  2. Announcements
    @ewgor "Could not resolve host" means dns is not working on your raspberry pi. Is the network working properly (can you access other web sites from the pi?) http://www.suntimebox.com/raspberry-pi-tutorial-course/week-3/day-5/ seems to have a guide if you need help configuring network settings.
    Velo17V
    Velo17V
    Velo17
    wrote on last edited by Velo17
    #166
    (sorry, I hit reply on mfalkvidd's post)
    I have a strange problem:
    I tried to be smart (haha) and updated my Raspberry2 with
    sudo apt-get update
    sudo apt-get dist-upgrade
    This took quite a while and looked successful to me.
    Unfortunately the MySensors Gateway and/or controller setup is not working correctly anymore. For troubleshooting I disabled my controller (MyController running on the Pi and for sniffing also MYSController available on my Windows machine). I stopped the gateway service and manually ran the gateway with -d debug information and get this:
    mysGateway: Starting gateway...
    mysGateway: Protocol version - 2.0.1-beta
    mysGateway: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.0.1-beta
    mysGateway: TSF:LRT:OK
    mysGateway: TSM:INIT
    mysGateway: TSM:INIT:TSP OK
    mysGateway: TSM:INIT:GW MODE
    mysGateway: TSM:READY
    mysGateway: Listening for connections on 0.0.0.0:5003
    mysGateway: MCO:REG:NOT NEEDED
    mysGateway: MCO:BGN:STP
    mysGateway: MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
    mysGateway: TSF:MSG:READ,7-7-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:BC
    mysGateway: TSF:MSG:FPAR REQ,ID=7
    mysGateway: TSF:PNG:SEND,TO=0
    mysGateway: TSF:CKU:OK
    mysGateway: TSF:MSG:GWL OK
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysGateway: TSF:MSG:PINGED,ID=7,HP=1
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=0,t=17,pt=0,l=5,sg=0:2.0.0
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=11,pt=0,l=17,sg=0:Ernie Giess-O-Mat
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=12,pt=0,l=4,sg=0:0.17
    mysGateway: TSF:MSG:READ,7-7-0,s=2,c=0,t=6,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=0,c=0,t=7,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=3,c=0,t=30,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=4,c=0,t=21,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:READ,7-7-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
    mysGateway: TSF:MSG:SEND,0-0-7-7,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:8219.0
    mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:29.66
    mysGateway: TSF:MSG:READ,7-7-0,s=3,c=1,t=38,pt=7,l=5,sg=0:9.0
    mysGateway: TSF:MSG:READ,7-7-0,s=4,c=1,t=34,pt=1,l=1,sg=0:0
    mysGateway: TSF:MSG:READ,17-17-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysGateway: TSF:MSG:FPAR REQ,ID=17
    mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
    mysGateway: TSF:MSG:PINGED,ID=17,HP=1
    mysGateway: TSF:MSG:SEND,0-0-17-17,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
    mysGateway: TSF:MSG:READ,7-7-0,s=0,c=1,t=1,pt=7,l=5,sg=0:10834.0
    mysGateway: TSF:MSG:READ,7-7-0,s=2,c=1,t=0,pt=7,l=5,sg=0:3.96
    mysGateway: TSF:MSG:READ,17-17-0,s=255,c=3,t=0,pt=1,l=1,sg=0:67
    mysGateway: TSF:MSG:READ,17-17-0,s=1,c=1,t=0,pt=7,l=5,sg=0:18.8
    mysGateway: TSM:READY:NWD REQ
    mysGateway: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    mysGateway: TSF:SRT:OK
    Which looks okay to me (2 sensor nodes are sending data here). But after this NWD REQ...STR:OK block nothing more happens, only more of these 3 lines blocks repeat over and over with about 15 minutes or so inbetween.
    "of course" I also re-compiled the gateway source with re-setting the configuration, which is
    sudo ./configure --my-rf24-channel=124 --my-rf24-irq-pin=11  --my-debug=enable
    sudo make install
    any ideas what I can try to make it work again? :-(
    In any case, happy weekend to everyone,
    greetings from Germany!
