  3. ESP8266 MQTT gateway + sonoff_MQTT code + vera + HA_Bridge + Alexa, oh my
9 Posts 2 Posters 6.3k Views 3 Watching
  • S Offline
    stephenmhall
    Hi guys, I have been playing with a sonoff using MQTT and a Mosquitto server on my Synology diskstation.
    But could not see a way to get control of the sonoff on my vera (with Mysensors) as it does not support MQTT.
    I started to play with the ESP8266 MQTT gateway, the gateway has an NRF radio but is Not connected to the vera as an actual gateway.
    (I just opened a second page on Mysensors to check something and saw Efflon posted a MQTT Sonoff post but his uses home assistant which supports MQTT so I think mine is different enough to keep going)
    Ok so, here is the working chain:
    • "Alexa switch on mains plug 1"
    • Alexa talks to HA Bridge (also running on my Synology) where mains plug 1 is the friendly name of Vera virtual switch device no 181 id 20;10 parent 3
    • HA Bridge talks to Vera in html to switch on the Virtual switch with id 20;10 (I have a 433Txnode with id 20 and 6 switches) with parent id 3(Mysensors plugin)
    • Message then goes out the Mysensors serial gateway and is broadcast over NRF (20/10/1/1/2 1)
    • The ESP8266_MQTT_gateway picks up the message on NRF and sends it on to the MQTT broker (mygateway1-out/20/10/1/1/2 with message 1)
    • The SONOFF unit is subscribed to the broker and picks up the message and switches on.
    if you press the button on the sonoff it works in reverse as far as Vera, sending a message to mygateway1-in/20/10/1/1/2 0 or 1 switching the state of the virtual switch.
    The ESP8266 MQTT gateway code was unchanged.
    Sonoff MQTT code from esp8266.com
    The only change was to the topic name
     It connects to an MQTT server then:
      - on 0 switches off relay
      - on 1 switches on relay
      - on 2 switches the state of the relay
      - sends 0 on off relay
      - sends 1 on on relay
     It will reconnect to the server if the connection is lost using a blocking
     reconnect function. See the 'mqtt_reconnect_nonblocking' example for how to
     achieve the same result without blocking the main loop.
     The current state is stored in EEPROM and restored on bootup
    #include <ESP8266WiFi.h>
    #include <PubSubClient.h>
    #include <EEPROM.h>
    const char* ssid = "ssid";
    const char* password = "password";
    const char* mqtt_server = "broker IP address";
    WiFiClient espClient;
    PubSubClient client(espClient);
    long lastMsg = 0;
    char msg[50];
    int value = 0;
    //const char* outTopic = "Sonoff1out";
    const char* outTopic = "mygateway1-in/20/10/1/1/2";
    //const char* inTopic = "Sonoff1in";
    const char* inTopic = "mygateway1-out/20/10/1/1/2";
    int relay_pin = 12;
    int button_pin = 0;
    bool relayState = LOW;
    // Instantiate a Bounce object :
    Bounce debouncer = Bounce();
    void setup_wifi() {
      delay(10);
      // We start by connecting to a WiFi network
      Serial.println();
      Serial.print("Connecting to ");
      Serial.println(ssid);
      WiFi.begin(ssid, password);
      while (WiFi.status() != WL_CONNECTED) {
        extButton();
        for(int i = 0; i<500; i++){
          extButton();
          delay(1);
        Serial.print(".");
      digitalWrite(13, LOW);
      delay(500);
      digitalWrite(13, HIGH);
      delay(500);
      delay(500);
      Serial.println("");
      Serial.println("WiFi connected");
      Serial.println("IP address: ");
      Serial.println(WiFi.localIP());
    void callback(char* topic, byte* payload, unsigned int length) {
      Serial.print("Message arrived [");
      Serial.print(topic);
      Serial.print("] ");
      for (int i = 0; i < length; i++) {
        Serial.print((char)payload[i]);
      Serial.println();
      // Switch on the LED if an 1 was received as first character
      if ((char)payload[0] == '0') {
        digitalWrite(relay_pin, LOW);   // Turn the LED on (Note that LOW is the voltage level
        Serial.println("relay_pin -> LOW");
        relayState = LOW;
        EEPROM.write(0, relayState);    // Write state to EEPROM
        EEPROM.commit();
      } else if ((char)payload[0] == '1') {
        digitalWrite(relay_pin, HIGH);  // Turn the LED off by making the voltage HIGH
        Serial.println("relay_pin -> HIGH");
        relayState = HIGH;
        EEPROM.commit();
      } else if ((char)payload[0] == '2') {
        relayState = !relayState;
        digitalWrite(relay_pin, relayState);  // Turn the LED off by making the voltage HIGH
        Serial.print("relay_pin -> switched to ");
        Serial.println(relayState);
        EEPROM.commit();
    void reconnect() {
      // Loop until we're reconnected
      while (!client.connected()) {
        Serial.print("Attempting MQTT connection...");
        // Attempt to connect
        if (client.connect("ESP8266Client")) {
          Serial.println("connected");
          // Once connected, publish an announcement...
