  3. 💬 RFM69(H)W Arduino Mini Pro Shield
rfm69arduino pro minishieldrfm69hw
27 Posts 8 Posters 12.1k Views 5 Watching
  • stevebusS
    stevebusS
    stevebus
    Thanks for the quick reply. No need for special build for IRQ (although that might be a good addition for a future rev to have that option). I can solder to a pad, it's just trickier as my E.E. training, skills, steadier hands, and better eyesight were 20+ years ago :-)
    For the holes, out of curiosity, I see the VCC hole connection trace on the board, but I can't see how the pins are all connected to GND (i.e. can't see any traces). Is it between the layers of the board? Or am I just going blind?
    Thanks again for the contribution as this is a very nice project.
    Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
    Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
    J 1 Reply Last reply
    • stevebusS stevebus
      J
      J
      jlaraujo
      @stevebus you are going blind :-D (like me probably) all those pins are in the ground plane, trying to provide a uniform ground to see if it improves the performance of the radio (by reducing outside interference). You can see that clearly on the gnd of the capacitor or in the gnd pad.
      Domoticz, mysensors 2.3.1, RFM69 and RF24 sensors
      gohanG 1 Reply Last reply
      • stevebusS
        stevebusS
        stevebus
        Ah! I see! (said the blind man :-) ).
        I had never really paid attention to PCB design, so didn't realize there were often "planes" for some widespread connections (like ground)... makes perfect sense.
        Thx again for the quick responses. I'll be soldering up the rest of the connections tomorrow so I'll be able to give it a test.
        • J jlaraujo
          @jlaraujo I am about to order sma connectors, is there anything to look for or anyone would do?
            sundberg84S
            sundberg84S
            @gohan - use the same size on the connector as you have when you order the boards ;)
              If you can find the size let me know, I looked on aliexpress and none are showing what is the supported pcb size. So either it is like standard for 1.6mm pcbs or I have no idea
              J sundberg84S 2 Replies Last reply
              • stevebusS
                stevebusS
                stevebus
                Was able to finish up the soldering, and just playing with the mocksensor sketch... works great! (not sure why my pics are sideways, they are straight on my machine :-) )
                Looking at the RSSI data, this sensor seems to be about the same signal strength as my other sensors (maybe even slightly better, probably due to the shorter and more solid connections). So it seems that the performance of the radio is pretty good.
                sensor1
                sensor2
                  J
                  J
                  jlaraujo
                  @gohan It seems to be a standard sma size the 1.6mm distance between the legs, anyway if it is bigger you can solder only the top layer, if it is shorter, you can cut some legs.
                  Not the best but it should work.
                    sensor1
                    sensor2
                    J
                    J
                    jlaraujo
                    @stevebus glad it is working i have an updated version of the pcb in the first production run, that will not need any extra wiring, i'll keep you guys updated on the progress.
                    • stevebusS
                      stevebusS
                      stevebus
                      Thanks @jlaraujo... Definitely keep us up to date and i'll be happy to order and try it out.
                        sundberg84S
                        sundberg84S
                        @gohan - I have found both 1.6mm and 1mm on Ebay. Since i like to order 1mm thats what i went with SMA connector but it was way easier to find 1.6mm. I just mean a easy misstake would be to order a 1.6mm SMA connector and 1.0mm pcb. Might probably work.
                          Since I ordered 1.6mm pcbs, I think I should be fine then.
                            556duckvader
                            I really like this design as I am looking for a small for factor RFM69 shield. One question how hard would it be to integrate a connection for a DHT22 to be able to have a small temp and humidity transmitter. I need to have about 5 of these setup in different locations sending temp and humidity back to a gateway.
                              The sensor will be attached to the arduino, not to the shield
                              • 5 556duckvader
                                J
                                J
                                jlaraujo
                                @556duckvader, like @gohan referred, you can attach the DHT22 to the arduino and not to the shield.
                                You can make a simple PCB that will connect to the required ports for the DHT22 to operate.
                                If you'd like to have an even smaller footprint, try this design:
                                https://www.openhardware.io/view/615
                                It is not yet tested in production, probably will be by the end of the week.
                                  There are also other solutions that have I2C bus pins on the shield and if you are going to make a battery powered node, I'd suggest to use an I2C sensor as it will be much more battery friendly