    • Velo17V Velo17
      sudo apt-get update
      sudo make install
      marceloaqno
      Code Contributor
      wrote on last edited by marceloaqno
      #167
      @Velo17 It might be related to the nrf24 irq pin. Could you try to build the gateway without the my-rf24-irq-pin option and check if the gateway still behaves this way?
      Velo17V 1 Reply Last reply
      • M marceloaqno
        Velo17V
        Velo17V
        Velo17
        @marceloaqno Thanks for the hint! This actually solves the lock up. But shouldnt the interrupt offer a superior connectivity and thus be desireable? Until yesterday (before I did the RPi upgrading) this worked - or at least it appeared to work (I dont know if the interrupt was actually used)
        • Velo17V Velo17
          marceloaqno
          Code Contributor
          @Velo17 I had the same problem in the past but I thought it was because of my nrf24 module wasn't properly shielded or my cables was too long, causing some kind of interference to the irq pin.
          I end up disabling the interrupt options until I replace my nrf24 module or rearrange the cables, which I haven't done yet.
          Could you give more details on what kind of nrf module you are using and how it is connected to rpi?
          • P
            P
            pettib
            Hi everyone.
            I´m trying to build a new homeController with the following parts / software.
            Raspberry Pi 3
            Home Assistant
            MySensors
            Tellstick
            Mosquitto MQTT Broker
            I got everything working beside the MySensors. I´m trying to connect the NRF 24L01+ chip directly to the RPI with help from https://www.mysensors.org/build/raspberry.
            I want to use MQTT between MySensors and HomeAssistant
            The MQTT broker is working when i´m testing it.
            The Mosquitto is configurated with username and Password in the config of Mosquitto.
            The config i´m using when Make Mysensors is the following:
            ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24 --my-rf24-irq-pin=15
            I also changed in the file /examples_linux/mysgw.cpp
            #define MY_MQTT_USER "My User"
            #define MY_MQTT_PASSWORD "My Password"
            When i´m running the command: sudo systemctl status mysgw I got following result.
            ● mysgw.service - MySensors Gateway daemon
            Loaded: loaded (/etc/systemd/system/mysgw.service; enabled)
            Active: active (running) since tis 2016-12-27 18:52:34 CET; 25min ago
            Main PID: 1405 (mysgw)
            CGroup: /system.slice/mysgw.service
            └─1405 /usr/local/bin/mysgw
            dec 27 19:18:10 HomeAssistant mysgw[1405]: failed to connect
            dec 27 19:18:10 HomeAssistant mysgw[1405]: socket: Too many open files
            When trying to run command sudo mysgw -d it shows following info in a endless loop:
            mysgw: connected to 127.0.0.1
            Please help figure this out.
            //PeTi
            • Flor SandersF
              Flor SandersF
              Flor Sanders
              wrote on last edited by Flor Sanders
              #171
              Hello
              The past two days I've been trying to setup the gateway on my RPi 2 with domoticz.
              Here's what I did.
              I installed domoticz onto my raspi, then I tried the install the gateway.
              cd MySensors
              Afterwards I did the following
              make
              sudo ./bin/mysgw -d
              Then it seems to start normally onto the point where it refuses to connect to anything.
              Does anyone have a clue what's going wrong?
              I can't seem to figure it out. I've tried it several times over, and always go similar results.
              I was using GertSanders's connector for the RPi Hub and I've tried it with normal wiring too.
              As far as I can see it shouldn't be a wiring problem...
              0_1482936624899_upload-edfa86af-fd0c-4e63-be7b-5393e20f27eb
              EDIT:
              !UPDATE!
              I think I just fixed it. I reconfigured it to include the IRQ Pin and now it's just listening for throughput
              pi@raspberrypi:~/MySensors $  sudo ./bin/mysgw -d
              mysgw: Starting gateway...
              mysgw: Protocol version - 2.1.0-beta
              mysgw: MCO:BGN:INIT GW,CP=RNNG--Q,VER=2.1.0-beta
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              • Flor SandersF
                Flor SandersF
                Flor Sanders
                I got the previous problem out of the way for now...
