    the temperature sensor will detect if the unit overheats and will switch if off for 1 minute, if that happens 5 times the unit will go into deep sleep mode and you need to manually reset the unit
    The fast led version I also tested with adafruit neopixels... only the small strips with 8 lixed LEDs flicker but the normal LED strip not so that seems not related to my control but to the LED's
    In the fast led based arduino code for brightness adjustment I just manually set a percentage that matches on first sight
    #define FASTLED_ESP8266_RAW_PIN_ORDER
    #include <FastLED.h>
    #include <EEPROM.h>
    #include <OneWire.h>
    #define MY_BAUD_RATE 9600
    // Setup gateway
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "MY WIFI"
    #define MY_ESP8266_PASSWORD "password"
    #define MY_IP_ADDRESS 192,168,2,151
    #define MY_IP_GATEWAY_ADDRESS 192,168,2,254
    #define MY_PORT 5003
    #define MY_MAC_ADDRESS 0x90, 0xA2, 0xDA, 0x10, 0x1D, 0x91
    #include <ESP8266WiFi.h>
    #define SKETCH_NAME "RGB_STRIP_TEMPERATURE"
    #define SKETCH_VERSION "1.0.0"
    #define NODE_REPEAT false
    #define NODE_ID 2
    //setup timer to get temperature measurement
    #include <SimpleTimer.h>
    SimpleTimer timer;
    //heartbeat timer
    SimpleTimer timerheartbeat;
    // define heartbeat variables
    #define CHILD_ID_HEART 100
    int heartbeatcount = 0;
    MyMessage msgHeart(CHILD_ID_HEART,V_TRIPPED);
    //RGB test sensor stuff
    //define RGB pins
    #define RED_PIN 12
    #define GREEN_PIN 13
    #define BLUE_PIN 14
    int H=0;
    int S=0;
    int V=0;
    int brightnessR = 0;
    int brightnessG = 0;
    int brightnessB = 0;
    int brightnessRold = 0; //prepared for fading in and out of brightness
    int brightnessGold = 0; //prepared for fading in and out of brightness
    int brightnessBold = 0; //prepared for fading in and out of brightness
    int Rcorrection = 100; // color correction for specific leds in %
    int Gcorrection = 90; // color correction for specific leds in %
    int Bcorrection = 100; // color correction for specific leds in %
    #define CHILD_ID_RGB 0
    #define ID_RGB_TEXT 38 //IDX of the text unility in domoticz holding the HEU values
    int off = 0;        //intensity when off
    int actRGBonoff=0;                        // OnOff flag
    MyMessage msg(CHILD_ID_RGB,V_CUSTOM);
    // Led brightness adjusement
    const int pwmIntervals = 1023; //1023 for ESP units and 255 for arduino
    // Dallas stuff
    #define CHILD_ID_TEMP 1
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    #define MAX_ATTACHED_DS18B20 2
    int numSensors=0;
    boolean receivedConfig = false;
    boolean metric = true;
    MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP);
    float overheat=70;  //temperature at which the dimmer will shut off to prevent damage
    #define CHILD_ID_OVERHEAT 200
    MyMessage msgOverheat(CHILD_ID_OVERHEAT,V_TRIPPED);
    int Overheatcounter = 0;
      Serial.begin(9600);
      Serial.println("Starting setup" );
      // Setup locally attached leds
      pinMode(RED_PIN, OUTPUT);
      pinMode(GREEN_PIN, OUTPUT);
      pinMode(BLUE_PIN, OUTPUT);
      present(CHILD_ID_RGB, S_RGB_LIGHT);
      request(CHILD_ID_RGB, V_RGB);
      present(CHILD_ID_OVERHEAT, S_DOOR);
    //setup measurement timer interval
        timer.setInterval(60000, getTemp);  //  in miliseconds
    // setup heartbeat timer interval
      timerheartbeat.setInterval(360000, checkReboot);  // 6 minutes in miliseconds
      present(CHILD_ID_HEART, S_DOOR);
      sensors.begin();
      Serial.println("Presentation:");
      Serial.print("temperature sensors: ");
      Serial.println(numSensors);
    // Present heartbeat signal
    // Presentation completed
      Serial.println("Setup completed" );
        timer.run();
        timerheartbeat.run();
    void checkReboot() {
