  2. Feature Requests
  3. Heartbeat
Heartbeat
Scheduled Pinned Locked Moved Feature Requests
3 Posts 2 Posters 3.2k Views 1 Watching
  • F
    F
    filoucaenais
    wrote on last edited by filoucaenais
    hello
    Has it there in the library means to control whether a node is active?
    type heartbeat
    thanks
    • F filoucaenais
      hello
      type heartbeat
      thanks
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @filoucaenais
      I do it by sending the status with a regular interval... so that you can see from the Last Update time in the device panel (Vera).
      like this example:
      * Motion Sensor Version 1.1
      * November 7, 2014
      * -Added pushing text status to V_VAR1
      * Version 1 - October 4, 2014
      * -Modified to transmit on state change
      * -removed Sleep for mains-only device
      * -Updates gateway according to UPDATE_INTERVAL
      #define DEBUG
      #define DIGITAL_INPUT_SENSOR 3
      #define RADIO_ID 2
      #define CHILD_ID 1
      #define UPDATE_INTERVAL 60000UL  // 1 minute
      boolean lastSensorState;
      MyMessage stateMsg(CHILD_ID, V_TRIPPED);
      MyMessage updateMsg(CHILD_ID, V_VAR1);
        gw.begin(NULL, RADIO_ID, false);
        #ifdef DEBUG
        gw.sendSketchInfo("MotionSensor", "V1.1");
        pinMode(DIGITAL_INPUT_SENSOR, INPUT);
        gw.present(CHILD_ID, S_MOTION);
        boolean sensorState = digitalRead(DIGITAL_INPUT_SENSOR);
        if (sensorState != lastSensorState)
          #ifdef DEBUG
            digitalWrite(13, sensorState ? HIGH : LOW);
            Serial.println(sensorState ? "Tripped" : "Not Tripped");
          gw.send(stateMsg.set(sensorState ? "1" : "0"));
        lastSensorState = sensorState;
        updateStatus(UPDATE_INTERVAL);
      void updateStatus(unsigned long updateInterval)
        static unsigned long lastUpdate;
        if (millis() - lastUpdate >= updateInterval)
          gw.send(updateMsg.set(lastSensorState ? "Motion Detected" : "No Motion"));
          #ifdef DEBUG
            digitalWrite(13, lastSensorState ? HIGH : LOW);
            Serial.println(lastSensorState ? F("Tripped") : F("Not Tripped"));
          lastUpdate += updateInterval;
      • F
        F
        filoucaenais
        thank you for your answer