                Now onto the next one.
                I started a node and now I can clearly see data being sent and received on my serial log and ssh. (See picture)
                0_1482941358792_upload-08fe5f75-3536-4fb5-a0f4-2ee7d0edbc6a
                So I tried adding the gateway to domoticz using following settings:
                0_1482941417649_upload-ce92a80a-a5aa-4713-bfe8-227c71b8ce72
                Yet if I check hardware setup I can see no nodes being presented.
                0_1482941455435_upload-e36e2fbf-ac80-4381-895d-293e6e638ead
                Are there settings or steps I missed?
                Greetings
                Flor
                TigroenotT 1 Reply Last reply
                • Flor SandersF Flor Sanders
                  Greetings
                  Flor
                  TigroenotT
                  TigroenotT
                  Tigroenot
                  @Flor-Sanders I think you maybe should choose not USB but Ethernet gateway in domoticz.
                  • Flor SandersF
                    Flor SandersF
                    Flor Sanders
                    @Tigroenot
                    That fixed it indeed XD
                    Thanks for helping me out
                    • P pettib
                      Hi everyone.
                      Raspberry Pi 3
                      Home Assistant
                      MySensors
                      Tellstick
                      //PeTi
                      marceloaqno
                      Code Contributor
                      @pettib Could it be that you are using an old version of Mosquitto?
                      mosquitto -h
                      Flor SandersF 1 Reply Last reply
                      • M marceloaqno
                        mosquitto -h
                        Flor SandersF
                        Flor SandersF
                        Flor Sanders
                        @marceloaqno
                        How so?
                        I've tried running the command you've supplied, but it doesn't work... Do I have to install mosquitto?
                        I didn't see it anywhere in the guide.
                        Everything is working at the moment, you think it can pose a problem later?
                        • Robinek70R
                          Robinek70R
                          Robinek70
                          Hello everyone,
                          I've been working gateway on RPi, but I don't know how to configure MY_SIGNING_SOFT .
                          File mysgw.cpp contains MY_SIGNING_SOFT definition and I can uncomment it, but I don't know where and how I should define: SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY ?
                          Could you give more details how to configure soft signing on RPi?
                          thanks
                          //Robert
                          • aandA
                            aandA
                            aand
                            Has anyone successfully built on an Orange Pi One running armbian? RPi running raspbinan is supported, but on my Orange Pi One running armbian I get
                            ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
                            I already have TMRh20's RF24 code running on this system, so I know it's capable.
                            • aandA aand
                              Tag
                              wrote on last edited by Tag
                              #179
                              @aand
                              working on the same setup, unfortunately was not able to compile the mysensors gateway...
                              this is the error i get:
                              root@orangepizero:~/MySensors# make
                              g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DMY_IS_SERIAL_PTY -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                              from ./MySensors.h:294,
                              compilation terminated.
                              seems spi is missing...
                              however it seems to be available in the system:
                              root@orangepizero:~/MySensors# ll /dev/spidev0.0
                              crw------- 1 root root 153, 0 Dec 30 16:26 /dev/spidev0.0
                              root@orangepizero:~/MySensors# dmesg | grep -i spi
                              [ 0.814155] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
                              [ 0.814185] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
                              [ 0.815261] spi spi0: master is unqueued, this is deprecated
                              setup:
                              Orangepi zero
                              Armbian
                              hope that we get native OPI support soon, any way all help is appreciated!!
                              kind regards,
                              Tag
                              jirmJ 1 Reply Last reply
                              • T Tag
                                @aand
                                setup:
                                Orangepi zero
                                Armbian
                                kind regards,
                                Tag
                                jirmJ
                                jirmJ
                                jirm
                                @aand said:
                                Orange Pi One
                                @aand
                                I think, maybe the hardware nrf24 radio its not properly detected or ready on OPI?
