  2. Announcements
  • Flor SandersF Flor Sanders
    I got the previous problem out of the way for now...
    Now onto the next one.
    I started a node and now I can clearly see data being sent and received on my serial log and ssh. (See picture)
    0_1482941358792_upload-08fe5f75-3536-4fb5-a0f4-2ee7d0edbc6a
    So I tried adding the gateway to domoticz using following settings:
    0_1482941417649_upload-ce92a80a-a5aa-4713-bfe8-227c71b8ce72
    Yet if I check hardware setup I can see no nodes being presented.
    0_1482941455435_upload-e36e2fbf-ac80-4381-895d-293e6e638ead
    Are there settings or steps I missed?
    Greetings
    Flor
    TigroenotT
    TigroenotT
    Tigroenot
    @Flor-Sanders I think you maybe should choose not USB but Ethernet gateway in domoticz.
    • Flor SandersF
      Flor SandersF
      Flor Sanders
      @Tigroenot
      That fixed it indeed XD
      Thanks for helping me out
      • P pettib
        Hi everyone.
        I´m trying to build a new homeController with the following parts / software.
        Raspberry Pi 3
        Home Assistant
        MySensors
        Tellstick
        Mosquitto MQTT Broker
        I got everything working beside the MySensors. I´m trying to connect the NRF 24L01+ chip directly to the RPI with help from https://www.mysensors.org/build/raspberry.
        I want to use MQTT between MySensors and HomeAssistant
        The MQTT broker is working when i´m testing it.
        The Mosquitto is configurated with username and Password in the config of Mosquitto.
        The config i´m using when Make Mysensors is the following:
        ./configure --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=mygateway1 --my-transport=nrf24 --my-rf24-irq-pin=15
        I also changed in the file /examples_linux/mysgw.cpp
        #define MY_MQTT_USER "My User"
        #define MY_MQTT_PASSWORD "My Password"
        When i´m running the command: sudo systemctl status mysgw I got following result.
        ● mysgw.service - MySensors Gateway daemon
        Loaded: loaded (/etc/systemd/system/mysgw.service; enabled)
        Active: active (running) since tis 2016-12-27 18:52:34 CET; 25min ago
        Main PID: 1405 (mysgw)
        CGroup: /system.slice/mysgw.service
        └─1405 /usr/local/bin/mysgw
        dec 27 19:18:10 HomeAssistant mysgw[1405]: failed to connect
        dec 27 19:18:10 HomeAssistant mysgw[1405]: socket: Too many open files
        When trying to run command sudo mysgw -d it shows following info in a endless loop:
        mysgw: connected to 127.0.0.1
        Please help figure this out.
        //PeTi
        marceloaqno
        Code Contributor
        @pettib Could it be that you are using an old version of Mosquitto?
        mosquitto -h
        Flor SandersF 1 Reply Last reply
        • M marceloaqno
          mosquitto -h
          Flor SandersF
          Flor SandersF
          Flor Sanders
          @marceloaqno
          How so?
          I've tried running the command you've supplied, but it doesn't work... Do I have to install mosquitto?
          I didn't see it anywhere in the guide.
          Everything is working at the moment, you think it can pose a problem later?
          • Robinek70R
            Robinek70R
            Robinek70
            Hello everyone,
            I've been working gateway on RPi, but I don't know how to configure MY_SIGNING_SOFT .
            File mysgw.cpp contains MY_SIGNING_SOFT definition and I can uncomment it, but I don't know where and how I should define: SOFT_HMAC_KEY, SOFT_SERIAL and AES_KEY ?
            Could you give more details how to configure soft signing on RPi?
            thanks
            //Robert
            • aandA
              aandA
              aand
              Has anyone successfully built on an Orange Pi One running armbian? RPi running raspbinan is supported, but on my Orange Pi One running armbian I get
              ./MySensors.h:258:2: error: #error No support for nRF24 radio on this platform
              I already have TMRh20's RF24 code running on this system, so I know it's capable.
              • aandA aand
                Tag
                wrote on last edited by Tag
                #179
                @aand
                working on the same setup, unfortunately was not able to compile the mysensors gateway...
                this is the error i get:
                root@orangepizero:~/MySensors# make
                g++ -MT build/examples_linux/mysgw.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RADIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -DMY_IS_SERIAL_PTY -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c examples_linux/mysgw.cpp -o build/examples_linux/mysgw.o
                from ./MySensors.h:294,
                compilation terminated.
                seems spi is missing...
                however it seems to be available in the system:
                root@orangepizero:~/MySensors# ll /dev/spidev0.0
                crw------- 1 root root 153, 0 Dec 30 16:26 /dev/spidev0.0
                root@orangepizero:~/MySensors# dmesg | grep -i spi
                [ 0.814155] sunxi_spi_chan_cfg()1376 - [spi-0] has no spi_regulator.
                [ 0.814185] sunxi_spi_chan_cfg()1376 - [spi-1] has no spi_regulator.
