  3. MyController.org
  4. MyController OTA problems
Scheduled Pinned Locked Moved MyController.org
15 Posts 2 Posters 5.6k Views 2 Watching
  • S slt1
    @jkandasa Hi. Its not too much inconvenience :) It would just be nice to get this working as MyController seems to work rather well for me otherwise.
    I am using Version 0.0.3.Final-SNAPSHOT of MyController.org
    The CHIP i installed Oracle JDK and then set it up to start on reboot by reading through this http://forum.mycontroller.org/topic/122/launch-start-sh-on-startup-or-like-a-service/2.
    I also have mosquitto, node and node-red setup on the CHIP.
    J
    J
    jkandasa
    @slt1 said in MyController OTA problems:
    I guess this makes MyController too slow. When you are not using inbuilt MQTT broker. you can make it disable. Can you send me the MyController.log file to know more about Ethernet failure?
    S 2 Replies Last reply
    • J jkandasa
      slt1
      wrote on last edited by slt1
      @jkandasa mycontroller.log file
      I am not using MQTT for MySensors. I just installed it to try out at some stage. I am using ethernet connection for MySensors from MyController.
      • J jkandasa
        slt1
        @jkandasa Sorry - i misread ... I do have the inbuilt MQTT disabled in MyController already
        J 1 Reply Last reply
        • S slt1
          J
          J
          jkandasa
          @slt1 I couldn't download the file you have attached. Can you please send it to jkandasa at gmail dot com?
          S 1 Reply Last reply
          • J jkandasa
            slt1
            @jkandasa Not sure why the "Upload file" for the forum is not working ! Sent via email !
            • S slt1
              J
              J
              jkandasa
              @slt1 Thank you! Do you have the serial or MQTT gateway? If yes, Can you try once with the serial or MQTT gateway and report the status?
              • J jkandasa
                slt1
                @jkandasa I only have an ESP8266 gateway working over ethernet. I do not have an MQTT or serial gateway. Should I rather be using one of those?
                • S slt1
                  J
                  J
                  jkandasa
                  @slt1 For now I do not have Ethernet gateway to reproduce your issue.
                  Yes, I request you to update your ESP8266 ethernet to MQTT. it is simple. Just modify your ESP8266 firmware as shown here. https://github.com/mysensors/MySensors/blob/development/examples/GatewayESP8266MQTTClient/GatewayESP8266MQTTClient.ino
                  • J jkandasa
                    slt1
                    @jkandasa There are 2 problems I have moving to MQTT. Firstly MYSController only works on Ethernet and Serial. Secondly, in MyController.org I lose all my sensor data as it will create new nodes for each of the sensors it picks up on a new gateway.
                    • S slt1
                      J
                      J
                      jkandasa
                      wrote on last edited by jkandasa
                      @slt1
                      I understand this. But the only test with MQTT. If you are not fine with the change of gateway. go back to current setup.
                      No, You can use edit gateway option. Edit existing ethernet gateway and update to MQTT configuration. This will retain your setup as is.
                      • J jkandasa
                        @slt1
                        slt1
                        @jkandasa Ok. I will try it out and let you know. Thanks for all the help. Its greatly appreciated.
                        12.5k