      Serial.println("check if heart is still beating");
        if (heartbeatcount <= 4 ){
        send(msgHeart.set(0));
    //    present(CHILD_ID, S_RGB_LIGHT);
    //    request(CHILD_ID, V_RGB);
        send(msg.set(0));
        Serial.println("rebooting ESP due to no communication");
        ESP.restart();
      else {
        heartbeatcount = 0;
        Serial.println("Heartbeat still beating");
        Serial.println("Heartbeat counter reset");
        Serial.print("Heartbeat count: ");
        Serial.println(heartbeatcount);
    void getTemp()
      Serial.println("Loop for temperature sensors:");
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        Serial.print("Reading sensor: ");
        Serial.print(i+1);
        Serial.print(" with value: ");
          send(msgTemp.set(temperature,1));
          if (temperature>=overheat){
            Serial.println("Power off overheat protection" );
            send(msgOverheat.set(1));
            Overheatcounter = Overheatcounter +1;
            actRGBonoff=0;
            analogWrite(RED_PIN, off);
            analogWrite(GREEN_PIN, off);
            analogWrite(BLUE_PIN, off);
            send(msg.set(0));
            if (Overheatcounter == 5){
               ESP.deepSleep(999999999*999999999U, WAKE_NO_RFCAL);
            Serial.println("Sleep 60 seconds to cool down" );
            delay(60000);
            Serial.println("Requestion RGB values" );
            send(msg.set(ID_RGB_TEXT));
          if (temperature<=overheat){
                  send(msgOverheat.set(0));
    //    Serial.println("Rquest RGB settings");
    String getValue(String data, char separator, int index)
      int found = 0;
      int strIndex[] = {0, -1  };
      int maxIndex = data.length()-1;
      for(int i=0; i<=maxIndex && found<=index; i++){
        if(data.charAt(i)==separator || i==maxIndex){
          found++;
          strIndex[0] = strIndex[1]+1;
          strIndex[1] = (i == maxIndex) ? i+1 : i;
      return found>index ? data.substring(strIndex[0], strIndex[1]) : "";
    void showAnalogRGB( const CRGB& rgb)
    //storing previous settings
        Serial.println("Storing previous settings");
          brightnessRold=brightnessR;
          brightnessGold=brightnessG;
          brightnessBold=brightnessB;
          Serial.print("rgb.r ");
          Serial.println(rgb.r);
          int brightnessR=(((rgb.r*pwmIntervals)/255)*Rcorrection)/100;
          Serial.print("brightnessR ");
          Serial.println(brightnessR);
      analogWrite(RED_PIN,   brightnessR );
          Serial.print("rgb.g ");
          Serial.println(rgb.g);
          int brightnessG=(((rgb.g*pwmIntervals)/255)*Gcorrection)/100;
          Serial.print("brightnessG ");
          Serial.println(brightnessG);
      analogWrite(GREEN_PIN, brightnessG );
          Serial.print("rgb.b ");
          Serial.println(rgb.b);
          int brightnessB=(((rgb.b*pwmIntervals)/255)*Bcorrection)/100;
          Serial.print("brightnessB ");
          Serial.println(brightnessB);
      analogWrite(BLUE_PIN,  brightnessB );
      //check if the message is heartbeat
      if (message.type==V_LIGHT){
        if (message.sensor==CHILD_ID_HEART) {
         // Read message
            heartbeatcount = heartbeatcount+1;
      if (message.type == V_RGB || message.type == V_DIMMER) {
        if (actRGBonoff == 1){
        Serial.println("RGB message received" );
        Serial.println("Sleep before requesting RGB values" );
        sleep (2000);
        Serial.println("Requesting RGB values" );
      if (message.type == V_CUSTOM) {
        String cMessage =  message.getString();
        Serial.print("cMessage" );
        Serial.println(cMessage);
        int Horg;
        int H;
        static uint8_t S;
        static uint8_t V;
        Horg=getValue(cMessage, '#', 2).toInt();
        H=((Horg*255)/65536);
