  3. 💬 RFM69 Serial GW (ATMEGA328P)
mysensors gatewayserial
24 Posts 7 Posters 9.5k Views 6 Watching
  • mtiutiuM
    mtiutiuM
    mtiutiu
    Serial gw is working. Tested with real MySensors nodes and it's working properly. Now regarding stability and such - well...that only time will tell us.
    • tonnerre33T
      tonnerre33T
      tonnerre33
      Hello, what is the goal of the TXB0104, it's the first time that i see him in a project ?
      mtiutiuM 1 Reply Last reply
      • tonnerre33T tonnerre33
        mtiutiuM
        mtiutiuM
        mtiutiu
        @tonnerre33
        It's a logic level voltage converter. The MCU runs at 5V so the logic level voltage that it uses on the SPI port which connects to the RFM69W use 5V too. But the RFM69W module runs at 3.3V and it's not 5V tolerant on its SPI port pins.
        The purpose of that IC is to convert voltage levels on the SPI lines forward and backward (from 5V to 3.3V and vice versa) in order to not damage the RFM69W chip.
        • mtiutiuM mtiutiu
          @tonnerre33
          tonnerre33T
          tonnerre33T
          tonnerre33
          @mtiutiu said in 💬 MySensors RFM69W serial GW(ATMEGA328P):
          Oh ok, and just for know, why we don't power the atmega with 3.3V ?
            mtiutiuM
            mtiutiuM
            mtiutiu
            @tonnerre33
            Because at 3.3V the atmega328p mcu can run at max 8MHz as per datasheet. So I wanted it to run at double the speed and for that it needs 5V as per datasheet again. Why at 16MHz? Well because I want the gateway to be more faster in general and to quickly process the incoming messages from the entire radio network.
            • tonnerre33T
              tonnerre33T
              tonnerre33
              Thanks a lot, now i know why ;)
                mtiutiuM
                mtiutiuM
                mtiutiu
                @tonnerre33
                And to use higher baudrates for the serial port on the mcu also. To achieve higher baudrates you need a higher mcu clock frequency too.
                  shabba
                  Does anyone have a BOM for this?
                  • S shabba
                    mtiutiuM
                    mtiutiuM
                    mtiutiu
                    @shabba
                    Sorry but I don't have one now. When I have time I will generate it. For now I'm busy with the Livolo stuff.
                    • tonnerre33T
                      tonnerre33T
                      tonnerre33
                      0_1494000655324_upload-1cfecb9c-1343-4411-a8c4-b4546cd9a63e
                      A fast extraction without traitment if that can help ;)
                        shabba
                        I see C5 on the board has polarity. My ceramic caps seem to have no polarity (no markings on it - https://www.digikey.com/product-detail/en/murata-electronics-north-america/ZRB18AR61E106ME01L/490-10991-1-ND/5321192).
                        I assume that this is ok and this does not need to be a tantalum cap?
                        • S shabba
                          mtiutiuM
                          mtiutiuM
                          mtiutiu
                          #21
                          @shabba
                          Yes it's ok. Just make sure that you have 10V rated capacitors(this board runs at 5V so it's best to stay above that). On the radio side you can use 6V capacitors as it's powered at 3.3V but anyway...it's easier to use just 10V types instead of remembering what goes where imho.
                            shabba
                            Hi @mtiutiu - Did you ever get a chance to make a BOM? Most of the one @tonnerre33 one makes sense but I only bought two boards so being a little cautious :-)
                              shabba
                              Any BOM? :-)
                              I still have these PCBs and want to finish em. Can't source a crystal/resonator of about 5x4 mm.
                              • S shabba
                                Any BOM? :-)
                                mtiutiuM
                                mtiutiuM
                                mtiutiu
                                @shabba
                                The majority of the components are 0603 SMD package type (except 2 smd resistors on the usb lines which are not really mandatory and can be replaced with a solder bridge).
                                There you go (extracted from schematic - I can't do better than this because it involves more work and I don't have time for it, sorry):
                                a) 9 x 100nF 0603 SMD MLCC capacitors, X5R/X7R (voltage can be 10V and above)
                                b) 3 x 1uF 0603 SMD MLCC capacitors, X5R/X7R (voltage can be 10V and above)
                                c) 1 x 10uF 0603 SMD MLCC capacitor, X5R/X7R (voltage can be 10V and above)
                                d) 1 x 22uF 0603 SMD MLCC capacitor, X5R/X7R (voltage can be 10V and above)
                                e) 1 x 10nF 0603 SMD MLCC capacitor, X5R/X7R (voltage can be 10V and above)
                                f) 1 x ferrite bead 0603 SMD blm18he152sn1d
                                g) 3 x 330 ohm 0603 SMD resistor
                                h) 1 x 1Kohm 0603 SMD resistor
                                i) 1 x 10Kohm 0603 SMD resistor
                                j) 1 x 56Kohm 0603 SMD resistor
                                k) 1 x MCP1703A-3302 3.3V/0.25A voltage regulator
                                l) 1 x TXB0104 voltage level converter
                                m) 1 x ATMEGA328P-MU AVR MCU (QFN32 package)
                                n) 1 x CP2102 USB to serial (QFN28 package)
                                o) 3 x 0603 SMD LEDs (your pick here)
                                p) 1 x ATSHA204A (SOT-23 package)
                                q) 1 x RFM69W module (your pick regarding working frequency)
                                r) 1 x ZTTCS16.00MX ceramic resonator
                                s) 1 x USB A type male connector for PCB and 1 SMD reset switch (I have no exact links for this, sorry)
