  3. A Basic domestic 240v light and switch.
8 Posts 2 Posters 3.2k Views 4 Watching
  • el tigroE Offline
    el tigroE Offline
    el tigro
    Once again I must be missing something. Nowhere can I find and example of a simple domestic 240v light switch and light fitting.
    I have lights on my HA, can control them with PC, phone, ALEXA, no problem, but I want manual switches (wifi) on the walls also.
    I use the relay sketch for the light fitting side, all working fine.
    Can I find anything relating to the switch side..... naffink.
    I have built the hardware, arduino nano,NRF2401+ all sat on the back of a single UK light switch. Thats all good and tested also. It's the code I dont have or guidance to set it up.
    Lights, temp, alexa were all basically plug and play with minor tweaks, this, a most simple use, baffled again.
    Please help.
    Boots33B 1 Reply Last reply
    • el tigroE el tigro
      Please help.
      Boots33B Offline
      Boots33B Offline
      Boots33
      @el-tigro The relay with button actuator sketch is a good place to start
      • el tigroE Offline
        el tigroE Offline
        el tigro
        I did have a look at that I assume I would need to insert a trigger also. It all seemed a bit over the top for the simplest of operation. All I want is if pin 3 goes high, publish light on.
        The bit I can't get my head around is that there is no details of topics etc to establish what goes where. Because I don't know, it is all a bit 'magic' how the communications work.
        • el tigroE Offline
          el tigroE Offline
          el tigro
          This is the yaml entry for mqtt switch from HA website
          switch:
            - platform: mqtt
              state_topic: "home/bedroom/switch1"
              command_topic: "home/bedroom/switch1/set"
              payload_on: "ON"
              payload_off: "OFF"
              optimistic: false
              qos: 0
              retain: true
          There is no similar refence for mysensors switch section.
          It's hard to ask when your not sure what your asking for.
            switch:
              - platform: mqtt
                payload_on: "ON"
                payload_off: "OFF"
                optimistic: false
                qos: 0
                retain: true
            Boots33B Offline
            Boots33B Offline
            Boots33
            wrote on last edited by Boots33
            @el-tigro Yes MySensors is certainly a journey of discovery ! :)
            I am not sure exactly what part of the sketch you are having problems understanding. I do not use yaml or mqtt so will not be of any help there i am afraid.
            Below I have posted a slightly modified relay sketch, which is probably more suited to being used as a light switch, It should work even if the uplink to the gateway/controller is lost. It is fairly well commented so have a look and let me know what part you need more info on.
            The part that lets the controller know when the local switch has been used to change the state is in the loop section. This sketch, like the original uses a momentary on push button you would need to make a few small changes if you are using a toggle switch.
             send(msg.set(state), false);          // send new state to controller, no ack requested
             * Relay with button sketch
             * modified to work with no uplink
             * to gateway
            #define MY_TRANSPORT_WAIT_READY_MS 3000     //set how long to wait for transport ready. in milliseconds
            #define RELAY_PIN  4      // Arduino Digital I/O pin number for relay
            #define RELAY_ON 1
            #define RELAY_OFF 0
            Bounce debouncer = Bounce();
            int oldValue = 0;
            bool state;
              pinMode(BUTTON_PIN, INPUT);              // Setup the button pin
              digitalWrite(BUTTON_PIN, HIGH);           // Activate internal pull-up
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              pinMode(RELAY_PIN, OUTPUT);               // set relay pin in output mode
              digitalWrite(RELAY_PIN, RELAY_OFF);      // Make sure relay is off when starting up
            void presentation()  {
              present(CHILD_ID, S_BINARY);
              debouncer.update();
              oldValue = value;
              if (message.type == V_STATUS) {                               // check to see if incoming message is for a switch
                state = message.getBool();                                  // get the current state
                digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to current state
            • el tigroE Offline
              el tigroE Offline
              el tigro
              Hello mate and thanks for chirping in. I realised a while ago that this project was well above my current knowledge base but thats like a red rag to bull, stubborn old git that I am.
              After I got my HA, mqtt, MySensors and the gateway talking, my first few nodes found and set themselves up pretty much. I didn't have to jump into message construction, pub/sub, complex yaml code and that's the bit I'm stuck on. Once I get it, I'm away, the penny just hasn't dropped yet.
              I think I need a night in, just me and mqtt, a nice meal, a bottle of soco, a few cuddles and really get to know each other. I guess thats true cyber sex, i do have a wife and kids.... honest.
              Any reccommended sites, tutorials will be appreciated.
              • el tigroE Offline
                el tigroE Offline
                el tigro
                wrote on last edited by el tigro
                Here is the most basic sketch I could find and tweaked the code to run as a toggle on a domestic light switch.
                #define MY_NODE_ID 25
                #define OPEN 1
                #define CLOSE 0
                #define switchpin 3
                int oldvalue = OPEN;
                MyMessage msg(MY_NODE_ID, V_TRIPPED);
                uint8_t value = OPEN;
                  pinMode (switchpin, INPUT_PULLUP);
                  sendSketchInfo("TESTER", "");
                  present(MY_NODE_ID, S_DOOR);
                  if (digitalRead(switchpin) == !oldvalue)
                    value = value == OPEN ? CLOSE : OPEN;
                    send(msg.set(value));
                    oldvalue = value;
                With this code alone,no yaml entry, the node is found by HA and shows accordingly as triggered if the switch is flicked. mqtt all good, gateway happy.
                How the fook do I attach switch result to the intended node?
                Do I need a yaml entry for the physical switch? I tried but failed.
                Do I then need to set up a trigger?
                switch:
                  - platform: mqtt
                    command_topic: "mygateway1-in/2/2/1/0/2"
                    payload_on: "1"
                    payload_off: "0"
                    optimistic: false
                    qos: 0
                    retain: true
                This just gives me a new (software) switch in my dash and controls the light but physical switch (node 2 child 2) doesn't work.
                • el tigroE Offline
                  el tigroE Offline
                  el tigro
                  1485777547: Sending PINGRESP to mysensors-1
                  1485777562: Received PINGREQ from mysensors-1
                  1485777562: Sending PINGRESP to mysensors-1
                  1485777563: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/5/25/1/0/16', ... (1 bytes))
                  1485777563: Sending PUBLISH to home-assistant-1 (d0, q0, r0, m0, 'mygateway1-out/5/25/1/0/16', ... (1 bytes))
                  1485777565: Received PUBLISH from mysensors-1 (d0, q0, r0, m0, 'mygateway1-out/5/25/1/0/16', ... (1 bytes))
                  1485777565: Sending PUBLISH to home-assistant-1 (d0, q0, r0, m0, 'mygateway1-out/5/25/1/0/16', ... (1 bytes))
                  This is the mqtt log for one on / off cycle.
                  12.1k