        S=getValue(cMessage, '#', 3).toInt();
        V=getValue(cMessage, '#', 4).toInt();
        showAnalogRGB( CHSV( H, S, V) );
        Serial.print("Horg ");
        Serial.println(Horg);
        Serial.print("H ");
        Serial.println(H);
        Serial.print("S ");
        Serial.println(S);
        Serial.print("V ");
        Serial.println(V);
      if (message.type == V_LIGHT and message.sensor== CHILD_ID_RGB) {
       if (message.getInt() == 0) {
          Serial.println("Power off toggle" );
          actRGBonoff=0;
        if (message.getInt() == 1) {
          Serial.println("Power on toggle" );
          actRGBonoff=1;
          sleep (2000);
          Serial.println(" ");
    analog output write code i used a brightness adjustment trick found on this page
    link text
    #include <EEPROM.h>
    // Setup gateway
    #define NODE_ID 2
    SimpleTimer timer;
    //heartbeat timer
    //define RGB pins
    #define RED_PIN 12
    #define BLUE_PIN 14
    int brightnessR;
    int brightnessG;
    int brightnessB;
    int Gcorrection = 100; // color correction for specific leds in %
    long RGB_values[3] = {0, 0, 0};
    String hexstring;   //HEX string for RGB value
    int dimmer;       //dimmer value in percentage
    // The number of Steps between the output being on and off
    // source from https://diarmuid.ie/blog/pwm-exponential-led-fading-on-arduino-or-other-platforms/
    const int brightnessmax = 1023;
    // The R value in the graph equation
    float R;
    // Dallas stuff
    int numSensors=0;
      Serial.begin(9600);
    // calculatebrightness adjustment
      R = (pwmIntervals * log10(2))/(log10(brightnessmax));
      sensors.begin();
      Serial.print("sensors: ");
      Serial.println("Present heartbeat signal");
        timer.run();
        send(msg.set(0));
        ESP.restart();
      else {
        heartbeatcount = 0;
    void getTemp()
        Serial.print(i+1);
            actRGBonoff=0;
            send(msg.set(0));
            delay(60000);
      int found = 0;
          found++;
         // Read message
        sleep (2000);
        hexstring=getValue(cMessage, '#', 2);
    // split dimmer values
        dimmer=(getValue(cMessage, '#', 3)).toInt();
        Serial.print("Dimmer " );
        Serial.println(dimmer);
    // split RGB values
        Serial.print("New RGB values " );
        Serial.println(hexstring);
        long number = (long) strtol( &hexstring[0], NULL, 16);
        Serial.println(number);
    // separate HEX string in RGB values
        RGB_values[0] = number >> 16;
        RGB_values[1] = number >> 8 & 0xFF;
        RGB_values[2] = number & 0xFF;
    // RGB value to display as send by the server
        long r1 = int(RGB_values[0]);
        long g1 = int(RGB_values[1]);
        long b1 = int(RGB_values[2]);
    // calculate RGB value to display
        long r = int((RGB_values[0] * dimmer/100));
        long g = int((RGB_values[1] * dimmer/100));
        long b = int((RGB_values[2] * dimmer/100));
    // set value of RGB controller
        int red = ((r*1023)/255);
        int green = ((g*1023)/255);
        int blue = ((b*1023)/255);
    //adjust brightness non linear
        brightnessR = pow (2, (red / R)) - 1;
        brightnessG = pow (2, (green / R)) - 1;
        brightnessB = pow (2, (blue / R)) - 1;
    int Rpwm=(brightnessR*Rcorrection)/100;
    int Gpwm=(brightnessG*Gcorrection)/100;
    int Bpwm=(brightnessB*Bcorrection)/100;
        Serial.print("r ");
        Serial.println(r1);
        Serial.print("r dimmed ");
        Serial.println(r);
        Serial.print("r-ESP ");
        Serial.println(red);
        Serial.print("g ");
        Serial.println(g1);
        Serial.print("g dimmed ");
        Serial.println(g);
        Serial.print("g-ESP ");
        Serial.println(green);
        Serial.print("b ");
        Serial.println(b1);