                [ 0.815261] spi spi0: master is unqueued, this is deprecated
                setup:
                Orangepi zero
                Armbian
                hope that we get native OPI support soon, any way all help is appreciated!!
                kind regards,
                Tag
                jirmJ 1 Reply Last reply
                • T Tag
                  @aand
                  setup:
                  Orangepi zero
                  Armbian
                  kind regards,
                  Tag
                  jirmJ
                  jirmJ
                  jirm
                  @aand said:
                  Orange Pi One
                  @aand
                  I think, maybe the hardware nrf24 radio its not properly detected or ready on OPI?
                  Seems ready state of the nrf24 board is needed in the moment to build/make the compilation of that module for the myGateway.
                  We have any chance to run any Raspbian version (not armbian) on OPI ?
                  Sure have so much differences about raspbian and armbian to aply same softw installation methods on both without adaptat in each case.
                  Im so interesed too for use OPI One like my HA Controller and MQTT Gateway, so will be really good if you can post here any evolution and impressions about using OPI for that.
                  • aandA
                    aandA
                    aand
                    jirm daid "I think, maybe the hardware nrf24 radio its not properly detected or ready on OPI?"
                    nrf24l01 radios WORK FINE on the Orange Pi One running armbian.
                    I downloaded TMRh20's RF24 GitHub files and successfully tested the Linux example code "gettingstarted" in which an Orange Pi One (tx) sent data to another Orange Pi One (rx).
                    • aandA aand
                      jirmJ
                      jirmJ
                      jirm
                      wrote on last edited by jirm
                      #182
                      @aand.
                      No dubt that NRF24 is detected and working on Armbian, but seems not properly detected on the build module process for the gateway installation process made for Raspbian. Sure because OS diferences from Raspbian and Armbian, raise this issue.
                      Why not directly use Raspbian on OPI to avoid that and sure other issues that will by found because all software are mainly build for Raspberry (Raspbian OS) and that is the only well tested?
                      I see Raspbian is available and updated for OPI trough his manufacturer.
                      http://www.orangepi.org/downloadresources/orangepipc/oragepipc_e930546e866b23585721e5d2a6.html
                      Regards
                      • aandA
                        aandA
                        aand
                        @jirm Thanks for the suggestion. I've downloaded the raspian image. To duplicate the path I used with armbian, I downloaded TMRh20's RF24 code so I can test the radio with code I've already had up and running on the hardware.. However, this version of raspbian is really bad. So far nothing compiles. Regular raspbian, and armbian on the orange pi one do not have this kind of problem out of the box; they compile a wide range of packages. I'll spend some more time on it to be diligent, but this distro looks like it needs to be put on the abandon pile.
                        I tried compiling mysensors gateway too but no luck with that yet either. This is what I get:
                        ./configure
                        [OK] init system detected: sysvinit
                        [OK] Finished.
                        make
                        gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
                        DIO_NRF24 -DMY_GATEWAY_LINUX -DMY_DEBUG -Ofast -g -Wall -Wextra -I. -I./core -I./drivers/Linux -c drivers/Linux/log
                        .c -o build/drivers/Linux/log.o
                        cc1: error: bad value (armv8-a) for -march switch
                        cc1: error: bad value (cortex-a53) for -mtune switch
                        Makefile:102: recipe for target 'build/drivers/Linux/log.o' failed
                        jirmJ 3 Replies Last reply
                        • aandA aand
                          ./configure
                          [OK] Finished.
                          make
                          jirmJ
                          jirmJ
                          jirm
                          #184
                          @aand
                          Ok. Arrrggg ! .
                          So sad ear that OPI Raspbian fork is too not working out the box and but its not surprise because the poor software support form manufacturer. Maybe this is another no way road.
                          So seems only keep fighting with both OS (arm and rasp) to make it working.
                          Some sugestions ...
                          Will be fine if can post this issue but in software section here on mysensors forums. Maybe some mysensors gateway developers or any linux hack can help to trace the error you have on armbian or raspbian.
                          Maybe can find another "no official" OPI Raspbian fork that compile better to mygateway. Maybe post this issue in OPI forums will be good and someone there can help or provide other better Raspbian fork.
                          Sadly in this days I dont have time to try install on my OPI´s to help more. :-1:
                          Regards
                          • aandA aand
                            ./configure
                            [OK] Finished.
                            make
                            jirmJ
                            jirmJ
                            jirm
                            #185
                            @aand
                            The las error you posted...is not on Raspbian but in Armbian ????
                            "gcc -MT build/drivers/Linux/log.o -MMD -MP -march=armv8-a -mtune=cortex-a53 -mfpu=neon-vfpv4 -mfloat-abi=hard -DMY_RA
                            cc1: error: bad value (cortex-a53) for -mtune switch"
                            In any case seems this is a gcc compiler error maybe because "wrong" version for that processor...so maybe trying to update gcc compiler can help to avoid that error?
                            • aandA
                              aandA
                              aand
                              @jirm The compiler error was from the raspbian image running on the orange pi one hardware. I installed the image, ran apt-get update and apt-get upgrade, then tried the mysensors installation. The error was unusual enough to stop me in my tracks ... it didn't look like a simple dependency error.