                                Seems ready state of the nrf24 board is needed in the moment to build/make the compilation of that module for the myGateway.
                                We have any chance to run any Raspbian version (not armbian) on OPI ?
                                Sure have so much differences about raspbian and armbian to aply same softw installation methods on both without adaptat in each case.
                                Im so interesed too for use OPI One like my HA Controller and MQTT Gateway, so will be really good if you can post here any evolution and impressions about using OPI for that.
                                • aandA
                                  aandA
                                  aand
                                  jirm daid "I think, maybe the hardware nrf24 radio its not properly detected or ready on OPI?"
                                  nrf24l01 radios WORK FINE on the Orange Pi One running armbian.
                                  I downloaded TMRh20's RF24 GitHub files and successfully tested the Linux example code "gettingstarted" in which an Orange Pi One (tx) sent data to another Orange Pi One (rx).
                                  • aandA aand
                                    jirmJ
                                    jirmJ
                                    jirm
                                    wrote on last edited by jirm
                                    #182
                                    @aand.
                                    No dubt that NRF24 is detected and working on Armbian, but seems not properly detected on the build module process for the gateway installation process made for Raspbian. Sure because OS diferences from Raspbian and Armbian, raise this issue.
                                    Why not directly use Raspbian on OPI to avoid that and sure other issues that will by found because all software are mainly build for Raspberry (Raspbian OS) and that is the only well tested?
                                    I see Raspbian is available and updated for OPI trough his manufacturer.
                                    http://www.orangepi.org/downloadresources/orangepipc/oragepipc_e930546e866b23585721e5d2a6.html
                                    Regards
                                    • aandA
                                      aandA
                                      aand
                                      @jirm Thanks for the suggestion. I've downloaded the raspian image. To duplicate the path I used with armbian, I downloaded TMRh20's RF24 code so I can test the radio with code I've already had up and running on the hardware.. However, this version of raspbian is really bad. So far nothing compiles. Regular raspbian, and armbian on the orange pi one do not have this kind of problem out of the box; they compile a wide range of packages. I'll spend some more time on it to be diligent, but this distro looks like it needs to be put on the abandon pile.
                                      I tried compiling mysensors gateway too but no luck with that yet either. This is what I get:
                                      ./configure
                                      [OK] init system detected: sysvinit
                                      [OK] Finished.
                                      make
                                      gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
                                      DIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/log
                                      .c -o build/drivers/Linux/log.o
                                      cc1: error: bad value (armv8-a) for -march switch
                                      cc1: error: bad value (cortex-a53) for -mtune switch
                                      Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
                                      jirmJ 3 Replies Last reply
                                      • aandA aand
                                        ./configure
                                        [OK] Finished.
                                        make
                                        jirmJ
                                        jirmJ
                                        jirm
                                        #184
                                        @aand
                                        Ok. Arrrggg ! .
                                        So sad ear that OPI Raspbian fork is too not working out the box and but its not surprise because the poor software support form manufacturer. Maybe this is another no way road.
                                        So seems only keep fighting with both OS (arm and rasp) to make it working.
                                        Some sugestions ...
                                        Will be fine if can post this issue but in software section here on mysensors forums. Maybe some mysensors gateway developers or any linux hack can help to trace the error you have on armbian or raspbian.
                                        Maybe can find another "no official" OPI Raspbian fork that compile better to mygateway. Maybe post this issue in OPI forums will be good and someone there can help or provide other better Raspbian fork.
                                        Sadly in this days I dont have time to try install on my OPI´s to help more. :-1:
                                        Regards
                                        • aandA aand
                                          ./configure
                                          [OK] Finished.
                                          make
                                          jirmJ
                                          jirmJ
                                          jirm
                                          #185
                                          @aand
                                          The las error you posted...is not on Raspbian but in Armbian ????
                                          "gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
                                          cc1: error: bad value (cortex-a53) for -mtune switch"
                                          In any case seems this is a gcc compiler error maybe because "wrong" version for that processor...so maybe trying to update gcc compiler can help to avoid that error?