        Serial.print("b dimmed ");
        Serial.println(b);
        Serial.print("b-ESP ");
        Serial.println(blue);
        Serial.print("red brightness adjusted ");
        Serial.print("green brightness adjusted ");
        Serial.print("blue brightness adjusted ");
        Serial.print("red PWM output ");
        Serial.println(Rpwm);
        Serial.print("green PWM output ");
        Serial.println(Gpwm);
        Serial.print("blue PWM output ");
        Serial.println(Bpwm);
    // write RGB value to controller
     analogWrite(RED_PIN, Rpwm);
     analogWrite(GREEN_PIN, Gpwm);
     analogWrite(BLUE_PIN, Bpwm);
          brightnessRold=0;
          brightnessGold=0;
          brightnessBold=0;
          actRGBonoff=0;
          actRGBonoff=1;
          sleep (2000);
    • franzelareF
      franzelareF
      franzelare
      in domoticz I have 2 lua scripts running for the HUE control, 1 time based and one triggered by the device change
      next to that I have 1 watchdog script that switches on ID 100 to the node and the node will reply with an off at that ID so the node can be reset if there is no communication
      a user variable has to be creased to store the current HUE settings (String)
      a dummy text utility has to be created to store the HSV or RGB and dimmer values for the mysensor node to request
      The device script contains calculations from HSV to RGB and RGB hex, I tried different formats for fowarding the data to the mysensor node and just kept it in the script in case I might need it later for troubleshooting
      -- this script reads the setting of 1 HUE RGB device and forwards this to a mysensor RGB dimmer
      -- one script will do this time based and the second script will do this on a device change, in order to capture changed made from domoticz and through the HUE bridge directly
      -- HUE stores the values in HSV format where the mysensor node uses RGB values for the RGB LED's so these have to be converted before forwarding
      -- a user variable has to be creased to store the current HUE settings (String)
      -- a dummy text utility has to be created to store the HSV or RGB and dimmer values for the mysensor node to request
      -- additional libraries for lua have to be installed
      -- how to do this can be found in the help wiki http://www.domoticz.com/wiki/Upload_energy_data_to_PVoutput#Install_socket_library
      -- or from  http://www.domoticz.com/forum/viewtopic.php?f=5&t=1847&p=22638#p22638
      -- for json processing I use http://regex.info/code/JSON.lua on a raspberry pi
      -- on a synology nas dkjson seems to do a better job http://dkolf.de/src/dkjson-lua.fsl/home
      -- all need to end up in /usr/local/lib/lua/5.2
      commandArray =  {}
      -- fixed values
      base_url = 'http://192.168.2.150/api/fd81c2245c8797cec333e351d01a3' 	-- hue URL and username
      domoticz_url = 'http://192.168.2.140:8080' 				--URL of domoticz server
      HUE_Strip_ID = 6 							        -- HUE ID of deviced to be replicated
      HUE_CURRENT = 'Led_HUE'                             -- Uservariable (String) to store HUE setting
      Source_Name = 'HueStrip'                            -- Name of the HUE device to be copied in Domoticz
      Target_IDX = 229    	    						-- IDX of target device
      Target_Name = 'RGB_Led'    	    					-- exact device name
      Target_IDX_TXT=38                                   -- IDX for HSV values
      ForwardType = 'HSV'                                  -- HSV or RGB to be forwarded to the mysensor node
      PRINT_MODE = false		-- when true wil print output to log and send notifications
      if (devicechanged[Source_Name]) then -- optional and (uservariables['HUE_Forward_LAN']==1)
      	if (otherdevices[Source_Name] == 'Off') then
      		-- set copied device to off
      		commandArray[Target_Name] = 'Off'
