  3. MyNodes.NET
  4. Installing ASP.NET 5/Core onto Raspberry Pi 3
Scheduled Pinned Locked Moved MyNodes.NET
13 Posts 4 Posters 7.0k Views 4 Watching
  • derwishD
    derwishD
    derwish
    It seems Microsoft has removed the old version of the ASP.NET framework, as soon as the new released. Wait for MyNodes be updated on the new framework.
    • nutcrackerN
      nutcrackerN
      nutcracker
      Thanks derwish.... any ETA on that ?
      • derwishD
        derwishD
        derwish
        I will try to do it on the weekend.
        • nutcrackerN
          nutcrackerN
          nutcracker
          Thanks derwish!
          • derwishD
            derwishD
            derwish
            I started to port MyNodes, but it's not as easy as I thought. Meanwhile, you can try to install everything according to the old instructions: https://docs.asp.net/en/1.0.0-rc1/getting-started/installing-on-linux.html
            nutcrackerN 1 Reply Last reply
            • derwishD derwish
              nutcrackerN
              nutcrackerN
              nutcracker
              @derwish ok... so what versions of the software do I need to have installed to ensure compatibility with MyNodes...? (I thought I had already tried rc1). Thanks.
              • K
                K
                kellers76
                Is there something new to install .net on the raspberry?
                I have tried it, but the installation does not get to run.
                • derwishD
                  derwishD
                  derwish
                  Hi. At this moment the project was successfully ported to the ASP .NET Core (thanks to gildorwang). But I did not try to run it on raspberry. You can try last version. At the same time, I'm porting MyNodes to the node.js. This project is ready for 70%. It will work on raspberry, but at the moment it is not ready to use.
                  • K
                    K
                    kellers76
                    Hello derwish,
                    Thank you for your info
                    I plan my new house with about 100 - 120 mysensor nodes to install and wants to then manage the nodes with your great software.
                    TerrenceT 1 Reply Last reply
                    • K kellers76
                      Hello derwish,
                      TerrenceT
                      TerrenceT
                      Terrence
                      @kellers76 Wow, that is a lot of sensors. What and where will you be measuring? Just a general grouping.
                      • K
                        K
                        kellers76
                        @Terrence said in Installing ASP.NET 5/Core onto Raspberry Pi 3:
                        Hi terrence, i steer and rule in every room the light, the rolls and the heating
