  3. MyNodes.NET
  4. Installing ASP.NET 5/Core onto Raspberry Pi 3
Scheduled Pinned Locked Moved MyNodes.NET
13 Posts 4 Posters 6.2k Views 4 Watching
  • nutcrackerN Offline
    nutcrackerN Offline
    nutcracker
    Has anyone had any luck in attempting to do the above? I've tried to follow the instructions on the website but the download link doesn't work (http://docs.asp.net/en/latest/getting-started/installing-on-linux.html).
    I've tried installing alternatives but no luck - issues with ARM/Intel compatibility... what am I doing wrong?
    Nutz
      nutcrackerN Offline
      nutcracker
      Have made some progress... by following the instructions here...
      https://github.com/lluppes/pisharp
      However, I'm now stumped with an error to do with libuv.
      Welcome to MyNodes.NET.
      Please configure the system in the web interface.
      System.DllNotFoundException: libuv
      at (wrapper managed-to-native) Microsoft.AspNet.Server.Kestrel.Networking.Libuv+NativeMethods:uv_loop_size ()
      at Microsoft.AspNet.Server.Kestrel.Networking.Libuv.loop_size () <0x6f73f560 + 0x00023> in <filename unknown>:0
      at Microsoft.AspNet.Server.Kestrel.Networking.UvLoopHandle.Init (Microsoft.AspNet.Server.Kestrel.Networking.Libuv uv) <0x6f73f478 + 0x0002f> in <filename unknown>:0
      at Microsoft.AspNet.Server.Kestrel.KestrelThread.ThreadStart (System.Object parameter) <0x6f73eef0 + 0x0008f> in <filename unknown>:0
      • derwishD Offline
        derwishD Offline
        derwish
        It seems Microsoft has removed the old version of the ASP.NET framework, as soon as the new released. Wait for MyNodes be updated on the new framework.
          nutcrackerN Offline
          nutcracker
          Thanks derwish.... any ETA on that ?
          • derwishD Offline
            derwishD Offline
            derwish
            I will try to do it on the weekend.
              nutcrackerN Offline
              nutcracker
              Thanks derwish!
              • derwishD Offline
                derwishD Offline
                derwish
                I started to port MyNodes, but it's not as easy as I thought. Meanwhile, you can try to install everything according to the old instructions: https://docs.asp.net/en/1.0.0-rc1/getting-started/installing-on-linux.html
                nutcrackerN 1 Reply Last reply
                • derwishD derwish
                  nutcrackerN Offline
                  nutcrackerN Offline
                  nutcracker
                  @derwish ok... so what versions of the software do I need to have installed to ensure compatibility with MyNodes...? (I thought I had already tried rc1). Thanks.
                  • K Offline
                    K Offline
                    kellers76
                    Is there something new to install .net on the raspberry?
                    I have tried it, but the installation does not get to run.
                    • derwishD Offline
                      derwishD Offline
                      derwish
                      Hi. At this moment the project was successfully ported to the ASP .NET Core (thanks to gildorwang). But I did not try to run it on raspberry. You can try last version. At the same time, I'm porting MyNodes to the node.js. This project is ready for 70%. It will work on raspberry, but at the moment it is not ready to use.
                      • K Offline
                        K Offline
                        kellers76
                        Hello derwish,
                        Thank you for your info
                        I plan my new house with about 100 - 120 mysensor nodes to install and wants to then manage the nodes with your great software.
                        TerrenceT 1 Reply Last reply
                        • K kellers76
                          Hello derwish,
                          TerrenceT Offline
                          TerrenceT Offline
                          Terrence
                          @kellers76 Wow, that is a lot of sensors. What and where will you be measuring? Just a general grouping.
                          • K Offline
                            K Offline
                            kellers76
                            @Terrence said in Installing ASP.NET 5/Core onto Raspberry Pi 3:
                            Hi terrence, i steer and rule in every room the light, the rolls and the heating
                            11.9k
                            113.3k