          client.publish(outTopic, "Sonoff1 booted");
          // ... and resubscribe
          client.subscribe(inTopic);
          Serial.print("failed, rc=");
          Serial.print(client.state());
          Serial.println(" try again in 5 seconds");
          // Wait 5 seconds before retrying
          for(int i = 0; i<5000; i++){
            extButton();
            delay(1);
    void extButton() {
      debouncer.update();
       // Call code if Bounce fell (transition from HIGH to LOW) :
       if ( debouncer.fell() ) {
         Serial.println("Debouncer fell");
         // Toggle relay state :
         digitalWrite(relay_pin,relayState);
         if (relayState == 1){
          client.publish(outTopic, "1");
         else if (relayState == 0){
          client.publish(outTopic, "0");
      EEPROM.begin(512);              // Begin eeprom to store on/off state
      pinMode(relay_pin, OUTPUT);     // Initialize the relay pin as an output
      pinMode(button_pin, INPUT);     // Initialize the relay pin as an output
      pinMode(13, OUTPUT);
      relayState = EEPROM.read(0);
      debouncer.attach(button_pin);   // Use the bounce2 library to debounce the built in button
      debouncer.interval(50);         // Input must be low for 50 ms
      digitalWrite(13, LOW);          // Blink to indicate setup
      delay(500);
      delay(500);
      setup_wifi();                   // Connect to wifi
      client.setServer(mqtt_server, 1883);
      client.setCallback(callback);
      if (!client.connected()) {
        reconnect();
      client.loop();
      extButton();
    //- See more at: http://www.esp8266.com/viewtopic.php?f=29&t=8746#sthash.vhv33y8Q.dpuf
    You don't need to add any extra gateways to Vera, you just add Virtual Switches and program each sonoff (or any other ESP8266) with the different Broker topics needed.
    EfflonE 1 Reply Last reply
    • S stephenmhall
      #include <EEPROM.h>
      long lastMsg = 0;
      char msg[50];
      int value = 0;
      int relay_pin = 12;
      int button_pin = 0;
      void setup_wifi() {
        delay(10);
        Serial.println();
          extButton();
            extButton();
            delay(1);
          Serial.print(".");
        delay(500);
        delay(500);
        delay(500);
        Serial.println("");
        Serial.print("] ");
        Serial.println();
          relayState = LOW;
          EEPROM.commit();
          relayState = HIGH;
          EEPROM.commit();
          EEPROM.commit();
      void reconnect() {
              extButton();
              delay(1);
      void extButton() {
        debouncer.update();
        delay(500);
        delay(500);
          reconnect();
        client.loop();
        extButton();
      EfflonE Offline
      EfflonE Offline
      Efflon
      @stephenmhall Cool! With my Sonoff example there is not a must to use HASS or mqtt. A MYS gateway or a standard mqtt broker would work fine. Anyway, as long as things work, life is good :smile: . What I don't understand is where the mqtt broker is running?
      • S Offline
        stephenmhall
        wrote on last edited by stephenmhall
        Broker is running on my Synology Diskstation, keeps it all in house as it were. The HA bridge is just there to allow Alexa to control Vera devices.
        • S stephenmhall
          EfflonE Offline
          EfflonE Offline
          Efflon
          @stephenmhall aha! But vera runs MYS? Then using my code with the ESP8266 wifi sketch should work without all in-between stuff? (just guessing)..
          • S Offline
            stephenmhall
            @Efflon I don't think it would, I'm assuming your Home Assistant controller is telling the sonoff to switch using MQTT with your config code
            mysensors:
              gateways:
                - device: mqtt
                  persistence_file: '/home/homeassistant/.homeassistant/sonoff.json'
                  topic_in_prefix: 'sonoff-out'
                  topic_out_prefix: 'sonoff-in'
              debug: false
              optimistic: false
              persistence: true
              retain: true
              version: 2.0
            The problem is the Vera controller does not speak MQTT at all, there is a plugin to send device statuses out to a Broker but it's not two way. So all you could do is send the fact that the switch is on or off, but not change it.
            This gets round that by sending out a MySensors message which is then converted into MQTT to switch the Sonoff. so the Vera does not need to know about MQTT and the Sonoff units do not need to know about MySensors.