                              armbian is not as well known as raspbian, but it is a very good distribution with an active and friendly development team. I like raspbian because it is a mature distro, and that's why I wanted to give it a try when you pointed out it's availability, but armbian is a very good alternative. I like armbian a lot and I hope we can get mysensors to work on it. Armbian also supports some of the newest and exciting hardware like the Nano Pi Neo and the Orange Pi Zero, each with a lot of IoT possibilities (they are very small form factors and low cost).
                              As you can tell, I think it's a big win if we can get it working on armbian. I will look for the place you mentioned on the forum that might be a good place to post this issue -- please let me know if you have a suggestion on where it's best to post. And I'd like to thank you for your consideration of this problem.
                              • jirmJ
                                jirmJ
                                jirm
                                I´m in the same boat as you, because for the moment I choose OPI hardware for my HA (Home Automation) system.
                                Agree with you that Armbian is much better OS than Raspbian in general terms and preferably the path to walk through for OPI, but in that case always we walk on a parallel side because Raspbian is today the most prefered OS for IoT on developments because Raspberry is the predominant hardware. So that means in future we need fight each installation.
                                In that case, Armbian forums sure is necesary place that can help to solve that problem too, but I think first better post here on mysensors software forums to try to get some more light about that specific error about mysensors gateway install process, and then at least have more info to report to someone that can help in Armbian.
                                I'm trying to find some help more about the issues you raise and if you maintain posting updates here will be so good for me and sure for others that can use OPI too now or on future.
                                OPI´s I´m sure is in near future a very good hardware (because they're so good relation cost-performance and quality) that mucho more people would choose for next coming IoT projects.
                                Regards
                                • jirmJ jirm
                                  Regards
                                  jirmJ
                                  jirmJ
                                  jirm
                                  #188
                                  @aand
                                  The error you post seems because gcc compiler is not well supporting the processor, so maybe need substitute all gcc compiler version in the OS to solve the issue (that's I wanted say before with update).
                                  apt-get update/upgrade cannot substituting "any" software to other because doing this only can push to last version the existing installed branch on the yet installed software on the OS.
                                  So It's not any dependence error it's a gcc compiler error raised for some weird version incompatibility with the hardware installed. Strange error but this is seems means message error you posted. So seems needed reinstall all gcc compiler to avoid that.
                                  Hope I explain enough...sorry about my bad english ;-)
                                  See you...
                                    musthafa
                                    Can I install mysensors on a openhab installed RPi ?
                                    • Robinek70R Robinek70
                                      Hello everyone,
                                      thanks
                                      //Robert
                                      marceloaqno
                                      Code Contributor
                                      wrote on last edited by marceloaqno
                                      #190
                                      @Robinek70
                                      $ sudo mysgw -h
                                      Usage: mysgw [options]
                                      Options:
                                      To generate a soft hmac key, run:
                                      sudo mysgw --gen-soft-hmac-key
                                      and set it using:
                                      sudo mysgw  --set-soft-hmac-key=KEY
                                      For example:
                                      $ sudo mysgw --gen-soft-hmac-key
                                      SOFT_HMAC_KEY | 7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
                                      The next line is intended to be used in SecurityPersonalizer.ino:
                                      #define MY_SOFT_HMAC_KEY 0X7F,0X3F,0X1A,0X1C,0X1E,0XA3,0X2B,0X72,0XBF,0X4B,0XED,0XE2,0XD1,0X65,0X43,0X97,0X1C,0X26,0X44,0X2F,0X69,0X57,0X21,0X77,0XD9,0XCC,0XDE,0X39,0X3B,0XFB,0X81,0X26
                                      To use this key, run mysgw with:
                                       --set-soft-hmac-key=7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
                                      $ sudo mysgw --set-soft-hmac-key=7F3F1A1C1EA32B72BF4BEDE2D16543971C26442F69572177D9CCDE393BFB8126
                                      The same process applies to generate/set the other key types.
                                        marceloaqno
                                        Code Contributor
                                        #191
                                        @aand @Tag @jirm MySensors uses its own nrf24 drivers, and OrangePi is not currently supported. It will be in the future.
                                        jirmJ T 2 Replies Last reply
                                        • M marceloaqno
                                          jirmJ
                                          jirmJ
                                          jirm
                                          @marceloaqno
                                          You mean the error posted @aand is because that?
                                          You mean mysgw use own NRF24 drivers that is not supported on OPI although he have running Raspbian version?.
                                          In any case, if so will be really fine if mysgw software allowed (or provide information about how to do it) to use any NRF24 driver (ex. TMRh20 fork that is working fine on OPI) and maybe too Hope RFMXX (I´m most interested in this last transceivers) because I think that generally speaking make a rigidly link with a type of hardware is not the best thing that can be done to really give the best functionality to any application.
                                          Still keep waiting for anyone here than can help to install mysgw softw on OPI.
                                          Thanks for your information
                                          Best regards