      -- Only load libaries now
      http = require('socket.http')
      ltn12 = require('ltn12')
      json = require('JSON')
      io = require('io')
      -- set some local variables
      device = ''
      mode = 'GET'
      params = ''
      function hueread(device, operation, mode)
               local t = {}
               local url = base_url .. device
               local req_body = operation
      	if PRINT_MODE == true then
              	 print(url)
      	         print(req_body)
      	end
               local headers = {
                  ["Content-Type"] = "application/json";
                  ["Content-Length"] = #req_body;
                client, code, headers, status = http.request{url=url, headers=headers, source=ltn12.source.string(req_body), sink = ltn12.sink.table(t), method=mode}
              	 print(status)
      	end
       return t
      end
      function processJSON(t)
      	obj, pos, err = json:decode(table.concat(t),1,nil)
              print(table.concat(t))
      	    print("check for error")
      	  end
      	if err then
              print ("Error for HUE Bridge:", err)
              		print("no error")
      		end
              data = ''
      	    i=HUE_Strip_ID
              state=obj.lights[tostring(i)].state
      	    dataHUE = data .. state.bri ..'|'.. state.hue ..'|'.. state.sat
          	dataStatus = state.on
      -- checking if HUE strip is off
      	if state.on==false then
      			if otherdevices[Target_Name] ~= 'Off' then
      				print('HUE LED is off, but RGB LED was on')
      				print('HUE LED is off, no action')
      			end
      			    print('Sending off switch command just to be sure')
      		    end
      		end
      -- checking if HUE strip is on but led strip is off
      	if state.on==true then
      		if otherdevices[Target_Name] == 'Off' then
      				print('Switching RGB led on')
      			end
      		commandArray[Target_Name] = 'On'
      				print('Hue ID checked: ' .. i)
      				print('Status on: On')
      				print('HUE: ' .. dataHUE)
      			    print('length of encode '..#dataHUE)
      			end
      				print('RGB led already on, checking settings')
      			end
      				print('Sending on switch command just to be sure')
      			end
      		end
      -- Collecting color data to compare
      	Old_data = tostring(uservariables[HUE_CURRENT])
      	New_data = tostring(dataHUE)
          if New_data ~= Old_data then
      	    print('HUE data changed')
      	    	print('New data:' .. New_data)
      		    print('Old data:' ..Old_data)
      		    print('')
      	    end
          -- convert HUE values to HSV
          	H=((state.hue)/65534)
      	    S=((state.sat)/254)
          	V=((state.bri)/254)
          --convert HUE to domoticz values
          	Hue=tostring(math.floor(H*360))
      	    Sat=tostring(math.floor(S*100))
      	    Bri=tostring(math.floor(V*100))
          -- convert HSV to RGB and RGB hex values
          	R, G, B =HSVtoRGB(H, S, V)
          	if R >= 16 then
      	    	Rhex=num2hex(R)
      	    	Rhex='0'.. num2hex(R)
      	    end
      	    if G >= 16 then
          		Ghex=num2hex(G)
      		    Ghex='0'.. num2hex(G)
          	end
      	    if B >= 16 then
      		    Bhex=num2hex(B)
      	    	Bhex='0'.. num2hex(B)
      	    end
          	RGB= R ..'|'.. G ..'|'.. B
      	    RGBhex= Rhex ..''.. Ghex ..''.. Bhex
          -- Reverse calculations of hue values for validation
      	        Hr, Sr, Vr =RGBtoHSV(R, G, B)
      		    Hrev=round((Hr*65536),0)
          		Srev=round((Sr*256),0)
      	    	Vrev=round((Vr*256),0)
              -- print all calculated data
          	    print('Hue Hue light: ' .. state.hue)
          	    print('Sat Hue light: ' .. state.sat)
              	print('Bright Hue light: ' .. state.bri)
      	        print(' ')