            • S stephenmhall
              mysensors:
                gateways:
                  - device: mqtt
                debug: false
                optimistic: false
                persistence: true
                retain: true
                version: 2.0
              EfflonE Offline
              EfflonE Offline
              Efflon
              @stephenmhall What I mean is by using the ESP8266 wifi sketch with my presentation etc. code (not the top mqtt parts) the sonoff will talk standard "MYS ethernet code" with your MYS controller.
              Untested example code:
               * Version 1.0 - Henrik EKblad
               * Contribution by Ivo Pullens (ESP8266 support)
               * The EthernetGateway sends data received from sensors to the WiFi link.
               * VERA CONFIGURATION:
               * LED purposes:
               * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch, only the LEDs that is defined is used.
               * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
               * nRF24L01+  ESP8266
               * VCC        VCC
               * CE         GPIO4
               * CSN/CS     GPIO15
               * SCK        GPIO14
               * MISO       GPIO12
               * MOSI       GPIO13
               * GND        GND
                * Inclusion mode button:
              #define MY_BAUD_RATE 9600
              #define MY_GATEWAY_ESP8266
              #define MY_ESP8266_SSID "MySSID"
              #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
              // Enable UDP communication
              //#define MY_USE_UDP
              // #define MY_ESP8266_HOSTNAME "sensor-gateway"
              #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
              #define MY_PORT 5003
              // Enable inclusion mode
              // #define MY_INCLUSION_BUTTON_FEATURE
              // Set blinking period
              // #define MY_DEFAULT_LED_BLINK_PERIOD 300
              // Flash leds on rx/tx/err
              #if defined(MY_USE_UDP)
              #include <WiFiUdp.h>
              #define BUTTON_PIN 0  // Sonoff pin number for button
              #define RELAY_PIN 12  // Sonoff pin number for relay
              #define LED_PIN 13    // Sonoff pin number for LED
              #define RELAY_ON 1
              #define RELAY_OFF 0
              #define LED_ON 0
              #define LED_OFF 1
              // Id of the sensor child
              #define CHILD_ID 0
              int oldValue = 0;
              bool state = false;
              MyMessage msg(CHILD_ID,V_STATUS);
                // Setup the button
                pinMode(BUTTON_PIN, INPUT_PULLUP);
                debouncer.attach(BUTTON_PIN);
                debouncer.interval(5);
                // Make sure relays and LED are off when starting up
                digitalWrite(LED_PIN, LED_OFF);
                pinMode(RELAY_PIN, OUTPUT);
                pinMode(LED_PIN, OUTPUT);
              void presentation()  {
                // Send the sketch version information
                sendSketchInfo("Sonoff", "1.0");
                // Register sensor
                present(CHILD_ID, S_BINARY);
                // Send the current state
                send(msg.set(state?true:false));
                // Blink when ready
                blink();
                debouncer.update();
                // Get the update value
                int value = debouncer.read();
                if (value != oldValue && value==0) {
                  // Toggle the state
                  state = state?false:true;
                  // Change relay state
                  // Change LED state
                  digitalWrite(LED_PIN, state?LED_ON:LED_OFF);
                  // Send new state
                  send(msg.set(state));
                oldValue = value;
                // We only react on status messages from the controller
                // to this CHILD_ID.
                if (message.type==V_STATUS  && message.sensor==CHILD_ID) {
                  // Only switch if the state is new
                  if (message.getBool() != state) {
                    state = message.getBool();
                    // Change LED state
              void blink()
                digitalWrite(LED_PIN, digitalRead(LED_PIN)?LED_ON:LED_OFF);
                wait(200);
                wait(200);
                wait(200);
              • S Offline
                stephenmhall
                Would it not need to be added to the Vera as another gateway? I only have a serial gateway on the vera at the moment, I seem to remember I had problems the last time I tried to upgrade to an esp8266 ethernet Gateway and had to go back to the old serial one.
                Mysensor plugin is reporting version 1.5 lib 2.0.0
                • S stephenmhall
                  EfflonE Offline
                  EfflonE Offline
                  Efflon
                  @stephenmhall ahh, serial gateway. Then just forget all I wrote... :smile:
                  • S Offline
                    stephenmhall
                    Switches working well but I can't get Temperature to update on a device.
                    When switching on a sonoff locally it sends
                    mygateway1-in/20/10/1/1/2/1
                    to the MQTT broker, which immediately causes the switch on the device in Vera to show on, this is passed back out and is sent back to the sonoff.
                    However I cannot get a temperature device to update. I send
                    mygateway1-in/50/1/1/0/0/20.70
                    to the Broker but get no change. I can send an html command to update the temp fine.
                    here is the Vera device parameters.
                    I have tried sending to the in and the out topic just to be sure.
                    Does anyone have a log from an actual temp node showing the message passed to the gateway just in case someting is not right with my message?
                    Also is there a way to monitor the serial messages passed into the Vera from the gateway to check the messages are passing?
                    12.2k
