  3. ESP8266 with RFM69HW - missing packets
12 Posts 3 Posters 3.8k Views 3 Watching
  • R
    R
    robosensor
    How many packets per second are you sending to ESP side?
      melwinek
      In loop:
      V_VAR1
      V_VAR1
      V_VAR1
      Wait 5sec.
      Between 3 VAR messages no wait.
      • R
        R
        robosensor
        Please try to test code with wait() between each send. In some enviroments (not in all) sometimes (not always) ESP code blocks thread of execution up to 200 milliseconds while waiting for TCP ACK packet. So if you send next your packet in this 200 ms interval packet (or next packet) can be missed.
          melwinek
          wrote on last edited by melwinek
          In 2.1.1 wait 200ms, did not help
          In development, everything is okay. All messages is received by gateway once.
          Tomorrow I will check the range, maybe I do not need RFM69HCW just RFM69CW. Thanks for help.
          One observation:
          Global variables in development version use a lot of dynamic memory. Its normal ?
          mppM 1 Reply Last reply
          • M melwinek
            One observation:
            mppM
            mppM
            mpp
            @melwinek why are you using #define MY_RFM69_NEW_DRIVER? The documentation about this doesn't explain why you should or should not use it.
            MyController with USB powered WeMos D1/mini ESP8266 MQTT Gateways and battery powered Arduino Pro Mini using the RFM69 radio
              melwinek
              MY_RFM69_NEW_DRIVER uses unique transmission power control, if the distance is less, transmission power is also reduced.
              • M melwinek
                mppM
                mppM
                mpp
                @melwinek thank you. What controller and sketch are you using?
                  melwinek
                  Controller: fhem
                  Sketch: GatewayESP8266OTA with my changes:
                  #define MY_RADIO_RFM69
                  #define MY_RFM69_MAX_POWER_LEVEL_DBM 13
                  #define MY_RF69_IRQ_PIN 15
                  #define MY_RF69_SPI_CS 16
                  Hardware is very simple :)
                  • mppM
                    mppM
                    mpp
                    Wow, very simple indeed! You're just using the ESP12E chip, have you tried using a microcontroller like the NodeMCU or WeMos D1?
                      melwinek
                      NodeMCU is much bigger. It also costs a lot more. I do not need a USB port or any other features that have these modules.