              	print('Hue domoticz: ' .. Hue)
      	        print('Sat domoticz: ' .. Sat)
          	    print('Bri domoticz: ' .. Bri)
          	    print(' ')
              	print('H: ' .. H)
          	    print('S: ' .. S)
              	print('V: ' .. V)
      	        print(' ')
              	print('R: ' .. R)
      	        print('G: ' .. G)
          	    print('B: ' .. B)
          	    print('RGB: ' .. RGB)
              	print(' ')
      	        print('Rhex: ' .. Rhex)
              	print('Ghex: ' .. Ghex)
      	        print('Bhex: ' .. Bhex)
          	    print('RGBhex: ' .. RGBhex)
          	    print(' ')
              	print('H reversed: ' .. Hrev)
      	        print('S reversed: ' .. Srev)
          	    print('V reversed: ' .. Vrev)
              end
          -- set LED strip
              if (ForwardType=='RGB') then
      	    -- store RGB as text
          		datanew_TXT=RGBhex..";"..Bri..";"
      	        commandArray['UpdateDevice'] = Target_IDX_TXT .. '|0|' .. tostring(datanew_TXT)
          		    print('Storing RGB text value:' .. datanew_TXT)
      	    	end
              end
              if (ForwardType=='HSV') then
      	    -- store HSV as text
      		    datanew_HSV=state.hue..";"..state.sat..";"..state.bri..";"
          	    commandArray['UpdateDevice'] = Target_IDX_TXT .. '|0|' .. tostring(datanew_HSV)
      		        print('Storing HSV text value:' .. datanew_HSV)
          		end
              end
          	--send HUE values to domoticz
                  urlRGBLED = 'http://127.0.0.1:8080/json.htm?type=command&param=setcolbrightnessvalue&idx=' .. Target_IDX .. '&hue=' ..Hue.. '&brightness=' ..Bri..'&saturation=' ..Sat.. '&iswhite=false'
                  commandArray['OpenURL']= urlRGBLED
          	-- store new HUE values in variables
      	    	commandArray['Variable:Led_HUE'] = New_data
      	    print('No change in HUE values')
          end
      	end
         end
        end
       return
      end
      function HSVtoRGB(h, s, v)
        local r, g, b
        local i = math.floor(h * 6);
        local f = h * 6 - i;
        local p = v * (1 - s);
        local q = v * (1 - f * s);
        local t = v * (1 - (1 - f) * s);
        i = i % 6
        if i == 0 then r, g, b = v, t, p
        end
        if i == 1 then r, g, b = q, v, p
        end
        if i == 2 then r, g, b = p, v, t
        end
        if i == 3 then r, g, b = p, q, v
        end
        if i == 4 then r, g, b = t, p, v
        end
        if i == 5 then r, g, b = v, p, q
        end
      	R=round((r*255),0)
      	G=round((g*255),0)
      	B=round((b*255),0)
        return R, G, B
      end
      function RGBtoHSV(r, g, b)
        r, g, b = r / 255, g / 255, b / 255
        local max, min = math.max(r, g, b), math.min(r, g, b)
        local h, s, v
        v = max
        local d = max - min
        if max == 0 then s = 0 else s = d / max end
        if max == min then
          h = 0 -- achromatic
          if max == r then
          h = (g - b) / d
          if g < b then h = h + 6 end
          elseif max == g then h = (b - r) / d + 2
          elseif max == b then h = (r - g) / d + 4
          end
          h = h / 6
        end
        return h, s, v
      end
      function round(num, idp)
        local mult = 10^(idp or 0)
        return math.floor(num * mult + 0.5) / mult
      end
      function num2hex(num)
          local hexstr = '0123456789ABCDEF'
          local s = ''
          while num > 0 do
              local mod = math.fmod(num, 16)
              s = string.sub(hexstr, mod+1, mod+1) .. s
              num = math.floor(num / 16)
          end
          if s == '' then s = '0' end
          return s
      end
      t = hueread(device, params, mode)
      processJSON(t)
      end
      end
      return commandArray
      The time based lua script
      commandArray =  {}
      -- fixed values
      HUE_CURRENT = 'Led_HUE'                             -- uservariable (String) to store HUE setting
      io = require('io')
      device = ''
      mode = 'GET'
      params = ''
               local t = {}
              	 print(url)
      	         print(req_body)
      	end
               local headers = {
              	 print(status)
      	end
       return t
      end
      	  end
      	if err then
              		print("no error")
      		end
              data = ''
      	    i=HUE_Strip_ID
      			end
      		    end
      		end
      			end
      			end
      			end
      			end
      		end
      		    print('')
      	    end
      	    S=((state.sat)/254)
          	V=((state.bri)/254)
          	if R >= 16 then
      	    	Rhex=num2hex(R)
      	    end
      	    if G >= 16 then
          		Ghex=num2hex(G)
          	end
      	    if B >= 16 then
      		    Bhex=num2hex(B)
      	    end
      	        print(' ')
          	    print(' ')
              	print('H: ' .. H)
          	    print('S: ' .. S)
              	print('V: ' .. V)
      	        print(' ')
              	print('R: ' .. R)
      	        print('G: ' .. G)
          	    print('B: ' .. B)
              	print(' ')
          	    print(' ')
              end
          -- set LED strip
      	    	end
              end
          		end
              end
          end
      	end
         end
        end
       return
      end
        local r, g, b
        i = i % 6
        end
        end
        end
        end
        end
        end
      	R=round((r*255),0)
      	G=round((g*255),0)
      	B=round((b*255),0)
        return R, G, B
      end
        local h, s, v
        v = max
        local d = max - min
        if max == min then
          h = 0 -- achromatic
          if max == r then
          h = (g - b) / d
          end
          h = h / 6
        end
        return h, s, v
      end
      end
          local s = ''
          while num > 0 do
          end
          return s
      end
      processJSON(t)
      return commandArray
      I use a watchdog script, where this is a simplified version of, currently I have 5 ESP units in this watchdog script
      commandArray = {}
      function timedifference (s)
        year = string.sub(s, 1, 4)
        month = string.sub(s, 6, 7)
        day = string.sub(s, 9, 10)
        hour = string.sub(s, 12, 13)
        minutes = string.sub(s, 15, 16)
        seconds = string.sub(s, 18, 19)
        t1 = os.time()
        t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes, sec=seconds}
        difference = os.difftime (t1, t2)
        return difference
      end
      LastupdateESP = otherdevices_lastupdate['HeartbeatESP']
      ESPdifference=timedifference (LastupdateESP)
      	    print('Lastupdate ESP ' .. LastupdateESP)
              print('Time difference ' .. ESPdifference)
          end
      if (ESPdifference>=130) then
          if (otherdevices['ESPAlive'] == 'On')then
              commandArray['ESPAlive'] = 'Off'
              CurrentTime=os.date("%Y-%m-%d %H:%M:%S")
              file = io.open("/home/pi/domoticz/www/log/MysensorWatchdog.log", "a")
                  io.output(file)
                  io.write(CurrentTime.. " Mysensor ESP connection lost" .. "\n")
                  io.close(file)
                      print('Writing to error log')
                  end
          end
      end
      if (ESPdifference<130 and otherdevices['ESPAlive'] == 'Off')then
              print('ESP is a live again')
          end
          commandArray['ESPAlive'] = 'On'
              io.output(file)
              io.write(CurrentTime.. " Mysensor ESP connection operational again" .. "\n")
              io.close(file)
              end
      end
                  commandArray['HeartbeatESP'] = 'On'
      return commandArray
      12.5k
